  4. Iobroker JavaScript MQTT Fehler
7 Beiträge 4 Kommentatoren 363 Aufrufe 2 Beobachtet
  • K Offline
    karloslb
    schrieb am zuletzt editiert von karloslb
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Windows 10
    Betriebssystem: Ubuntu als Subsystem
    Node-Version: 14.21.1
    NPM-Version: 6.14.17
    ich habe ein Script, das im Visual Studio Code funktioniert.
    code_tvar dgram = require("dgram");
    var CronJob = require('cron').CronJob;
    const mqtt = require('mqtt');
    var client = dgram.createSocket("udp4");
    var PORT = process.env.UDP_PORT||"4000";
    var IPadress = process.env.UDP_IP ||"192.168.178.90";
    var ID = process.env.RL_ID||"002D001E47435719";
    var IDSZ = "002D001E47435719";
    var PWD = "1111"
    var MQTTserver = process.env.MQTT_IP ||"192.168.178.54";
    var MQTTPort = process.env.MQTT_PORT ||"1883";
    var mqtt_temp_message = "";
    var header  = Buffer.from(
            [ 0xFD, 0xFD,   // Beginn des Pakets
             0x02,          // Protokolltyp
             0x10,          // ID Blockgroesse
    var IDbuf = Buffer.from(ID);
    var PWDsizebuf = Buffer.from([0x04]);
    var PWDbuf = Buffer.from(PWD);
    var writeFlevelbuf = Buffer.from('init');
    var writeModebuf = Buffer.from('init');
    const clientId = `mqtt_${Math.random().toString(16).slice(3)}`;
    var mqtt_url = 'mqtt://${MQTTServer}:${MQTTport}';
    //console.log(mqtt_url);
    const mqtt_client  = mqtt.connect(mqtt_url, clientId);
    mqtt_client.on('connect', function(){
    	console.log("connected to mqtt");
    	mqtt_client.subscribe('rl/Bathroom/cmnd/fan_level');
    	mqtt_client.subscribe('rl/Bathroom/cmnd/mode');
    mqtt_client.on('message', function(topic, message){
    	//message ist Buffer
    	//console.log(topic);
    	if(topic.includes("fan_level")){
    		// construct fan_level write message
    		var dataarr = new Uint8Array(1);
    		dataarr[0] = parseInt(message.toString());
    		var writeFlevelDatabuf = Buffer.from([0x02, 0x02]);
    		writeFlevelbuf = Buffer.concat([header, IDbuf, PWDsizebuf, PWDbuf, writeFlevelDatabuf, Buffer.from(dataarr.buffer)]);
    		var checksum_writeFlevel = calcchecksum(writeFlevelbuf);
    		writeFlevelbuf = Buffer.concat([writeFlevelbuf,checksum2buffer(checksum_writeFlevel)]);
    		console.log(writeFlevelbuf);
    		client.send(writeFlevelbuf, PORT, IPadress);
    		console.log("fan level case");
    	else if(topic.includes("mode")){
    		// construct Mode write message
    		var error = 0;
    		var modedataarr = new Uint8Array(1);
                    if(message.toString() == "ventilation"){modedataarr[0] = 0;}
                    else if(message.toString() == "regeneration"){modedataarr[0] = 1;}
                    else if(message.toString() == "supplyair"){modedataarr[0] = 2;}
    		else {
    			console.log("bad mode command", message.toString());
    			error = 1;
    		if(error == 0){
    			var writeModeDatabuf = Buffer.from([0x02, 0xB7]);
    			writeModebuf = Buffer.concat([header, IDbuf, PWDsizebuf, PWDbuf, writeModeDatabuf, Buffer.from(modedataarr.buffer)]);
    			var checksum_writeMode = calcchecksum(writeModebuf);
    			writeModebuf = Buffer.concat([writeModebuf,checksum2buffer(checksum_writeMode)]);
    			console.log(writeModebuf);
    			client.send(writeModebuf, PORT, IPadress);
    		console.log("mode case");
    	else{
    		console.log(message.toString())
    // UDP
    client.on("message", function(message, rinfo) {
        	console.log("received: ", message, rinfo);
    	datalen = rinfo.size - 24 - message.readInt8(20);
    	databuf = message.subarray(20+message.readInt8(20)+2, -2) //20 byte upfront, pwd length, pwd, func
    	for (let i=0; i < datalen; i+=2){
    		console.log("data = ", databuf[i]);
    		switch(databuf[i]){
    			case(1):
    				console.log("RL ist  ", databuf[i+1]?"an":"aus");
    				mqtt_client.publish('/rl/Bathroom/status', databuf[i+1]?"on":"off", { qos: 0, retain: true });
    				break;
    			case(2):
    				console.log("Lueftungsstufe ist ", databuf[i+1]);
    				mqtt_client.publish('/rl/Bathroom/fan_level', databuf[i-1]?databuf[i+1].toString():"0", { qos: 0, retain: true });
    				break;
    			case(37): //0x25
