  4. Adapter upgrade klappt nicht
upgrade adpater
4 Beiträge 2 Kommentatoren 482 Aufrufe 2 Beobachtet
  • werner2000xW Offline
    werner2000x
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC/Pi3/etc.
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link
    Ich kann drei adapter nicht mehr upgraden. Folgender Fehler kommt mit iob upgrade --debug
    iob upgrade --debug
    Update vw-connect from @0.0.62 to @0.0.67
    NPM version: 9.5.1
    Installing iobroker.vw-connect@0.0.67... (System call)
    npm ERR! code EBADENGINE
    npm ERR! engine Unsupported engine
    npm ERR! engine Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
    npm ERR! notsup Not compatible with your version of node/npm: iobroker.daikin-cloud@0.2.3
    npm ERR! notsup Required: {"node":"^12.19.0 || ^14.15.0 || ^16.13.0"}
    npm ERR! notsup Actual:   {"npm":"9.5.1","node":"v18.16.0"}
    npm ERR!     /home/iobroker/.npm/_logs/2023-04-18T11_57_07_123Z-debug-0.log
    upload [4] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/admin.d.ts admin.d.ts video/mp2t
    upload [3] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/index_m.html index_m.html text/html
    upload [2] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/style.css style.css text/css
    upload [1] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/vw-connect.png vw-connect.png image/png
    upload [0] vw-connect.admin /opt/iobroker/node_modules/iobroker.vw-connect/admin/words.js words.js application/javascript
    Update vis-icontwo from @0.90.0 to @0.93.0
    NPM version: 9.5.1
    Installing iobroker.vis-icontwo@0.93.0... (System call)
    npm ERR!     /home/iobroker/.npm/_logs/2023-04-18T11_57_32_606Z-debug-0.log
    Adapter "system.adapter.vis.0" restarted.
    upload [1347] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/alarm.png Alarm/alarm.png image/png
    upload [1300] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Alarm/sensor_window_red.png Alarm/sensor_window_red.png image/png
    upload [1250] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Automobile/defogger2.png Automobile/defogger2.png image/png
    upload [1200] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Backgrounds/Seamless/80.jpg Backgrounds/Seamless/80.jpg image/jpeg
    upload [1150] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Brands/raspberry.png Brands/raspberry.png image/png
    upload [1100] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Awning/awning4_50.png Devices/Awning/awning4_50.png image/png
    upload [1050] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Computers/pc_rep.png Devices/Computers/pc_rep.png image/png
    upload [1000] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Cooling/fan2_mode_timer.png Devices/Cooling/fan2_mode_timer.png image/png
    upload [950] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Network/offline.png Devices/Network/offline.png image/png
    upload [900] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/Sounds/radio_cb.png Devices/Sounds/radio_cb.png image/png
    upload [850] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Devices/microwave.png Devices/microwave.png image/png
    upload [800] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Doors_Windows/Shutter/blinds2_50.png Doors_Windows/Shutter/blinds2_50.png image/png
    upload [750] vis-icontwo /opt/iobroker/node_modules/iobroker.vis-icontwo/www/Drinks_Food/beans.png Drinks_Food/beans.png image/png
    Raspi4 8 GB mit Aqara Zigbee USB, iob
    Innogy Smarthome
    Bosch Bridge 2
    HUE Bridge
    OpenWB Wallbox mit EVU Kit
    Google Nest Pro Hub
    HA auf uGreen dxp4800
    • werner2000xW werner2000x
      NPM-Version: 6.x.x
      iob upgrade --debug
      NPM version: 9.5.1
      NPM version: 9.5.1
      @werner2000x sagte in Adapter upgrade klappt nicht:
      Node.js 18 is currently NOT supported because the used OAuth library does not support it!
      Und das blockiert die anderen Updates mit. Vielleicht hier erstmal mit nodejs16 weiterfahren.
      Oder hier mal eine Beta installieren. Die dürfte auch funktionieren.
      werner2000xW 1 Antwort Letzte Antwort
        werner2000x
        @thomas-braun Vielen Dank für die Antwort :-)
        Ich warte noch etwas mit einer Umstellung, da ich ohne Upgrade (noch) keine Probleme habe.
        Vielleicht löst sich der Fehler bald von selbst.
        Innogy Smarthome
        Bosch Bridge 2
        HUE Bridge
        Google Nest Pro Hub
          Der löst sich, wenn eine nodejs18-kompatible Version über das bei dir eingestellte Repo (vermutlich 'stable') verfügbar ist.
