  4. Loxone Instanz stützt bei der Verbindung ab
3 Beiträge 2 Kommentatoren 266 Aufrufe 2 Beobachtet
  • DreDaProD Offline
    DreDaProD Offline
    DreDaPro
    bei einer neuen Installation von IoBroker stürzt die Loxone Instanz bei der Verbindung mit Loxone ab.
    Plattform: linux
    Betriebssystem: linux
    Architektur: x64
    CPUs: 2
    Geschwindigkeit: 2096 MHz
    Modell: AMD Opteron 63xx class CPU
    RAM: 1.9 GB
    System-Betriebszeit: 22:34:13
    Node.js: v16.19.0
    time: 1675192113721
    timeOffset: -60
    Adapter-Anzahl: 457
    NPM: v8.19.3
    Datenträgergröße: 490.6 GB
    Freier Festplattenspeicher: 474.8 GB
    Betriebszeit: 00:01:34
    Aktive Instanzen: 10
    Pfad: /opt/iobroker/
    aktiv:
    host.IoBroker
    2023-01-31 20:08:31.193	error	instance system.adapter.loxone.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.IoBroker
    2023-01-31 20:08:31.193	error	Caught by controller[2]: at processTicksAndRejections (node:internal/process/task_queues:78:11)
    host.IoBroker
    2023-01-31 20:08:31.193	error	Caught by controller[2]: at flush (/opt/iobroker/node_modules/q/q.js:125:13)
    host.IoBroker
    2023-01-31 20:08:31.193	error	Caught by controller[2]: at runSingle (/opt/iobroker/node_modules/q/q.js:137:13)
    host.IoBroker
    2023-01-31 20:08:31.193	error	Caught by controller[2]: at /opt/iobroker/node_modules/q/q.js:624:44
    host.IoBroker
    2023-01-31 20:08:31.192	error	Caught by controller[2]: at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/q/q.js:808:41)
    host.IoBroker
    2023-01-31 20:08:31.192	error	Caught by controller[2]: at Promise.when (/opt/iobroker/node_modules/q/q.js:1142:31)
    host.IoBroker
    2023-01-31 20:08:31.192	error	Caught by controller[2]: at /opt/iobroker/node_modules/q/q.js:890:30
    host.IoBroker
    2023-01-31 20:08:31.192	error	Caught by controller[2]: at _rejected (/opt/iobroker/node_modules/q/q.js:864:24)
    host.IoBroker
    2023-01-31 20:08:31.192	error	Caught by controller[2]: at _handleBadAuthResponse (/opt/iobroker/node_modules/lxcommunicator/modules/WebSocket.js:336:14)
    host.IoBroker
    2023-01-31 20:08:31.192	error	Caught by controller[2]: TypeError: Cannot read properties of undefined (reading '_setAuthenticating')
    host.IoBroker
    2023-01-31 20:08:31.192	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    host.IoBroker
    2023-01-31 20:08:31.191	error	Caught by controller[0]: WebSocket: socket failed! WS Close Code: 1006
    loxone.0
    2023-01-31 20:08:30.627	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    loxone.0
    2023-01-31 20:08:30.625	info	terminating
    loxone.0
    2023-01-31 20:08:30.600	error	Cannot read properties of undefined (reading '_setAuthenticating')
    loxone.0
    2023-01-31 20:08:30.600	error	TypeError: Cannot read properties of undefined (reading '_setAuthenticating') at _handleBadAuthResponse (/opt/iobroker/node_modules/lxcommunicator/modules/WebSocket.js:336:14) at _rejected (/opt/iobroker/node_modules/q/q.js:864:24) at /opt/iobroker/node_modules/q/q.js:890:30 at Promise.when (/opt/iobroker/node_modules/q/q.js:1142:31) at Promise.promise.promiseDispatch (/opt/iobroker/node_modules/q/q.js:808:41) at /opt/iobroker/node_modules/q/q.js:624:44 at runSingle (/opt/iobroker/node_modules/q/q.js:137:13) at flush (/opt/iobroker/node_modules/q/q.js:125:13) at processTicksAndRejections (node:internal/process/task_queues:78:11)
    loxone.0
    2023-01-31 20:08:30.599	error	unhandled promise rejection: Cannot read properties of undefined (reading '_setAuthenticating')
    loxone.0
    2023-01-31 20:08:30.598	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    loxone.0
    2023-01-31 20:08:30.588	error	Couldn't open socket
    loxone.0
    2023-01-31 20:08:30.431	info	Trying to connect
    loxone.0
    2023-01-31 20:08:30.344	info	starting. Version 3.0.0 (non-npm: UncleSamSwiss/ioBroker.loxone#0d354f53ef9516762a6f8af492e625be8bff309d) in /opt/iobroker/node_modules/iobroker.loxone, node: v16.19.0, js-controller: 4.0.24
    MOD EDIT: LOG IN CODE TAGS </> GESETZT
    • Thomas BraunT Online
      @dredapro
      Warum fischst du den Adapter aus dem github und installierst das nicht ordentlich aus einem Repo?
      loxone
      github:	3.0.0
      latest:	3.0.0 for 13 months
      stable:	3.0.0 for 13 months
      Passt das?
      https://github.com/UncleSamSwiss/ioBroker.loxone/issues/369
      • DreDaProD Offline
        DreDaProD Offline
        DreDaPro
        schrieb am zuletzt editiert von DreDaPro
        @thomas-braun said in Loxone Instanz stützt bei der Verbindung ab:
        Hi Thomas,
        danke für deine Antwort.
        natürlich habe ich es zuerst aus dem Repo genommen. Hab versucht die Instanzen neu zu installieren oder den ganzen Adapter neu. Am Ende hab ich es versucht schon von Github aus.... aber da genau das gleiche..
