  4. Ring Adapter Problem
8 Beiträge 2 Kommentatoren 746 Aufrufe 2 Beobachtet
  • planetkeaneP Offline
    planetkeane
    seit einigen Tagen funktioniert mein Ring-Adapter nicht mehr. Am System habe ich nichts verändert, jedoch den Adapter auf die neuste Version hochgezogen. Hat jemand eine Idee?
    host.ioBroker2
    	2022-11-20 13:20:30.468	info	Restart adapter system.adapter.ring.0 because enabled
    host.ioBroker2
    	2022-11-20 13:20:30.468	error	instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker2
    	2022-11-20 13:20:30.468	error	Caught by controller[0]: }
    host.ioBroker2
    	2022-11-20 13:20:30.468	error	Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
    host.ioBroker2
    	2022-11-20 13:20:30.468	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.ring/build/lib/ringApiClient.js:7:15) {
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1028:19)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:942:27)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:533:31)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:493:36)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:748:3)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:464:9)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: at new NodeError (node:internal/errors:387:5)
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/api/api' is not defined by "exports" in /opt/iobroker/node_modules/ring-client-api/package.json
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: ^
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: throw e;
    host.ioBroker2
    	2022-11-20 13:20:30.467	error	Caught by controller[0]: node:internal/modules/cjs/loader:499
    host.ioBroker2
    	2022-11-20 13:20:30.044	info	instance system.adapter.ring.0 started with pid 312201
    • planetkeaneP planetkeane
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      host.ioBroker2
      @planetkeane
      Welche nodeJS-Version? Ist diese senkrecht installiert?
        planetkeane
        Ich nutze ioBroker als Docker.
        Die Node Version ist 16.17.1
        Was du mit "senkrecht" meinst, weiß ich leider nicht. Auch aus deiner Signatur konnte ich diesbezüglich nichts finden
        userB@ioBroker2:/opt/iobroker# npm ls | grep -E 'github|ERR'
        ├── iobroker.habpanel@0.5.0 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.habpanel.git#2b7acb607d832a9450bec5409ff219469eff4b50)
        ├── iobroker.mqtt@2.7.3 (git+ssh://git@github.com/ioBroker/ioBroker.mqtt.git#43438675241701d45ecf95f20e2d5ffa35e0af29)
          @planetkeane sagte in Ring Adapter Problem:
          Dann lies nochmal. Gibt da einen Punkt der sich Check nennt.
            @planetkeane
            https://github.com/iobroker-community-adapters/ioBroker.ring/issues/395
              planetkeane
              Danke für den Link. Er beschreibt zwar das Problem, jedoch keine Lösung mit der neusten Version von Ring. So wie im Forum beschrieben, habe ich die 2.0.0-beta.3 installiert. Diese funktioniert tatsächlich auf anhieb.
                @planetkeane
                Da muss dem Mainrainer ran, denke ich.
                  planetkeane
                  Ich lasse es mit dem Adapter erst einmal bleiben. Auch hier bekomme ich Fehlermeldungen im Log. Ich habe ihn nur nutzen wollen, um den Batteriestatus der Kameras zu überwachen. Scheint aber sehr unausgereift der Adapter
