  3. Einsteigerfragen
  4. IOBroker + Zigbee 3.0 USB Dongle Plus
7 Beiträge 5 Kommentatoren 835 Aufrufe 4 Beobachtet
  • H Offline
    hpgo
    wie beschrieben habe ich mir einen neuen IOBroker Docker Container erstellt und den Zigbee Adapter installiert.
    Konfiguriert habe ich alles so wie in dem Video hier
    Bei mir werden allerdings unter Instanzen nicht die drei Hacken grün siehe Bildiobroker instanz.png
    Mit iobroker logs --watch ekomme ich den log
    root@RPi4:/opt/iobroker# iobroker logs --watch
    2022-12-23 20:59:35.766  - info: admin.0 (733) ==> Connected system.user.admin from ::ffff:192.168.178.32
    2022-12-23 20:59:35.918  - error: zigbee.0 (31060) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2022-12-23 20:59:56.898  - info: host.RPi4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2022-12-23 20:59:56.909  - info: zigbee.0 (31060) Got terminate signal TERMINATE_YOURSELF
    2022-12-23 20:59:56.910  - info: host.RPi4 stopInstance system.adapter.zigbee.0 send kill signal
    2022-12-23 20:59:57.032  - info: admin.0 (733) <== Disconnect system.user.admin from ::ffff:192.168.178.32
    2022-12-23 20:59:56.913  - info: zigbee.0 (31060) cleaned everything up...
    2022-12-23 20:59:56.922  - info: zigbee.0 (31060) Zigbee: disabling joining new devices.
    2022-12-23 20:59:57.052  - warn: zigbee.0 (31060) Failed to stop zigbee during startup
    2022-12-23 20:59:57.053  - info: zigbee.0 (31060) terminating
    2022-12-23 20:59:57.054  - info: zigbee.0 (31060) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-12-23 20:59:57.609  - info: host.RPi4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-12-23 20:59:59.977  - info: host.RPi4 instance system.adapter.zigbee.0 started with pid 31113
    2022-12-23 21:00:04.251  - info: zigbee.0 (31113) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.23
    2022-12-23 21:00:04.387  - info: zigbee.0 (31113) Starting Zigbee  npm ...
    2022-12-23 21:00:04.711  - error: zigbee.0 (31113) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
    2022-12-23 21:00:04.712  - error: zigbee.0 (31113) Failed to start Zigbee
    2022-12-23 21:00:04.713  - error: zigbee.0 (31113) Error herdsman start
    2022-12-23 21:00:04.902  - info: zigbee.0 (31113) Installed Version: iobroker.zigbee@1.7.6
    2022-12-23 21:00:14.718  - info: zigbee.0 (31113) Try to reconnect. 1 attempts left
    2022-12-23 21:00:14.720  - info: zigbee.0 (31113) Starting Zigbee  npm ...
    2022-12-23 21:00:14.739  - error: zigbee.0 (31113) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
    2022-12-23 21:00:14.742  - error: zigbee.0 (31113) Failed to start Zigbee
    2022-12-23 21:00:14.743  - error: zigbee.0 (31113) Error herdsman start
    2022-12-23 21:00:14.767  - info: zigbee.0 (31113) Installed Version: iobroker.zigbee@1.7.6
    2022-12-23 21:22:08.531  - info: admin.0 (733) ==> Connected system.user.admin from ::ffff:192.168.178.32
    2022-12-23 21:22:08.725  - error: zigbee.0 (31113) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
    2022-12-23 21:22:22.343  - info: host.RPi4 stopInstance system.adapter.zigbee.0 (force=false, process=true)
    2022-12-23 21:22:22.352  - info: host.RPi4 stopInstance system.adapter.zigbee.0 send kill signal
    2022-12-23 21:22:22.351  - info: zigbee.0 (31113) Got terminate signal TERMINATE_YOURSELF
    2022-12-23 21:22:22.476  - info: admin.0 (733) <== Disconnect system.user.admin from ::ffff:192.168.178.32
    2022-12-23 21:22:22.355  - info: zigbee.0 (31113) cleaned everything up...
    2022-12-23 21:22:22.362  - info: zigbee.0 (31113) Zigbee: disabling joining new devices.
    2022-12-23 21:22:22.515  - warn: zigbee.0 (31113) Failed to stop zigbee during startup
    2022-12-23 21:22:22.516  - info: zigbee.0 (31113) terminating
    2022-12-23 21:22:22.517  - info: zigbee.0 (31113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-12-23 21:22:23.064  - info: host.RPi4 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-12-23 21:22:25.398  - info: host.RPi4 instance system.adapter.zigbee.0 started with pid 32196
    2022-12-23 21:22:29.533  - info: zigbee.0 (32196) starting. Version 1.7.6 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.23
    2022-12-23 21:22:29.711  - info: zigbee.0 (32196) Starting Zigbee  npm ...
    2022-12-23 21:22:30.060  - error: zigbee.0 (32196) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
    2022-12-23 21:22:30.061  - error: zigbee.0 (32196) Failed to start Zigbee
    2022-12-23 21:22:30.062  - error: zigbee.0 (32196) Error herdsman start
    2022-12-23 21:22:30.257  - info: zigbee.0 (32196) Installed Version: iobroker.zigbee@1.7.6
    2022-12-23 21:22:40.067  - info: zigbee.0 (32196) Try to reconnect. 1 attempts left
    2022-12-23 21:22:40.068  - info: zigbee.0 (32196) Starting Zigbee  npm ...
    2022-12-23 21:22:40.085  - error: zigbee.0 (32196) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0'"
    2022-12-23 21:22:40.088  - error: zigbee.0 (32196) Failed to start Zigbee
    2022-12-23 21:22:40.090  - error: zigbee.0 (32196) Error herdsman start
    2022-12-23 21:22:40.140  - info: zigbee.0 (32196) Installed Version: iobroker.zigbee@1.7.6
    Würde mich freuen, wenn mir jemand weiterhelfen kann.
    Lg
    Thomas BraunT T GlasfaserG O 5 Antworten Letzte Antwort
    • H hpgo
      Lg
      @hpgo sagte in IOBroker + Zigbee 3.0 USB Dongle Plus:
      root@RPi4
      User anlegen und damit durch das System hoppeln.
      • H hpgo
        Lg
        TT-Tom
        kann sein, dass dort das Hochkomma am Ende falsch ist.
        Gruß Tom
        Public Transport
        NSPanel Adapter Wiki
        • H hpgo
          Lg
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          Docker Container
          Standard Frage :
          Stick zum Container durchgereicht !?
          H 1 Antwort Letzte Antwort
          • H hpgo
            Lg
            @hpgo
            Wenn der Stick durchgereicht wurde:
            ls -lA /dev/serial/by-id/
            anschauen.
            • H hpgo
              Lg
              O Offline
              O Offline
              ObiTobi
              @hpgo said in IOBroker + Zigbee 3.0 USB Dongle Plus:
              Und wie hast Du ihn gebaut? (Parameter)
              • GlasfaserG Glasfaser
                Docker Container
                Standard Frage :
                hpgo
                schrieb am zuletzt editiert von hpgo
                @glasfaser
                tja gute Frage, wäre nie darauf gekommen das zu kontrollieren - muss mal schauen wie das geht.
                Danke, hilft mir schon mal weiter
                Edit: hab das hier gefunden und werde es morgen durchackern - heute bin, eich einfach viel zu müde.
                Nochmals danke, melde mich morgen, wenn ich darf.
