  4. Zigbee 1.8.7 errors im Log
4 Beiträge 2 Kommentatoren 595 Aufrufe 2 Beobachtet
  • ESP8266E Offline
    ESP8266E Offline
    ESP8266
    schrieb am zuletzt editiert von ESP8266
    Habe den Zigbee Adapter vor drei Tagen auf 1.8.7 geupgradet.
    Jetzt kommen immer mal errors im Log.
    zigbee.0
    	2022-12-05 14:00:03.342	error	Error 225 on send command to 0x847127fffe8f3279. Error: Error: Command 0x847127fffe8f3279/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 14:00:00.640	error	Error 225 on send command to 0x84fd27fffe93d9f2. Error: Error: Command 0x84fd27fffe93d9f2/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 13:59:43.028	error	Error 225 on send command to 0x00158d00053cc50d. Error: Error: Command 0x00158d00053cc50d/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 13:59:42.961	error	Error 225 on send command to 0x00158d00053c3cf6. Error: Error: Command 0x00158d00053c3cf6/1 genOnOff.off({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 13:59:11.655	error	Error 225 on send command to 0x84fd27fffe9b3baf. Error: Error: Command 0x84fd27fffe9b3baf/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    	2022-12-05 13:59:11.591	error	Error 225 on send command to 0x84fd27fffe93d9f2. Error: Error: Command 0x84fd27fffe93d9f2/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    zigbee.0
    zigbee.0
    zigbee.0
    	2022-12-05 13:58:59.150	error	Error 225 on send command to 0xbc33acfffee60b3b. Error: Error: Command 0xbc33acfffee60b3b/1 genOnOff.on({}, {"sendWhen":"immediate","timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null,"writeUndiv":false}) failed (Data request failed with error: 'MAC channel access failure' (225)) at ZStackAdapter.sendZclFrameToEndpointInternal (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:415:23) at Queue.executeNext (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
    Obwohl soweit alles zu funktionieren scheint. Update: Nein es wir verzögert geschaltet.
    Stick wurde schon mal getrennt.
    Gerade festgestellt, auch bei der Version 1.8.3. das gleiche Problem.
    Langsame Reaktion beim ein/auschalten der Lampen, dabei kommt es zu den errors.
    Scheinbar war das System durcheinander.....derzeit keine errrors mehr im Log.
    • ESP8266E ESP8266
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @esp8266 sagte in Zigbee 1.8.7 errors im Log:
      Das system war nicht durcheinander. Das System hat Dir gemeldet das es Probleme mit dem Funknetz hat.
      Siehe auch:
      https://www.zigbee2mqtt.io/guide/faq/#common-error-codes (leider nur auf englisch)
      Je nach der Funkauslastung bei Dir kann der Effekt also erneut auftreten.
      A.
      ESP8266E 1 Antwort Letzte Antwort
      • AsgothianA Asgothian
        Siehe auch:
        A.
        ESP8266E Offline
        ESP8266E Offline
        ESP8266
        @asgothian , eventuell muss ich mal den Kanal wechseln. Danke für den Hinweis....werde mal in der Fritte die Wlan Nachbarkanäle beobachten.
        • ESP8266E ESP8266
          AsgothianA Offline
          AsgothianA Offline
          Asgothian
          @esp8266
          Bitte auch andere 2.4 GHz Störquellen betrachten:
          • DECT Telefone
          • Proprietäre 2.4 GHz Kopfhörer / Tastatur/Maus Kombinationen etc.
          A.
