  3. Off Topic
  4. influxDB Update Fehler public key
    6.3k
    1.6k
influxdb public key error
11 Beiträge 3 Kommentatoren 2.1k Aufrufe 3 Beobachtet
  • xxx_turbo_xxxX Offline
    xxx_turbo_xxx
    ich habe seit einer Weile das Problem, dass ich beim Update von InfluxDB einen Error bekomme.
    pi@raspberrypi:/etc/apt/sources.list.d $ sudo apt-get update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 https://repos.influxdata.com/debian stable InRelease
    Get:4 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
    Hit:5 https://apt.grafana.com stable InRelease
    Hit:6 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:7 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:8 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:9 https://repo.ebusd.eu/apt/nomqtt/bullseye bullseye InRelease
    Err:4 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Fetched 7,022 B in 2s (3,071 B/s)
    Reading package lists... Done
    N: Ignoring file 'influxdata-archive_compat.key' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Ich habe 2 repos Listen für influx mit folgenden Inhalten gefunden. Frag mich warum? Eine sollte doch reichen?
    influxdata.list
    deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
    influxdb.list
    deb [signed-by=/usr/share/keyrings/influxdb-archive-keyring.gpg] https://repos.influxdata.com/debian bullseye stable
    Würde das gerne glatt ziehen und wär über Support sehr dankbar :-)
    • xxx_turbo_xxxX xxx_turbo_xxx
      influxdata.list
      influxdb.list
      @xxx_turbo_xxx
      Zu influxdb steht hier auch was dabei:
      https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
        xxx_turbo_xxx
        schrieb am zuletzt editiert von xxx_turbo_xxx
        Das war nicht gut :-)
        hab das gemacht...
        und jetzt kommt das... Verstehe nicht, was das mit Grafana zu tun hat... Das hat davor noch funktioniert...
        Get:1 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://deb.debian.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Get:5 https://apt.grafana.com stable InRelease [5,984 B]
        Hit:6 https://repo.ebusd.eu/apt/nomqtt/bullseye bullseye InRelease
        Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
        Err:1 https://repos.influxdata.com/debian bullseye InRelease
        Get:8 https://apt.grafana.com stable/main armhf Packages [68.2 kB]
        Err:8 https://apt.grafana.com stable/main armhf Packages
          File has unexpected size (67781 != 68168). Mirror sync in progress? [IP: 2a04:4e42:6f::729 443]
          Hashes of expected file:
           - Filesize:68168 [weak]
           - SHA512:219e0403856608149840204d86c1f3d0ab07a08acc07f8a8c02957ac843b40ebc292c8798d7d91dd05a5e82c1bd6125fbf6b66726670df4b54247ee0d33b0964
           - SHA256:71566d26c07ea46f56e421e023e2ed46ce903d10c8554e981da09cf3d29ccf9c
           - SHA1:eeab0b4a8a96b34bf3ab4e6381ba719344e42e7b [weak]
           - MD5Sum:f9059eccea966e300342f8bc9e027eb2 [weak]
          Release file created at: Tue, 28 Feb 2023 11:22:49 +0000
        Get:9 https://apt.grafana.com stable/main arm64 Packages [70.4 kB]
        Err:9 https://apt.grafana.com stable/main arm64 Packages
        Hit:10 http://archive.raspberrypi.org/debian bullseye InRelease
        Fetched 7,022 B in 6s (1,263 B/s)
        E: Failed to fetch https://apt.grafana.com/dists/stable/main/binary-armhf/Packages.bz2  File has unexpected size (67781 != 68168). Mirror sync in progress? [IP: 2a04:4e42:6f::729 443]
        E: Failed to fetch https://apt.grafana.com/dists/stable/main/binary-arm64/Packages.bz2
          hab das gemacht...
          @xxx_turbo_xxx sagte in influxDB Update Fehler public key:
          Der .key hat in dem Verzeichnis nix zu suchen.
          xxx_turbo_xxxX 1 Antwort Letzte Antwort
            xxx_turbo_xxx
            @thomas-braun ok, wo sollte er sonst liegen?
              @xxx_turbo_xxx
              Da wo er in der influxdb.list eingetragen und erwartet wird.
              Könnte in /usr/share/keyrings sein.
              Ist es jedenfalls auf meinem System:
              echad@chet:~ $ cat /etc/apt/sources.list.d/influxdb.list
              deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/debian bullseye stable
                xxx_turbo_xxx
                ah, ok... verstehe :-)
                Da liegen auch welche...
                pi@raspberrypi:/usr/share/keyrings $ dir
                debian-archive-bullseye-automatic.gpg           debian-archive-buster-security-automatic.gpg  debian-archive-stretch-automatic.gpg           influxdb-archive-keyring.gpg     raspberrypi-archive-removed-keys.gpg
                debian-archive-bullseye-security-automatic.gpg  debian-archive-buster-stable.gpg              debian-archive-stretch-security-automatic.gpg  influxdb.gpg                     raspberrypi-archive-stable.gpg
                debian-archive-bullseye-stable.gpg              debian-archive-keyring.gpg                    debian-archive-stretch-stable.gpg              nodesource.gpg
                debian-archive-buster-automatic.gpg             debian-archive-removed-keys.gpg               grafana.key                                    raspberrypi-archive-keyring.gpg
                  @xxx_turbo_xxx
                  Dann kann er ja da weg, wo er im Weg ist.
                    @xxx_turbo_xxx
                    Tschak
                    bin noch ein wenig verwirrt verwendest du dann noch den alten key, weil der bei dir influxdb.gpg lautet?
                    https://www.influxdata.com/blog/linux-package-signing-key-rotation/
                    Ich verwende iobroker docker und installiere influxdb2-cli per script.
                    • T Tschak
                      @tschak
                      Der Name ist wumpe, der Inhalt zählt.
                        @tschak
                        Tschak
                        schrieb am zuletzt editiert von Tschak
                        @thomas-braun danke habe es verstanden war für mich nur ein wenig verwirrend auf die schnelle
                        82.7k
