  3. Einsteigerfragen
  4. Installation
  5. iobroker auf synology kein Startbildschirm
Geplant Angeheftet Gesperrt Verschoben Installation
21 Beiträge 4 Kommentatoren 1.9k Aufrufe 3 Beobachtet
  • CodierknechtC Codierknecht
    Nagelneuer Container - Host-Mode - ohne weiteres Gedöns
    root@iobroker:/opt/iobroker# iobroker logs --watch
    2022-12-21 21:28:16.428  - info: host.iobroker iobroker.js-controller version 4.0.23 js-controller starting
    2022-12-21 21:28:16.433  - info: host.iobroker Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-12-21 21:28:16.434  - info: host.iobroker hostname: iobroker, node: v16.19.0
    2022-12-21 21:28:16.435  - info: host.iobroker ip addresses: 172.17.0.1 fe80::42:b7ff:fe43:c18e 192.168.178.5 fdc0:aba5:3373:431d:211:
    32ff:fe2c:a603 2a00:6020:4884:7b00:211:32ff:fe2c:a603 fe80::211:32ff:fe2c:a603 fe80::c16:f8ff:fe40:ef37 fe80::c021:69ff:febe:5d5e fe80
    ::50cd:cfff:fe39:3ae6
    2022-12-21 21:28:16.798  - info: host.iobroker connected to Objects and States
    2022-12-21 21:28:16.817  - info: host.iobroker Node.js version has changed from unknown to 16.19.0
    2022-12-21 21:28:16.863  - info: host.iobroker added notifications configuration of host
    2022-12-21 21:28:17.043  - info: host.iobroker 3 instances found
    2022-12-21 21:28:17.052  - info: host.iobroker starting 3 instances
    2022-12-21 21:28:17.286  - info: host.iobroker instance system.adapter.admin.0 started with pid 514
    2022-12-21 21:28:17.439  - info: host.iobroker Created UUID: 835f04f8-c3e6-4fc4-85d7-9c813ad7ec7a
    2022-12-21 21:28:19.466  - info: admin.0 (514) starting. Version 6.2.23 in /opt/iobroker/node_modules/iobroker.admin, node: v16.19.0,
    js-controller: 4.0.23
    2022-12-21 21:28:19.511  - info: admin.0 (514) requesting all states
    2022-12-21 21:28:19.512  - info: admin.0 (514) requesting all objects
    2022-12-21 21:28:19.595  - info: admin.0 (514) received all objects
    2022-12-21 21:28:19.628  - info: admin.0 (514) Request actual repository...
    2022-12-21 21:28:19.639  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
    2022-12-21 21:28:19.672  - info: admin.0 (514) http server listening on port 8081
    2022-12-21 21:28:19.673  - info: admin.0 (514) Use link "http://localhost:8081" to configure.
    2022-12-21 21:28:19.682  - info: admin.0 (514) socket.io server listening on port 8081
    2022-12-21 21:28:19.774  - warn: admin.0 (514) Repository cannot be read: Active repo - stable
    2022-12-21 21:28:19.775  - warn: admin.0 (514) Active repository "stable" cannot be read
    2022-12-21 21:28:21.084  - info: host.iobroker instance system.adapter.discovery.0 started with pid 529
    2022-12-21 21:28:22.242  - info: discovery.0 (529) starting. Version 3.0.3 in /opt/iobroker/node_modules/iobroker.discovery, node: v16
    GlasfaserG Offline
    GlasfaserG Offline
    Glasfaser
    @codierknecht sagte in iobroker auf synology kein Startbildschirm:
    Warum wieso Sie bei dir ist ..im Host ... keine Ahnung .
    Habe aber zu dieser IP was gefunden :
    https://forum.iobroker.net/post/728008
