  4. fb-checkpresence - Fehler beim Lesen fb-devices.json
3 Beiträge 2 Kommentatoren 205 Aufrufe 1 Beobachtet
    Snopy_16
    Bei mir kommen beim Auslesen der Geräteliste der Fritzbox 7530 folgende Fehlermeldungen.```
    fb-checkpresence.0
    2023-01-18 20:17:52.979	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:17:52.452	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:17:52.376	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:17:12.879	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:17:12.559	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:17:12.500	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:17:12.443	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:16:23.861	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:16:23.808	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:15:23.750	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:15:23.651	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:15:23.558	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    fb-checkpresence.0
    2023-01-18 20:14:58.625	error	getWlBlInfo: TypeError: Cannot read properties of null (reading 'length')
    Bitte um Hilfe, ich kann nichts anfangen damit 😕
    Man kann nicht alle Probleme lösen, aber wenigstens verursachen.
    LenovoThinkCentre M900 Tiny | i5-T6500 | 16 GB | 256 SSD
    iobroker auf Proxmox VM
    Node.js: v22.22.3 - NPM: 10.9.8 - js-controller: 7.0.6 - admin: v7.8.23
    FritzBox-7530TX hinter Glasfasermodem, WiFi mit Unifi
    afuerhoffA 1 Antwort Letzte Antwort
    • S Snopy_16
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      fb-checkpresence.0
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      @snopy_16
      Hallo, ich hab deinen Post gerade erst gesehen. Das ist ein Fehler, der so nicht vorkommen sollte. Ich benötige mehr Infos. Kommt der Fehler ständig (im Takt des Intervalls) oder nur sporadisch? Hast Du eine Beta Firmware Version auf der Fritzbox?
      Kannst Du unter Instanzen die Protokollstufe auf debug stellen und dann vom Start des Adapters bis zum Fehler das Log einmal posten. Bitte vorher nach fb-checkpresence filtern und ggfs. Daten anonymisieren, die du nicht posten möchtest.
      • afuerhoffA afuerhoff
        @snopy_16
        Snopy_16
        @afuerhoff Danke, aber die Fehler sind jetzt weg 😀
