  4. SD-Karte läuft im Verzeichnis /dev/root voll
28 Beiträge 5 Kommentatoren 4.9k Aufrufe 4 Beobachtet
    @kenji
    Der zweite Befehl greift offenbar zu kurz.
    Dann mal mehr Output:
    tail -n 300 /var/log/syslog.1
    Und mach bitte dein puTTY-Fenster größer.
    KenjiK Offline
    KenjiK Offline
    Kenji
    @thomas-braun Ich hoffe das ist groß genug bin grade am Laptop.
    pi@raspberrypi:~ $ tail -n 300 /var/log/syslog.1
    Dec  6 12:17:11 raspberrypi kernel: [    3.025544]     splash
    Dec  6 12:17:11 raspberrypi kernel: [    3.025557]   with environment:
    Dec  6 12:17:11 raspberrypi kernel: [    3.025569]     HOME=/
    Dec  6 12:17:11 raspberrypi kernel: [    3.025581]     TERM=linux
    Dec  6 12:17:11 raspberrypi kernel: [    4.489622] NET: Registered PF_INET6 protocol family
    Dec  6 12:17:11 raspberrypi kernel: [    4.491382] Segment Routing with IPv6
    Dec  6 12:17:11 raspberrypi kernel: [    4.491426] In-situ OAM (IOAM) with IPv6
    Dec  6 12:17:11 raspberrypi kernel: [    6.640012] fuse: init (API version 7.34)
    Dec  6 12:17:11 raspberrypi kernel: [    6.862416] i2c_dev: i2c /dev entries driver
    Dec  6 12:17:11 raspberrypi kernel: [    7.491840] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
    Dec  6 12:17:11 raspberrypi kernel: [   11.657586] mc: Linux media interface: v0.10
    Dec  6 12:17:11 raspberrypi kernel: [   11.795183] videodev: Linux video capture interface: v2.00
    Dec  6 12:17:11 raspberrypi kernel: [   11.843047] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   11.857533] bcm2835_audio bcm2835_audio: card created with 8 channels
    Dec  6 12:17:11 raspberrypi kernel: [   11.948828] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   11.957733] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   11.958590] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    Dec  6 12:17:11 raspberrypi kernel: [   11.958616] [vc_sm_connected_init]: start
    Dec  6 12:17:11 raspberrypi kernel: [   11.959252] [vc_sm_connected_init]: installed successfully
    Dec  6 12:17:11 raspberrypi kernel: [   11.971423] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.024522] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.024757] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.024761] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.095319] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.112372] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    Dec  6 12:17:11 raspberrypi kernel: [   12.112909] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    Dec  6 12:17:11 raspberrypi kernel: [   12.113419] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    Dec  6 12:17:11 raspberrypi kernel: [   12.113756] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    Dec  6 12:17:11 raspberrypi kernel: [   12.113787] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.113811] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.113834] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.113870] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.117721] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
    Dec  6 12:17:11 raspberrypi kernel: [   12.118190] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
    Dec  6 12:17:11 raspberrypi kernel: [   12.118581] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
    Dec  6 12:17:11 raspberrypi kernel: [   12.118912] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
    Dec  6 12:17:11 raspberrypi kernel: [   12.118942] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.118967] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.118989] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.119011] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    Dec  6 12:17:11 raspberrypi kernel: [   12.119185] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    Dec  6 12:17:11 raspberrypi kernel: [   12.125528] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.134051] rpivid feb10000.codec: Device registered as /dev/video19
    Dec  6 12:17:11 raspberrypi kernel: [   12.138147] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.154714] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    Dec  6 12:17:11 raspberrypi kernel: [   12.154765] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    Dec  6 12:17:11 raspberrypi kernel: [   12.157966] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    Dec  6 12:17:11 raspberrypi kernel: [   12.158014] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    Dec  6 12:17:11 raspberrypi kernel: [   12.162789] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    Dec  6 12:17:11 raspberrypi kernel: [   12.169866] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    Dec  6 12:17:11 raspberrypi kernel: [   12.169915] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    Dec  6 12:17:11 raspberrypi kernel: [   12.177384] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
    Dec  6 12:17:11 raspberrypi kernel: [   12.177432] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
    Dec  6 12:17:11 raspberrypi kernel: [   12.187919] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
    Dec  6 12:17:11 raspberrypi kernel: [   12.187968] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
    Dec  6 12:17:11 raspberrypi kernel: [   12.417865] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    Dec  6 12:17:11 raspberrypi kernel: [   12.424127] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    Dec  6 12:17:11 raspberrypi kernel: [   12.424163] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    Dec  6 12:17:11 raspberrypi kernel: [   12.428048] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    Dec  6 12:17:11 raspberrypi kernel: [   16.039488] uart-pl011 fe201000.serial: no DMA platform data
    Dec  6 12:17:11 raspberrypi kernel: [   16.649362] 8021q: 802.1Q VLAN Support v1.8
    Dec  6 12:17:11 raspberrypi kernel: [   17.115931] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    Dec  6 12:17:11 raspberrypi kernel: [   17.129574] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    Dec  6 12:17:11 raspberrypi dhcpcd[355]: forked to background, child pid 466
    Dec  6 12:17:11 raspberrypi systemd[1]: Started DHCP Client Daemon.
