  4. Node-Red
  5. Pumpe steuern über Tempdifferenz
    6.5k
21 Beiträge 5 Kommentatoren 2.3k Aufrufe 4 Beobachtet
  • S stefan14
    @rudolf1957
    Versuche es mal mit diesem flow
            "id": "899599b8f9de1378",
            "type": "tab",
            "label": "Flow 2",
            "disabled": false,
            "info": "",
            "env": []
            "id": "458e3bc802ffa358",
            "type": "api-current-state",
            "z": "899599b8f9de1378",
            "name": "",
            "server": "2a08017d41c42a0a",
            "version": 3,
            "outputs": 1,
            "halt_if": "",
            "halt_if_type": "str",
            "halt_if_compare": "is",
            "entity_id": "sensor.28_ff641f598ee0_temperature",
            "state_type": "num",
            "blockInputOverrides": false,
            "outputProperties": [
                    "property": "payload",
                    "propertyType": "msg",
                    "value": "",
                    "valueType": "entityState"
                    "property": "topic",
                    "value": "Temp1",
                    "valueType": "str"
            "for": "0",
            "forType": "num",
            "forUnits": "minutes",
            "override_topic": false,
            "state_location": "payload",
            "override_payload": "msg",
            "entity_location": "data",
            "override_data": "msg",
            "x": 550,
            "y": 540,
            "wires": [
                    "c9415f769ea20817"
            "id": "fce1376ac4483678",
            "type": "inject",
            "name": "",
            "props": [
                    "p": "payload"
                    "p": "topic",
                    "vt": "str"
            "repeat": "1",
            "crontab": "",
            "once": false,
            "onceDelay": 0.1,
            "topic": "",
            "payload": "",
            "payloadType": "date",
            "x": 210,
            "y": 560,
            "wires": [
                    "458e3bc802ffa358",
                    "e562b1ee38ae590c"
            "id": "e562b1ee38ae590c",
            "name": "",
            "version": 3,
            "outputs": 1,
            "halt_if": "",
            "entity_id": "sensor.solis_temperature",
                    "value": "",
                    "value": "Temp2",
                    "valueType": "str"
            "for": "0",
            "forType": "num",
            "x": 520,
            "y": 600,
            "wires": [
                    "c9415f769ea20817"
            "id": "80b539375074cdfd",
            "type": "function",
            "name": "function 5",
            "func": "msg.topic = \"diff\"\nmsg.payload = msg.payload.Temp2 - msg.payload.Temp1;\nreturn msg;",
            "outputs": 1,
            "noerr": 0,
            "initialize": "",
            "finalize": "",
            "libs": [],
            "x": 1080,
            "y": 560,
            "wires": [
                    "19dc43570ca9090f",
                    "61e394b2b1d96a82"
            "id": "c9415f769ea20817",
            "type": "join",
            "name": "",
            "mode": "custom",
            "build": "object",
            "key": "topic",
            "joiner": "\\n",
            "joinerType": "str",
            "accumulate": false,
            "timeout": "",
            "count": "2",
            "reduceRight": false,
            "reduceExp": "",
            "reduceInit": "",
            "reduceInitType": "",
            "reduceFixup": "",
            "x": 890,
            "y": 560,
            "wires": [
                    "80b539375074cdfd",
                    "847e8baca31e6b10"
            "id": "19dc43570ca9090f",
            "type": "debug",
            "name": "debug 6",
            "active": true,
            "tosidebar": true,
            "console": true,
            "tostatus": true,
            "complete": "payload",
            "targetType": "msg",
            "statusVal": "payload",
            "statusType": "auto",
            "x": 1310,
            "y": 620,
            "wires": []
            "id": "847e8baca31e6b10",
            "type": "debug",
            "name": "debug 7",
            "active": false,
            "tosidebar": true,
            "console": true,
            "tostatus": true,
            "x": 1070,
            "y": 640,
            "wires": []
            "id": "61e394b2b1d96a82",
            "type": "switch",
            "name": "",
            "rules": [
                    "t": "gt",
                    "v": "1",
                    "vt": "num"
                    "t": "lt",
                    "v": "1",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 1390,
            "y": 460,
            "wires": [
                    "316918699f3ea2ea"
                    "0c942921a06f0cb7"
            "id": "316918699f3ea2ea",
            "type": "api-call-service",
            "name": "Pumpe Ein",
            "version": 5,
            "debugenabled": false,
            "domain": "switch",
            "service": "turn_on",
            "areaId": [],
            "deviceId": [],
            "entityId": [
                "switch.hm_flur_statusanzeige_state_ch3"
            "data": "",
            "dataType": "jsonata",
            "mergeContext": "",
            "mustacheAltTags": false,
            "outputProperties": [],
            "queue": "none",
            "x": 1610,
            "y": 400,
            "wires": [
            "id": "0c942921a06f0cb7",
            "name": "Pumpe Aus",
            "version": 5,
            "domain": "switch",
            "service": "turn_off",
            "areaId": [],
            "deviceId": [],
            "entityId": [
            "data": "",
            "mergeContext": "",
            "queue": "none",
            "x": 1610,
            "y": 480,
            "wires": [
            "id": "2a08017d41c42a0a",
            "type": "server",
            "name": "Home Assistant",
            "version": 5,
            "addon": false,
            "rejectUnauthorizedCerts": true,
            "ha_boolean": "y|yes|true|on|home|open",
            "connectionDelay": true,
            "cacheJson": true,
            "heartbeat": false,
            "heartbeatInterval": "30",
            "areaSelector": "friendlyName",
            "deviceSelector": "friendlyName",
            "entitySelector": "friendlyName",
            "statusSeparator": ": ",
            "statusYear": "hidden",
            "statusMonth": "short",
            "statusDay": "numeric",
            "statusHourCycle": "default",
            "statusTimeFormat": "h:m",
            "enableGlobalContextStore": false
    rudolf1957
    @stefan14
    Hallo Stefan14, es funktioniert, nachdem ich die Geräte angepasst habe!
    Herzlichen Dank ☺ 🙏
