  3. Einsteigerfragen
  4. Sonoff Adapter nur Gelb
9 Beiträge 3 Kommentatoren 1.2k Aufrufe 3 Beobachtet
  • Z Offline
    Z Offline
    zgadgeter
    Hallo, bei mir is der Adapter sied einiger Zeit immer nur Gelb. Ich habe den Iobroker von einer VM zu einem LXC in Proxmox gesetzt.
    Habe den Adapter schon entfernt und installiert, Einstellungen geaendert, etc.
    Beim Start steht im Log folgendes, und der Sonoff Adapter hat die Version: V2.5.1
    Hat jemand ein Tipp fuer mich?
    sonoff.0
    2023-03-04 12:08:28.721	info	Starting MQTT server on port 1883
    sonoff.0
    2023-03-04 12:08:28.644	info	starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.1, js-controller: 4.0.24
    sonoff.0
    2023-03-04 11:08:22.907	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-03-04 11:08:22.905	info	terminating
    sonoff.0
    2023-03-04 11:08:22.901	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-03-04 11:04:23.502	info	Starting MQTT server on port 1883
    sonoff.0
    2023-03-04 11:04:23.389	info	starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.1, js-controller: 4.0.24
    sonoff.0
    2023-03-04 11:04:17.794	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-03-04 11:04:17.792	info	terminating
    sonoff.0
    2023-03-04 11:04:17.788	info	Got terminate signal TERMINATE_YOURSELF
    sonoff.0
    2023-03-04 11:03:18.419	info	Starting MQTT server on port 1883
    sonoff.0
    2023-03-04 11:03:18.274	info	starting. Version 2.5.1 in /opt/iobroker/node_modules/iobroker.sonoff, node: v16.19.1, js-controller: 4.0.24
    sonoff.0
    2023-03-04 11:03:12.586	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    sonoff.0
    2023-03-04 11:03:12.583	info	terminating
    sonoff.0
    2023-03-04 11:03:12.551	info	Got terminate signal TERMINATE_YOURSELF
    • Z zgadgeter
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      sonoff.0
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @zgadgeter sagte in Sonoff Adapter nur Gelb:
      erst nach dem Umzug oder auch schon vorher so gewesen .
      Der Adapter bleibt Gelb wenn kein Gerät verbunden ist .
      Kenn dein System nicht , Port eventuell nicht weitergereicht ... oder !?
      Z 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        Z Offline
        Z Offline
        zgadgeter
        @glasfaser Hi und danke
        Also mindestens ein Geraet ist im netz, war auch vorher drin. Ich kann mich ehrlich gesagt nicht mehr daran errinnern ob der Adapter in der VM schon Probleme machte.
        Sorry, was meinst Du mit port weiter geleitet? Meinst Du in den Sonoff Geraeten ob der richtige Port eingegeben ist? Das ja.
        • Z zgadgeter
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          Was heißt das für mich ,
          also ist er über den Sonoff Adapter auch auslesbar / steuerbar
          und was heißt nur ein Gerät
          Ok , also erst nach dem Umzug .
          du schreibts :
          LXC in Proxmox
          da wie ich schon erwähnt dein Systemaufbau nicht kenne , kann es auch sein das du mit Docker arbeitest , oder mit was anderes .
          Daher müssen die Ports Weitergleitete werden .
          Aber , da du am Anfang schreibts:
          aber die Aussage ist schwamming , deshalb meine Frage am Anfang in dieser Antwort !
          Dann hast du eine Connect , dann brauchst du keine Portweiterleitung !?
            du schreibts :
            LXC in Proxmox
            Z Offline
            Z Offline
            zgadgeter
            @glasfaser
            Hi, also nix mit Docker, das ganze mit Proxmox und einen container jetzt.
            Vorher mit Proxmox und einer VM.
            Vorher waren mehrere Geraete im System, momentan nur ein Sonoff Geraet.
            Sorry aber mit den Port weiterleitungen weiss ich nicht was Du meinst.
            1883 stegt in dem Adapter, und 1883 steht in dem einem sonoff Geraet.
            Das ganze genau so wie es vorher in der VM war.
            W 1 Antwort Letzte Antwort
            • Z zgadgeter
              @glasfaser
              W Online
              W Online
              Wildbill
              @zgadgeter Läuft eventuell bereits ein anderer Adapter, der den Port 1883 blockiert? MQTT oder Shelly wären da so Kandidaten. Dann musst Du für diese Adapter jeweils andere Ports vernwenden z.B. 1885 und 1887. Und diese dann auch beiu den jeweiligen Geräten ändern. Was zum zweiten Punkt führt: Du hattest vorher eine VM und jetzt einen LXC. Hat der LXC die gleiche IP-Adresse als vorher die VM? Ansonsten musst Duz bei den Geräten natürlich auch die neue Adresse des iobroker angeben.
              Das wären mal so gerne gemachte Stolperfallen.
              Gruss, Jürgenb
              • W Wildbill
                Gruss, Jürgenb
                GlasfaserG Offline
                GlasfaserG Offline
                Glasfaser
                @wildbill sagte in Sonoff Adapter nur Gelb:
                Wenn der Port belegt wäre, dann wäre die Logmeldung dazu anders.
                Aber diese Aussage macht mich stutzig ...
                Warum nur ein Gerät !?
                @glasfaser sagte in Sonoff Adapter nur Gelb:
                @glasfaser...
                .... kein Antwort auf meine Fragen .
                  @glasfaser...
                  Z Offline
                  Z Offline
                  zgadgeter
                  @glasfaser Hi und sorry fuer die Konfusion.
                  Also es ist im moment (später vielleicht mehr) nur ein Gerät in meinen Iobroker System was Sonoff benutzt. Das ist ein Zwischenstecker, der per IP steuerbar ist, aber halt nicht über Iobroker, bzw. dem Sonoff Adapter.
                  Was Ports angeht, habe ich den shelly aus gemacht, den Sonoff an, und auch bei dem Sonoff einen anderen Port eingestellt. Keins davon hat funktioniert.
                  Ausserdem, beim Shelly benutze ich die COAP Einstellungen, nicht die MQTT, heisst doch das da kein Port benutzt wird, oder?
                  • Z Offline
                    Z Offline
                    zgadgeter
                    Hmm, strange...ich habe gerade zwei Sachen gemacht, bzw. geprüft.
                    Ich habe in dem Sonoff die IP Addresse geprüft, und in der MQTT Einstellungen war tatsächlich die falsche IOB Addresse eingegeben. Das habe ich korrigiert. Sonoff Adapter neu gestartet, immer noch Geld.
                    Dann habe ich in dem Sonoff Adapter eine UserID und Passwort eingegeben (hatte ich zuvor nicht), und in dem Sonoff Geraet das auch gemacht.
                    Sonoff Adapter neu gestartet...Gruen.
                    Hmmm