    Dec  6 12:17:11 raspberrypi rngd[471]: rngd 2.2 starting up...
    Dec  6 12:17:11 raspberrypi systemd[1]: Started LSB: rng-tools (Debian variant).
    Dec  6 12:17:11 raspberrypi rngd[471]: entropy feed to the kernel ready
    Dec  6 12:17:12 raspberrypi kernel: [   17.908243] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
    Dec  6 12:17:12 raspberrypi udisksd[363]: udisks daemon version 2.9.2 starting
    Dec  6 12:17:13 raspberrypi systemd[1]: Finished Check for glamor.
    Dec  6 12:17:13 raspberrypi systemd[1]: Finished Check for v3d driver.
    Dec  6 12:17:13 raspberrypi dhcpcd[466]: eth0: waiting for carrier
    Dec  6 12:17:13 raspberrypi kernel: [   19.117523] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    Dec  6 12:17:13 raspberrypi kernel: [   19.119139] bcmgenet fd580000.ethernet eth0: Link is Down
    Dec  6 12:17:13 raspberrypi dphys-swapfile[344]: want /var/swap=100MByte, restricting to 50% of remaining disk size: 12MBytes, checking existing: deleting wrong size file (26214400), generating swapfile ... of 12MBytes
    Dec  6 12:17:13 raspberrypi systemd[1]: Finished dphys-swapfile - set up, mount/unmount, and delete a swap file.
    Dec  6 12:17:13 raspberrypi kernel: [   19.172313] Adding 12284k swap on /var/swap.  Priority:-2 extents:1 across:12284k SSFS
    Dec  6 12:17:13 raspberrypi rpi-eeprom-update[359]: Skipping automatic bootloader upgrade. current 1599135103 >= min 1599135103
    Dec  6 12:17:13 raspberrypi systemd[1]: Started User Login Management.
    Dec  6 12:17:13 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.systemd1'
    Dec  6 12:17:13 raspberrypi systemd[1]: Started Telephony service.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Successfully called chroot().
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Successfully dropped remaining capabilities.
    Dec  6 12:17:13 raspberrypi wpa_supplicant[364]: Successfully initialized wpa_supplicant
    Dec  6 12:17:13 raspberrypi systemd[1]: Started Connection service.
    Dec  6 12:17:13 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
    Dec  6 12:17:13 raspberrypi systemd[1]: Started DUN service.
    Dec  6 12:17:13 raspberrypi systemd[1]: Started WPA supplicant.
    Dec  6 12:17:13 raspberrypi systemd[1]: Reached target Network.
    Dec  6 12:17:13 raspberrypi systemd[1]: Starting CUPS Scheduler...
    Dec  6 12:17:13 raspberrypi systemd[1]: Started ioBroker Server.
    Dec  6 12:17:13 raspberrypi connmand[343]: Connection Manager version 1.36
    Dec  6 12:17:13 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
    Dec  6 12:17:13 raspberrypi systemd[1]: Condition check resulted in fast remote file copy program daemon being skipped.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: No service file found in /etc/avahi/services.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: New relevant interface lo.IPv6 for mDNS.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: New relevant interface lo.IPv4 for mDNS.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Network interface enumeration completed.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Registering new address record for ::1 on lo.*.
