  5. full zigbee2tasmota integration
3 Beiträge 1 Kommentatoren 1.1k Aufrufe 2 Beobachtet
    randomuser123
    Re: [JSON](Zigbee und ein undefined)
    I recently bought a zigbee2tasmota device. I managed to set it up with the iobroker.sonoff adapter which allows me to read zigbee sensor values nicely.
    But with the sonoff adapter I can not send control commands, for example to turn on a light or a socket.
    To do that I understand that I have to send a mqtt command, but that is not possible with the sonoff adapter (afaik).
    I can use another mqtt client, but then I don't have the feature of the sonoff adapter that splits up the mqtt json string into separate iobroker objects :-/
    Here's what I would like to achieve:
    • receive tasmota mqtt messages and split them up into separate objects
    • send an mqtt command to tasmota. Ideally by setting for example "myFancyMqtt.0.ZigbeeLight.power = true" will send the appropriate command to my zigbee2tasmota device that will turn on the ZigbeeLight.
    Is there any out-of-the-box solution available as of 2023?
      randomuser123
      Maybe this script https://forum.iobroker.net/topic/48945/tasmota-steckdosen-per-mqtt-javascript-direkt-ansteuern/23 can help, but I don't want to modify a script every time I add a new zigbee device...
        randomuser123
        Ok, I finally had time to find a solution. Thanks to chatGPT :-)
        The zigbee2tasmota device is connected to a "regular" mqtt client in iobroker (not the sonoff adapter). When a zigbee message arrives it gets forwarded via mqtt to my iobroker as a json string.
        My script parses that json and creates separate states for each of the key:value pairs in the json.
        For sending commands I automatically add an additional state "PowerSet" to devices that have a "Power" state. When I update the PowerSet state, a script creates a json string and writes it into the "mqtt.0.cmnd.ZigbeeGateway.ZbSend" state (see https://tasmota.github.io/docs/Zigbee/#sending-device-commands)
        The advantage of this approach is that I have nothing to do on the iobroker side when I add new zigbee devices, they are handled automatically.
        That's it :-) Seems to work well so far. Here's the script in case anyone has a similar problem with zigbee2tasmota:
        // ############## user config
        // where the mqtt messages arrive
        const zigbee2tasmotaSensorObjectId = 'mqtt.0.tele.ZigbeeGateway.SENSOR';
        // where the states of the zigbee devices should appear
        const zbBaseFolder = '0_userdata.0.zigbee2tasmota';
        // ZbSend state, see https://tasmota.github.io/docs/Zigbee/#sending-device-commands
        const zbsendObjId = 'mqtt.0.cmnd.ZigbeeGateway.ZbSend';
        // ############## end user config
        const regexPowerSetStr = `${zbBaseFolder}\\..*PowerSet$`;
        const regexPowerSet = new RegExp(regexPowerSetStr);
        // receive
        on(zigbee2tasmotaSensorObjectId, (obj) => {
          const jsonString = obj.state.val;
          const jsonData = JSON.parse(jsonString);
          // log(`Received JSON string: ${jsonString}`);
          function createObjectsRecursively(parent, data) {
            for (const key in data) {
              const obj = data[key];
              const stateName = `${parent}.${key}`;
              if (typeof obj === 'object') {
                createObjectsRecursively(stateName, obj);
              } else {
                let value = obj;
                // custom handling of special data types
                if (key.toLowerCase() == 'time') {
                  value = new Date(obj);
                  log("found time")
                // Check if the state already exists. If it does, just update the value.
                // If it does not exist (-> new zigbee device), create the states.
                if (!existsState(stateName)) {
                  // If the state does not exist, create it and set the value
                  createState(stateName, value, {
                    type: typeof value,
                    role: "value",
                    read: true,
                    write: true
                  log(`Created state ${stateName}`);
                  // create additional state to set a new value that will be sent to the zigbee device.
                  // If I use the normal "Power" state, I am afraid it will trigger the zbSend command
                  // everytime it gets updated from the zigbee device itself.
                  if (stateName.endsWith("Power")) {
                    let powerSetStateName = stateName + "Set"
                    createState(powerSetStateName, !!value, {
                      name: key + "Set",
                      type: "boolean",
                      role: "value",
                      read: true,
                      write: true
                    log(`Created state ${powerSetStateName}`);
                  // potentially add more custom handling for dimmer values, etc
                } else {
                  setState(stateName, value);
                // log(`set state ${parent}.${key} with value ${value}`);
          createObjectsRecursively(zbBaseFolder, jsonData);
        // send power on/off
        on(regexPowerSet, (obj) => {
          const objId = obj.id;
          // probably regex is not needed and we can just take .Device or .Name
          // Define a regular expression to match the substring between "ZbReceived" and "PowerSet"
          const regex = /ZbReceived\.(.*?)\.PowerSet/;
          // Use the regular expression to extract the substring
          const match = objId.match(regex);
          if (match) {
            const zbname = match[1];
            let newValue = obj.state.val;
            let zbsendstring = "\{\"Device\": \"" + zbname + "\"\,\"Send\"\:\{\"Power\"\: "+newValue+"\}}"
            log("zbsend: " + zbsendstring)
            setState(zbsendObjId, zbsendstring)
          } else {
            log(`The substring between "ZbReceived" and "PowerSet" not found in ${objId}`);
        PS: sending zigbee commands is only supported for power on/off. I don't have any zigbee devices that have dimmer or hue values or anything else. I guess the script can be adapted to work with those kind of devices, too.
