  4. Admin GUI crashes JS Controller
9 Beiträge 3 Kommentatoren 557 Aufrufe 3 Beobachtet
  • H Offline
    hioniq42
    Systemdata Bitte Ausfüllen
    Hardwaresystem: VM on Synology
    Arbeitsspeicher: 8GB
    Festplattenart: HDD
    Betriebssystem: Ubuntu
    Node-Version: 16.18.1
    Nodejs-Version: 16.18.1
    NPM-Version: 8.19.2
    Installationsart: Skript
    Image genutzt: Nein
    Dear Community,
    I recently updated my system to the latest versions of node, nodeJS, JS-Controller, NPM etc. Since then, whenever I start the admin interface in any browser, it crashes the JS controller. The core system comes up again and everything else works fine (Scripts, IOT Integration, VIS, ...). I tried downgrades of the admin adapter, but it didn't help. I also searched the forum and GitHub but could not find anything similiar. Maybe someone out here has an idea.
    Thank you!
    Florian
    • H hioniq42
      Festplattenart: HDD
      NPM-Version: 8.19.2
      Image genutzt: Nein
      Dear Community,
      Thank you!
      Florian
      @hioniq42
      iobroker stop
      iobroker fix
      iobroker start
      Then please post the output of
      iobroker diag
      H 1 Antwort Letzte Antwort
        @hioniq42
        iobroker stop
        iobroker fix
        iobroker start
        iobroker diag
        hioniq42
        Thank you for the quick response. I did the stop/fix/start several times before with no luck. This is the output from the diganose command (with stop/fix/start executed right before). Problem is still the same.
                                v.2022-12-13
        Operatingsystem:        Ubuntu 22.04.1 LTS
        Installation:           microsoft
        Timezone:               Europe/Berlin
        User-ID:                1000
        X-Server:               true
        Pending OS-Updates:     0
        Nodejs-Installation:    /usr/bin/nodejs         v16.18.1
                                /usr/bin/node           v16.18.1
                                /usr/bin/npm            8.19.2
        ioBroker Core:          js-controller           4.0.24
                                admin                   6.2.23
        Objects type: jsonl
        States  type: jsonl
        Pending iob updates:    1
        Active repo(s): stable
        Objects:                78677
        States:                 73856
        Size of iob-Database:
        48M     /opt/iobroker/iobroker-data/objects.jsonl
        17M     /opt/iobroker/iobroker-data/states.jsonl
        I also had a look into the log messages right after calling the admin UI but for me there is no meaningful information except the fact that everything falls into pieces:
        2022-12-19 21:34:45.885  - info: unifi.0 (387391) cleaned everything up...
        2022-12-19 21:34:45.899  - info: fullybrowser.0 (388048) cleaned everything up...
        2022-12-19 21:34:45.911  - info: javascript.0 (384789) Stop script script.js.Aktienkurse
        2022-12-19 21:34:45.882  - error: sonnen.0 (386920) States database error: read ECONNRESET
        2022-12-19 21:34:45.894  - info: admin.1 (384406) terminating http server on port 8080
        2022-12-19 21:34:45.901  - info: simple-api.0 (388366) terminating http server on port 8087
        2022-12-19 21:34:45.931  - info: info.0 (387970) cleaned everything up...
        2022-12-19 21:34:45.923  - info: hm-rpc.2 (386075) binrpc -> 192.168.x.x:8701/ init ["xmlrpc_bin://192.168.x.x:12001",""]
        2022-12-19 21:34:45.900  - info: hm-rpc.3 (386737) binrpc -> 192.168.x.x:2001/ init ["xmlrpc_bin://192.168.x.x:12002",""]
        2022-12-19 21:34:45.903  - error: admin.2 (384556) States database error: read ECONNRESET
        2022-12-19 21:34:45.943  - error: backitup.0 (388528) States database error: read ECONNRESET
        I was wondering if there is a way to change the debug level of an instance through CLI?
        thank you so far
        Florian
        • H hioniq42
                                  v.2022-12-13
          User-ID:                1000
          X-Server:               true
                                  /usr/bin/npm            8.19.2
                                  admin                   6.2.23
          Objects type: jsonl
          States  type: jsonl
          Objects:                78677
          States:                 73856
          thank you so far
          Florian
          @hioniq42 warum jetzt hier auf englisch?
            hioniq42
            Entschuldigung, das war reine Gewohnheit. Weiter auf deutsch :)
            @Thomas-Braun
            Mir ist im System-Log (/var/logs/syslog) noch folgendes aufgefallen:
            21:34:45 iobroker systemd[1]: iobroker.service: Main process exited, code=dumped, status=11/SEGV
            • H hioniq42
              @Thomas-Braun
              hioniq42
              So, ein paar neue Erkenntnisse, nachdem ich mich durch die Coredumps gearbeitet habe, wo folgendes zu finden ist:
              ProblemType: Crash
              Architecture: amd64
              Date: Tue Dec 20 11:07:29 2022
              DistroRelease: Ubuntu 22.04
              ExecutablePath: /usr/bin/node
              ExecutableTimestamp: 1667561607
              ProcCmdline: iobroker.js-controller
              ProcEnviron: Error: [Errno 13] Permission denied: 'environ'
              ProcMaps: Error: [Errno 13] Permission denied: 'maps'
              ProcStatus:
              Dass hier zwei Berechtigungsprobleme (Zeile 8&9) bestehen, überrascht mich. Müsste das nicht genau mit iobroker fix behoben werden?
              • H hioniq42
                ProblemType: Crash
                Architecture: amd64
                ProcStatus:
                @hioniq42 sagte in Admin GUI crashes JS Controller:
                überrascht mich.
                Mich nicht, wenn da mit sudo und/oder vollem root-Account herumgefuhrwerkt wurde.
                  überrascht mich.
                  hioniq42
                  Dafür habe ich einen Standard-User "iobroker" und sudo nur bei absoluter Notwendigkeit. Und ist doch auch etwas seltsam, dass dann nur bei der Admin GUI Probleme auftreten, sonst aber alles sauber läuft.
                  • H hioniq42
                    der Systemuser heisst bereits iobroker