    Dec  6 12:17:13 raspberrypi avahi-daemon[340]: Registering new address record for 127.0.0.1 on lo.IPv4.
    Dec  6 12:17:13 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
    Dec  6 12:17:13 raspberrypi systemd[1]: Starting Permit User Sessions...
    Dec  6 12:17:13 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
    Dec  6 12:17:13 raspberrypi systemd[1]: Finished Permit User Sessions.
    Dec  6 12:17:13 raspberrypi systemd[1]: Starting Light Display Manager...
    Dec  6 12:17:13 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
    Dec  6 12:17:14 raspberrypi udisksd[363]: failed to load module crypto: libbd_crypto.so.2: cannot open shared object file: No such file or directory
    Dec  6 12:17:14 raspberrypi udisksd[363]: failed to load module mdraid: libbd_mdraid.so.2: cannot open shared object file: No such file or directory
    Dec  6 12:17:14 raspberrypi kernel: [   20.137426] Bluetooth: Core ver 2.22
    Dec  6 12:17:14 raspberrypi kernel: [   20.137494] NET: Registered PF_BLUETOOTH protocol family
    Dec  6 12:17:14 raspberrypi kernel: [   20.137501] Bluetooth: HCI device and connection manager initialized
    Dec  6 12:17:14 raspberrypi kernel: [   20.137516] Bluetooth: HCI socket layer initialized
    Dec  6 12:17:14 raspberrypi kernel: [   20.137525] Bluetooth: L2CAP socket layer initialized
    Dec  6 12:17:14 raspberrypi kernel: [   20.137543] Bluetooth: SCO socket layer initialized
    Dec  6 12:17:14 raspberrypi avahi-daemon[340]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 970382656.
    Dec  6 12:17:14 raspberrypi udisksd[363]: Failed to load the 'mdraid' libblockdev plugin
    Dec  6 12:17:14 raspberrypi udisksd[363]: Failed to load the 'crypto' libblockdev plugin
    Dec  6 12:17:14 raspberrypi dbus-daemon[342]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.8' (uid=0 pid=363 comm="/usr/libexec/udisks2/udisksd ")
    Dec  6 12:17:14 raspberrypi systemd[1]: Starting Authorization Manager...
    Dec  6 12:17:14 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
    Dec  6 12:17:14 raspberrypi lightdm[520]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
    Dec  6 12:17:14 raspberrypi polkitd[537]: started daemon version 0.105 using authority implementation `local' version `0.105'
    Dec  6 12:17:14 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
    Dec  6 12:17:14 raspberrypi systemd[1]: Started Authorization Manager.
    Dec  6 12:17:15 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 185 (plymouthd).
    Dec  6 12:17:15 raspberrypi systemd[1]: Finished Hold until boot process finishes up.
    Dec  6 12:17:15 raspberrypi systemd[1]: Started Getty on tty1.
    Dec  6 12:17:15 raspberrypi systemd[1]: Reached target Login Prompts.
    Dec  6 12:17:15 raspberrypi systemd[1]: Started Light Display Manager.
    Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: carrier acquired
    Dec  6 12:17:16 raspberrypi systemd[1]: Started Disk Manager.
    Dec  6 12:17:16 raspberrypi kernel: [   22.231956] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    Dec  6 12:17:16 raspberrypi kernel: [   22.231987] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Dec  6 12:17:16 raspberrypi udisksd[363]: Acquired the name org.freedesktop.UDisks2 on the system message bus
    Dec  6 12:17:16 raspberrypi dhcpcd[466]: DUID 00:01:00:01:27:5a:4f:d3:b8:27:eb:5f:f2:dd
    Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: IAID 32:3a:c3:f5
    Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: adding address fe80::f040:6593:7196:c74d
    Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: adding address fd51:42f8:caae:d92e::ff/64
    Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: adding route to fd51:42f8:caae:d92e::/64
    Dec  6 12:17:16 raspberrypi dhcpcd[466]: eth0: probing address 192.168.178.3/24
    Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::f040:6593:7196:c74d.
    Dec  6 12:17:16 raspberrypi avahi-daemon[340]: New relevant interface eth0.IPv6 for mDNS.
    Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Registering new address record for fe80::f040:6593:7196:c74d on eth0.*.
    Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::f040:6593:7196:c74d.
    Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface eth0.IPv6 with address fd51:42f8:caae:d92e::ff.
    Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Registering new address record for fd51:42f8:caae:d92e::ff on eth0.*.
    Dec  6 12:17:16 raspberrypi avahi-daemon[340]: Withdrawing address record for fe80::f040:6593:7196:c74d on eth0.
    Dec  6 12:17:16 raspberrypi connmand[343]: Checking loopback interface settings
    Dec  6 12:17:16 raspberrypi connmand[343]: System hostname is raspberrypi
    Dec  6 12:17:16 raspberrypi systemd[1]: Started CUPS Scheduler.
    Dec  6 12:17:16 raspberrypi systemd[1]: Started Make remote CUPS printers available locally.
    Dec  6 12:17:16 raspberrypi connmand[343]: lo {newlink} index 1 address 00:00:00:00:00:00 mtu 65536
    Dec  6 12:17:16 raspberrypi connmand[343]: lo {newlink} index 1 operstate 0 <UNKNOWN>
    Dec  6 12:17:16 raspberrypi dbus-daemon[342]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.4' (uid=0 pid=343 comm="/usr/sbin/connmand -n ")
    Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {create} index 2 type 1 <ETHER>
    Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {RX} 0 packets 0 bytes
    Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {TX} 3 packets 258 bytes
    Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {update} flags 69699 <UP,RUNNING,LOWER_UP>
    Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {newlink} index 2 address DC:A6:32:3A:C3:F5 mtu 1500
    Dec  6 12:17:16 raspberrypi connmand[343]: eth0 {newlink} index 2 operstate 6 <UP>
    Dec  6 12:17:16 raspberrypi systemd[1]: Starting Hostname Service...
    Dec  6 12:17:16 raspberrypi connmand[343]: Adding interface eth0 [ ethernet ]
    Dec  6 12:17:16 raspberrypi connmand[343]: The name net.connman.vpn was not provided by any .service files
    Dec  6 12:17:16 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.hostname1'
    Dec  6 12:17:16 raspberrypi systemd[1]: Started Hostname Service.
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]: BOOTLOADER: up to date
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:    CURRENT: Do 3. Sep 12:11:43 UTC 2020 (1599135103)
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:     LATEST: Di 26. Apr 10:24:28 UTC 2022 (1650968668)
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:    RELEASE: default (/lib/firmware/raspberrypi/bootloader/default)
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:             Use raspi-config to change the release.
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:   VL805_FW: Dedicated VL805 EEPROM
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:      VL805: up to date
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:    CURRENT: 000138a1
    Dec  6 12:17:17 raspberrypi rpi-eeprom-update[359]:     LATEST: 000138a1
    Dec  6 12:17:17 raspberrypi systemd[1]: Finished Check for Raspberry Pi EEPROM updates.
    Dec  6 12:17:17 raspberrypi systemd[1]: Reached target Multi-User System.
    Dec  6 12:17:17 raspberrypi systemd[1]: Reached target Graphical Interface.
    Dec  6 12:17:17 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
    Dec  6 12:17:17 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
    Dec  6 12:17:17 raspberrypi systemd[1]: Finished Update UTMP about System Runlevel Changes.
    Dec  6 12:17:17 raspberrypi dhcpcd[466]: eth0: soliciting an IPv6 router
    Dec  6 12:17:18 raspberrypi connmand[343]: eth0 {add} address fd51:42f8:caae:d92e::ff/64 label (null) family 10
    Dec  6 12:17:21 raspberrypi systemd[1]: Created slice User Slice of UID 1000.
    Dec  6 12:17:21 raspberrypi systemd[1]: Starting User Runtime Directory /run/user/1000...
    Dec  6 12:17:21 raspberrypi systemd[1]: Finished User Runtime Directory /run/user/1000.
    Dec  6 12:17:21 raspberrypi systemd[1]: Starting User Manager for UID 1000...
    Dec  6 12:17:22 raspberrypi dhcpcd[466]: eth0: using static address 192.168.178.3/24
    Dec  6 12:17:22 raspberrypi avahi-daemon[340]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.178.3.
