  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Smartmeter mit Hitchi und Norax 3D+
    5.1k
hichi ttl - ir lesekopfno or too long answersmartmeter hichi norax 3d+
11 Beiträge 4 Kommentatoren 621 Aufrufe 3 Beobachtet
  • Kay SchwassK Offline
    Kay Schwass
    IOBroker IOBroker
    Hardwaresystem: NUC
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Debian
    Node-Version: 16.19.0
    Nodejs-Version: 00.00.00
    NPM-Version: 8.19.3
    Installationsart: Manuell
    Image genutzt: Nein
    Ort/Name der Imagedatei: Kein
    Mein Hichi TTL - IR Lesekopf bring nach der Eingabe des PIN am Norax 3D+ nur noch folgede Fehler .
    Vor der Eingabe hat alles normal funktioniert.
    smartmeter.0
    2023-02-08 18:43:01.614	warn	No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-02-08 18:43:01.614	debug	Error: No or too long answer from Serial Device after last request.
    smartmeter.0
    2023-02-08 18:43:01.613	debug	MESSAGE TIMEOUT TRIGGERED
    smartmeter.0
    2023-02-08 18:43:01.611	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b00000000000000" -> null
    smartmeter.0
    2023-02-08 18:43:01.611	debug	ADD NEW DATA (233 + NEW 1)
    smartmeter.0
    2023-02-08 18:43:01.602	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b000000000000" -> null
    smartmeter.0
    2023-02-08 18:43:01.601	debug	ADD NEW DATA (232 + NEW 1)
    smartmeter.0
    2023-02-08 18:43:01.599	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b0000000000" -> null
    smartmeter.0
    2023-02-08 18:43:01.599	debug	ADD NEW DATA (231 + NEW 1)
    smartmeter.0
    2023-02-08 18:43:01.594	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b00000000" -> null
    smartmeter.0
    2023-02-08 18:43:01.594	debug	ADD NEW DATA (230 + NEW 1)
    smartmeter.0
    2023-02-08 18:43:01.583	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b000000" -> null
    smartmeter.0
    2023-02-08 18:43:01.583	debug	ADD NEW DATA (229 + NEW 1)
    smartmeter.0
    2023-02-08 18:43:01.578	debug	MATCH-RESULT MESSAGE: "000000000000000000ff72000000000000000045000069000000006900360000000000000000000000000000000000006900000000290000000069000000004100000000490000000049000000000000000000000000006900000000000000000200000000000000000000001b1b1b0000000000000000000000000000ff72000000000000000045000069000000006900370000000000000000000000000000000000006900000000690000000000690000000000000000004900000000004900000000000000000000000000690000000000000000020000000000000000001b1b1b0000" -> null
    usw...
    MOD EDIT: LOG IN CODE TAGS GESETZT </>
    • Kay SchwassK Kay Schwass
      IOBroker IOBroker
      Hardwaresystem: NUC
      Festplattenart: SSD
      NPM-Version: 8.19.3
      Image genutzt: Nein
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      smartmeter.0
      usw...
      @kay-schwass wie sind die Einstellungen?
      Kay SchwassK 2 Antworten Letzte Antwort
        Kay Schwass
          Kay Schwass
          @homoran Hallo, wie geschrieben - Vor Eingabe des PIN am Norax hat es noch funktioniert.
            IOBroker IOBroker
            Hardwaresystem: NUC
            Festplattenart: SSD
            NPM-Version: 8.19.3
            Image genutzt: Nein
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            smartmeter.0
            usw...
            @kay-schwass sagte in Smartmeter mit Hitchi und Norax 3D+:
            hängt jetzt am USB?
            Kay SchwassK 1 Antwort Letzte Antwort
            • wendy2702W Offline
              wendy2702W Offline
              wendy2702
              Lesekopf nicht richtig positioniert?
              Abfrageintervall zu kurz für den erweiterten Datensatz?
              Erweiterung nochmal deaktiviert und geschaut ob es dann wieder geht? Wenn ja unterstütz der Adapter das eventuell noch nicht
              optische Schnittstelle unterstützt SML Protokoll, an das FNN Lastenheft BZ angepasst
              Vielleicht kann der Adapter Entwickler @apollon77 da etwas zu sagen
                hängt jetzt am USB?
                Kay Schwass
                @homoran Ja, am FTDI Adapter
                • wendy2702W wendy2702
                  @wendy2702 sagte in Smartmeter mit Hitchi und Norax 3D+:
                  Nein, wenn der serielle Timeout ... 2s ist halt kurz ... überleg wieviele Zeichen da kommen und die baudrate. Setz auf 20s und schau was passiert und wie lange es dauert.
                  Es ist ja auch so ... Wenn er liesst dann liesst er. Wenn er aber zb die ersten 10 byte der nachricht verpasst hat dann muss er warten bis die vollständig gesendet wurde und dann die nächste kommt und die fertig ist. Also Faktisch muss die serielle wartezeit 2xsendezeit plus die Pause zwischen den nachrichten lang sein
                  • apollon77A apollon77
                    wendy2702W Offline
                    wendy2702W Offline
                    wendy2702
                    @apollon77 Nur um das klar zu stellen.
                    Ich hab das Problem nicht. Das hat @Kay-Schwass
                      Kay Schwass
                      @wendy2702 Heute morgen geht es :)
                      Wahrscheinlich war es wohl die Wartezeit, ich habe Sie auf 10sec korrigiert.
                      Danke !
                        Danke !
                        @kay-schwass das würde passen, da nach der PIN Eingabe ja das lange Datentelegramm kommt. Das benötigt entsprechend mehr Zeit als vorher das reduzierte Datentelegramm.