    				console.log("Feuchtigkeit Bad ist ", databuf[i+1]);
    				mqtt_client.publish('/rl/Bathroom/humidity', databuf[i+1].toString(), { qos: 0, retain: true });
    				break;
    			case(183): //0xB7
    				if(databuf[i+1].toString() == "0"){mqtt_temp_message = "ventilation";}
    				else if(databuf[i+1].toString() == "1"){mqtt_temp_message = "regeneration";}
    				else if(databuf[i+1].toString() == "2"){mqtt_temp_message = "supplyair";}
    				else {mqtt_temp_message = "error"+ databuf[i+1].toString();}
    				mqtt_client.publish('/rl/Bathroom/mode', mqtt_temp_message, { qos: 0, retain: true });
                                    break;
    			default:
    				console.log("unknown ID");
    				console.log(message, rinfo)
    client.bind(PORT);
    function calcchecksum(intbuff){
    	let checksum = 0;
    	for (let i = 2; i < intbuff.length; i++) {
      		// console.log(newbuff[i]);
      		checksum+=intbuff[i];
    	//console.log("checksum = " , checksum);
    	return checksum;
    function checksum2buffer(checksum){
    	const arr = new Uint8Array(2);
    	arr[0] = checksum%256;
    	arr[1] = checksum/256;
    	return Buffer.from(arr.buffer);
    // setup UDP messages
    //var Databuf = Buffer.from([0x01, 0xb9, 0x92, 0xa3]);
    var Databuf = Buffer.from([0x01, 0x01, 0x02, 0x25, 0xB7]);
    var list = [header, IDbuf, PWDsizebuf, PWDbuf, Databuf];
    var intbuff = Buffer.concat(list);
    //calculate checksum
    let checksum = calcchecksum(intbuff);
    const checksumbuff = Buffer.from(arr.buffer);
    var list2 = [intbuff,checksum2buffer(checksum)];
    var getbuff = Buffer.concat(list2);
    console.log(getbuff);
    // <Buffer fd fd 02 10 30 30 34 41 30 30 32 45 34 33 35 33 35 33 30 42 04 31 31 31 31 01 01 02 de 00>
    var job = new CronJob('*/10 * * * * *', function() {
    	client.send(getbuff, PORT, IPadress);
     	console.log('You will see this message every second');
    }, null, true, 'Europe/Berlin');
    job.start();
    //from App
    //fd fd 02 10 30 30 34 45 30 30 33 35 34 33 35 33 35 33 30 42 04 31 31 31 31 01 b9 92 a3 13 06
    //fd fd 02 10 30 30 34 41 30 30 32 45 34 33 35 33 35 33 30 42 04 31 31 31 31 01 b9 92 a3 1e 06
    ext
    Ich habe versucht das Script mit dem JS Adpater von Iobroker zu starten.
    Leider funktioniert es nicht.
    Das Problem ist folgendes: in der Zeile 31
    bekomme ich folgende Meldung:
    Property 'connect' does not exist on type 'typeof import("mqtt")'
    Kann mir jemand bitte weiter helfen?
    • CinimodC Offline
      CinimodC Offline
      Cinimod
      @karloslb
      Bisschen mehr Infos währen hilfreich um dir zu helfen
      K 1 Antwort Letzte Antwort
      • CinimodC Cinimod
        @karloslb
        karloslb
        @cinimod sorry, bin neu im Forum. Es hat ein wenig gedauert.
        HomoranH CinimodC 2 Antworten Letzte Antwort
        • K karloslb
          @karloslb hilft das?
          https://github.com/ioBroker/ioBroker.javascript/blob/master/docs/en/javascript.md
          • K karloslb
            CinimodC Offline
            CinimodC Offline
            Cinimod
            @karloslb
            Alles gut, war nicht bös gemeint. Es war nur nichts zum auswerten da 😊
            Ich bin da leider raus.
            • K karloslb
              var PWD = "1111"
              		var error = 0;
              		else {
              			error = 1;
              		if(error == 0){
              	else{
              // UDP
              		switch(databuf[i]){
              			case(1):
              				break;
              			case(2):
              				break;
              			case(37): //0x25
              				break;
              			case(183): //0xB7
                                              break;
              			default:
              client.bind(PORT);
              	let checksum = 0;
              	return checksum;
              job.start();
              //from App
              ext
              @karloslb sagt: Das Problem ist folgendes: in der Zeile 31
              Ignorieren! Der Javascript-Editor meckert bei Attributen, die er nicht kennt.
                karloslb
                @homoran sagte in Iobroker JavaScript MQTT Fehler:
                Nein, leider nicht. Ich bin nicht so fortgeschritten.