    Dec  6 12:17:22 raspberrypi avahi-daemon[340]: New relevant interface eth0.IPv4 for mDNS.
    Dec  6 12:17:22 raspberrypi connmand[343]: eth0 {add} address 192.168.178.3/24 label eth0 family 2
    Dec  6 12:17:22 raspberrypi avahi-daemon[340]: Registering new address record for 192.168.178.3 on eth0.IPv4.
    Dec  6 12:17:22 raspberrypi dhcpcd[466]: eth0: adding route to 192.168.178.0/24
    Dec  6 12:17:22 raspberrypi dhcpcd[466]: eth0: adding default route via 192.168.178.1
    Dec  6 12:17:22 raspberrypi connmand[343]: eth0 {add} route 0.0.0.0 gw 192.168.178.1 scope 0 <UNIVERSE>
    Dec  6 12:17:22 raspberrypi avahi-daemon[340]: Registering new address record for 192.168.178.38 on eth0.IPv4.
    Dec  6 12:17:22 raspberrypi systemd-xdg-autostart-generator[618]: Configuration file /etc/xdg/autostart/pprompt.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
    Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} address 192.168.178.38/24 label eth0 family 2
    Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} route 192.168.178.1 gw 0.0.0.0 scope 253 <LINK>
    Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} route 0.0.0.0 gw 192.168.178.1 scope 0 <UNIVERSE>
    Dec  7 15:24:48 raspberrypi connmand[343]: ntp: adjust (jump): +97645.640944 sec
    Dec  7 15:24:48 raspberrypi connmand[343]: Failed to find URL:http://ipv4.connman.net/online/status.html
    Dec  7 15:24:48 raspberrypi connmand[343]: eth0 {add} route 82.165.8.211 gw 192.168.178.1 scope 0 <UNIVERSE>
    Dec  7 15:24:48 raspberrypi systemd[586]: Queued start job for default target Main User Target.
    Dec  7 15:24:48 raspberrypi systemd[586]: Created slice User Application Slice.
    Dec  7 15:24:48 raspberrypi systemd[586]: Reached target Paths.
    Dec  7 15:24:48 raspberrypi systemd[586]: Reached target Timers.
    Dec  7 15:24:48 raspberrypi systemd[586]: Starting D-Bus User Message Bus Socket.
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG network certificate management daemon.
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on GnuPG cryptographic agent and passphrase cache.
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on Multimedia System.
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on debconf communication socket.
    Dec  7 15:24:48 raspberrypi systemd[586]: Listening on Sound System.
    Dec  7 15:24:49 raspberrypi systemd[1]: Starting Rotate log files...
    Dec  7 15:24:49 raspberrypi systemd[1]: Starting Daily man-db regeneration...
    Dec  7 15:24:49 raspberrypi systemd[586]: Listening on D-Bus User Message Bus Socket.
    Dec  7 15:24:49 raspberrypi systemd[586]: Reached target Sockets.
    Dec  7 15:24:49 raspberrypi systemd[586]: Reached target Basic System.
    Dec  7 15:24:49 raspberrypi systemd[1]: Started User Manager for UID 1000.
    Dec  7 15:24:49 raspberrypi systemd[1]: Started Session 1 of user pi.
    Dec  7 15:24:49 raspberrypi systemd[586]: Started Multimedia Service.
    Dec  7 15:24:49 raspberrypi systemd[586]: Starting Sound Service...
    Dec  7 15:24:49 raspberrypi dbus-daemon[342]: [system] Activating via systemd: service name='org.freedesktop.RealtimeKit1' unit='rtkit-daemon.service' requested by ':1.22' (uid=1000 pid=654 comm="/usr/bin/pipewire ")
    Dec  7 15:24:49 raspberrypi systemd[1]: Starting RealtimeKit Scheduling Policy Service...
    Dec  7 15:24:49 raspberrypi dbus-daemon[342]: [system] Successfully activated service 'org.freedesktop.RealtimeKit1'
    Dec  7 15:24:49 raspberrypi systemd[1]: Started RealtimeKit Scheduling Policy Service.
    Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Successfully called chroot.
    Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Successfully dropped privileges.
    Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Successfully limited resources.
    Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Canary thread running.
    Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Running.
    Dec  7 15:24:49 raspberrypi rtkit-daemon[663]: Watchdog thread running.
    Dec  7 15:24:51 raspberrypi kernel: [   31.831859] cam-dummy-reg: disabling
    Dec  7 15:24:51 raspberrypi kernel: [   32.060106] Bluetooth: HCI UART driver ver 2.3
    Dec  7 15:24:51 raspberrypi kernel: [   32.060130] Bluetooth: HCI UART protocol H4 registered
    Dec  7 15:24:51 raspberrypi kernel: [   32.061606] Bluetooth: HCI UART protocol Three-wire (H5) registered
    Dec  7 15:24:51 raspberrypi kernel: [   32.061906] Bluetooth: HCI UART protocol Broadcom registered
    Dec  7 15:24:51 raspberrypi btuart[385]: bcm43xx_init
    Dec  7 15:24:51 raspberrypi btuart[385]: Flash firmware /lib/firmware/brcm/BCM4345C0.hcd
    Dec  7 15:24:51 raspberrypi btuart[385]: Set Controller UART speed to 3000000 bit/s
    Dec  7 15:24:51 raspberrypi btuart[385]: Device setup complete
    Dec  7 15:24:51 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
    Dec  7 15:24:51 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
    Dec  7 15:24:51 raspberrypi systemd[586]: Reached target Bluetooth.
    Dec  7 15:24:51 raspberrypi systemd[1]: Created slice system-bthelper.slice.
    Dec  7 15:24:51 raspberrypi systemd[1]: Starting Raspberry Pi bluetooth helper...
    Dec  7 15:24:52 raspberrypi bthelper[691]: Can't init device hci0: Operation not possible due to RF-kill (132)
    Dec  7 15:24:52 raspberrypi systemd[1]: bthelper@hci0.service: Main process exited, code=exited, status=1/FAILURE
    Dec  7 15:24:52 raspberrypi systemd[1]: bthelper@hci0.service: Failed with result 'exit-code'.
    Dec  7 15:24:52 raspberrypi systemd[1]: Failed to start Raspberry Pi bluetooth helper.
    Dec  7 15:24:52 raspberrypi systemd[1]: Starting Bluetooth service...
    Dec  7 15:24:52 raspberrypi systemd[1]: Stopping Make remote CUPS printers available locally...
    Dec  7 15:24:52 raspberrypi systemd[1]: cups-browsed.service: Succeeded.
    Dec  7 15:24:52 raspberrypi systemd[1]: Stopped Make remote CUPS printers available locally.
    Dec  7 15:24:52 raspberrypi systemd[1]: Stopping CUPS Scheduler...
    Dec  7 15:24:52 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
    Dec  7 15:24:52 raspberrypi systemd[1]: cups.service: Succeeded.
    Dec  7 15:24:52 raspberrypi systemd[1]: Stopped CUPS Scheduler.
    Dec  7 15:24:52 raspberrypi systemd[1]: cups.path: Succeeded.
    Dec  7 15:24:52 raspberrypi systemd[1]: Started CUPS Scheduler.
    Dec  7 15:24:52 raspberrypi systemd[1]: cups.socket: Succeeded.
    Dec  7 15:24:52 raspberrypi systemd[1]: Closed CUPS Scheduler.
    Dec  7 15:24:52 raspberrypi systemd[1]: Listening on CUPS Scheduler.
    Dec  7 15:24:52 raspberrypi systemd[1]: Starting CUPS Scheduler...
    Dec  7 15:24:52 raspberrypi systemd[1]: Started Make remote CUPS printers available locally.
    Dec  7 15:24:52 raspberrypi bluetoothd[695]: Bluetooth daemon 5.55
    Dec  7 15:24:52 raspberrypi systemd[1]: Started Bluetooth service.
    Dec  7 15:24:52 raspberrypi systemd[1]: Reached target Bluetooth.
    Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 654 of process 654 owned by '1000' high priority at nice level -11.
    Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 1 threads of 1 processes of 1 users.
    Dec  7 15:24:53 raspberrypi bluetoothd[695]: Starting SDP server
    Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 655 of process 655 owned by '1000' high priority at nice level -11.
    Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 2 threads of 2 processes of 1 users.
    Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Successfully made thread 660 of process 654 owned by '1000' RT at priority 20.
    Dec  7 15:24:53 raspberrypi rtkit-daemon[663]: Supervising 3 threads of 2 processes of 1 users.
    Dec  7 15:24:53 raspberrypi kernel: [   33.527732] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    Dec  7 15:24:53 raspberrypi kernel: [   33.527759] Bluetooth: BNEP filters: protocol multicast
    Dec  7 15:24:53 raspberrypi kernel: [   33.527787] Bluetooth: BNEP socket layer initialized
    Dec  7 15:24:53 raspberrypi bluetoothd[695]: Bluetooth management interface 1.21 initialized
    Dec  7 15:24:53 raspberrypi kernel: [   33.568521] NET: Registered PF_ALG protocol family
    Dec  7 15:24:53 raspberrypi kernel: [   33.669986] cryptd: max_cpu_qlen set to 1000
    Dec  7 15:24:53 raspberrypi systemd[586]: Started D-Bus User Message Bus.
    Dec  7 15:24:53 raspberrypi bluetoothd[695]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Dec  7 15:24:53 raspberrypi bluetoothd[695]: sap-server: Operation not permitted (1)
    Dec  7 15:24:53 raspberrypi bluetoothd[695]: Failed to set mode: Blocked through rfkill (0x12)
    Dec  7 15:24:53 raspberrypi kernel: [   34.096992] Bluetooth: RFCOMM TTY layer initialized
    Dec  7 15:24:53 raspberrypi kernel: [   34.097017] Bluetooth: RFCOMM socket layer initialized
    Dec  7 15:24:53 raspberrypi kernel: [   34.097035] Bluetooth: RFCOMM ver 1.11
    pi@raspberrypi:~ $
    Danke schonmal im Voraus
      @kenji sagte in SD-Karte läuft im Verzeichnis /dev/root voll:
      Sorry das ich hier parallel fahre (Discord/Forum)
      ist nicht optimal, da die linke nicht die Informationen hat, die die rechte hat.
      Meister MopperM Online
      Meister Mopper
      @homoran sagte in SD-Karte läuft im Verzeichnis /dev/root voll:
      Habe die Anfrage deswegen nach hier fokussiert.
      Proxmox und HA ...
      • KenjiK Kenji
        pi@raspberrypi:~ $
        @kenji
        Schalt den Desktop-Krempel aus.
        KenjiK 1 Antwort Letzte Antwort
          @kenji
          KenjiK Offline
          KenjiK Offline
          Kenji
          @thomas-braun Würdest du mir da eine Hilfestellung geben oder ist das umfangreicher. Wie kann man diese Logs aktivieren oder deaktivieren?
          Oder müssen die Prozesse dahinter einfach deaktiviert werden.
          Ich habe eigentlich nur en IoBroker auf dem Pi installiert. Wie kommt eine so große Ansammlung zustande? Hat das mit dem Update zu tun was ich durchgeführt habe?
          Gruß Matze :)
          • KenjiK Kenji
            Gruß Matze :)
            Offenbar entgegen der Empfehlung die Version mit vollem DesktopEnvironment.
            Musst du in die logs schauen. Die bisher geposteten Auszüge zeigen (bis auf den hochgefahrenen Desktop) nicht genug.
            Welches Update?
            • KenjiK Offline
              KenjiK Offline
              Kenji
              Achso also ist die Pi Version komplett ohne Desktop offiziell für den IoBroker empfohlen. Das könnte ich ja auf Dauer mal ändern. Vielen Dank für die Hilfe. Er läuft jetzt erstmal wieder und ich versuche mal mit einem Backup auf eine andere Pi Version ohne Desktop umzuziehen.
              Das Update war Node 16v. und Pi Version "Bullseye".
              • KenjiK Kenji
                Das ist die Version, die generell für Serverbetrieb vorgesehen ist.
                Den Desktop kannst du in
                sudo raspi-config
                ausknipsen. In den Boot-Optionen auf 'Boot into CLI, LogIn required' oder so ähnlich umstellen.
                  sudo raspi-config
                  KenjiK Offline
                  KenjiK Offline
                  Kenji
                  @thomas-braun Dankeschön habe ich umgestellt hat auch geklappt.
