  4. Ring adapter problem
    5.6k
15 Beiträge 3 Kommentatoren 1.6k Aufrufe 4 Beobachtet
  • XceccX Offline
    XceccX Offline
    Xcecc
    Hallo liebe community,
    ich habe vor paar Tagen den ring adapter installiert, welcher ohne Probleme auch durchgelaufen ist. Jedoch wenn ich diesen starte erscheint unter debug folgender fehlercode.
    2022-11-13 21:44:25.739 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:535
    2022-11-13 21:44:25.739 - error: host.iobroker Caught by controller[0]: throw e;
    2022-11-13 21:44:25.739 - error: host.iobroker Caught by controller[0]: ^
    2022-11-13 21:44:25.739 - error: host.iobroker Caught by controller[0]: Error [ERR_PACKAGE_PATH_NOT_EXPORTED]: Package subpath './lib/api/api' is not defined by "exports" in /opt/iobroker/node_modules/ring-client-api/package.json
    2022-11-13 21:44:25.739 - error: host.iobroker Caught by controller[0]: at new NodeError (node:internal/errors:393:5)
    2022-11-13 21:44:25.739 - error: host.iobroker Caught by controller[0]: at throwExportsNotFound (node:internal/modules/esm/resolve:358:9)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at packageExportsResolve (node:internal/modules/esm/resolve:668:3)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at resolveExports (node:internal/modules/cjs/loader:529:36)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at Module._findPath (node:internal/modules/cjs/loader:569:31)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:841:27)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1061:19)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.ring/build/lib/ringApiClient.js:4:15) {
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: code: 'ERR_PACKAGE_PATH_NOT_EXPORTED'
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: }
    2022-11-13 21:44:25.740 - error: host.iobroker Caught by controller[0]: Node.js v18.12.1
    2022-11-13 21:44:25.740 - error: host.iobroker instance system.adapter.ring.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    evtl kann mir jemand helfen diesen zu beheben über jegliche hilfe wäre ich sehr dankbar :)
    • XceccX Xcecc
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @xcecc sagte in Ring adapter problem:
      Erstmal ... packe die Ausgabe in Code-Tags </> dann kann man es besser lesen .
      und zu :
      installiere die empfohlene Nodejs 16
      XceccX 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        und zu :
        XceccX Offline
        XceccX Offline
        Xcecc
        @glasfaser danke für deine Hilfestellung jedoch lag es nicht an nodejs der gleiche Fehler wird immer noch erzeugt :/
        GlasfaserG 2 Antworten Letzte Antwort
        • XceccX Xcecc
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @xcecc
          Ich habe den Adapter nicht und kenne den Fehler nicht in deinem Log ...
          aber du hast ja schon dazu ein Issues erstellt :
          https://github.com/iobroker-community-adapters/ioBroker.ring/issues/395
          • XceccX Xcecc
            GlasfaserG Offline
            GlasfaserG Offline
            Glasfaser
            Zeige mal was du so hast
            Ausgabe in Code-Tags !!!
            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            iobroker update -i
              iobroker update -i
              XceccX Offline
              XceccX Offline
              Xcecc
              @glasfaser
              xcecc@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodej
              s &> /dev/null
              iobroker update -i[sudo] password for xcecc:
              Sorry, try again.
              s &> /dev/null
              iobroker update -ixcecc@iobroker:~$
              xcecc@iobroker:~$ uname -m && test -f /opt/scripts/.docke
              icy nodejs
              x86_64
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              8.19.2in/npm
              4.0.23
              xcecc
              xcecc sudo
              /home/xcecc
              Hit:1 http://security.debian.org bullseye-security InRele
              ase
              Hit:2 http://ftp.debian.org/debian bullseye InRelease
              Hit:3 http://ftp.debian.org/debian bullseye-updates InRel
              ease
              Hit:4 https://deb.nodesource.com/node_16.x bullseye InRel
              ease
              Reading package lists... Done
              Building dependency tree... Done
              5 packages can be upgraded. Run 'apt list --upgradable' t
              o see them.
              nodejs:
                Installed: 16.18.1-deb-1nodesource1
                Candidate: 16.18.1-deb-1nodesource1
                Version table:
               *** 16.18.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye
              /main amd64 Packages
                      100 /var/lib/dpkg/status
                   12.22.12~dfsg-1~deb11u1 500
                      500 http://security.debian.org bullseye-security/
              main amd64 Packages
                   12.22.5~dfsg-2~11u1 500
                      500 http://ftp.debian.org/debian bullseye/main am
              d64 Packages
              xcecc@iobroker:~$
              xcecc@iobroker:~$ iobroker update -i
              Used repository: stable
              Adapter    "admin"        : 6.2.23   , installed 6.2.23
              Adapter    "backitup"     : 2.5.4    , installed 2.5.4
              Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [
              Updatable]
              Adapter    "history"      : 2.2.0    , installed 2.2.0
              Controller "js-controller": 4.0.23   , installed 4.0.23
              Adapter    "ring"         : 3.1.3    , installed 3.1.3
              Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
              Adapter    "socketio"     : 4.2.0    , installed 4.2.0
              Adapter    "web"          : 4.3.0    , installed 4.3.0
              Adapter    "ws"           : 1.3.0    , installed 1.3.0
              s &> /dev/null
              icy nodejs
              x86_64
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.1
              v16.18.1
              8.19.2
              4.0.23
              xcecc
              xcecc sudo
              /home/xcecc
              Hit:1 http://ftp.debian.org/debian bullseye InRelease
              Hit:2 http://security.debian.org bullseye-security InRele
              ase
              ease
              ease
              o see them.
              nodejs:
                Version table:
              s &> /dev/null
              icy nodejs
              x86_64
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.1
              v16.18.1
              8.19.2
              4.0.23
              xcecc
              xcecc sudo
              /home/xcecc
              ase
              ease
              ease
              o see them.
              nodejs:
                Version table:
              main amd64 Packages
              d64 Packages
              xcecc@iobroker:~$
              xcecc@iobroker:~$
              • XceccX Xcecc
                @glasfaser
                s &> /dev/null
                Sorry, try again.
                s &> /dev/null
                icy nodejs
                x86_64
                Kein Docker
                /usr/bin/nodejs
                /usr/bin/node
                8.19.2in/npm
                4.0.23
                xcecc
                xcecc sudo
                /home/xcecc
                ase
                ease
                ease
                o see them.
                nodejs:
                  Version table:
                main amd64 Packages
                d64 Packages
                xcecc@iobroker:~$
                Updatable]
                s &> /dev/null
                icy nodejs
                x86_64
                Kein Docker
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.18.1
                v16.18.1
                8.19.2
                4.0.23
                xcecc
                xcecc sudo
                /home/xcecc
                ase
                ease
                ease
                o see them.
                nodejs:
                  Version table:
                s &> /dev/null
                icy nodejs
                x86_64
                Kein Docker
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.18.1
                v16.18.1
                8.19.2
                4.0.23
                xcecc
                xcecc sudo
                /home/xcecc
                ase
                ease
                ease
                o see them.
                nodejs:
                  Version table:
                main amd64 Packages
                d64 Packages
                xcecc@iobroker:~$
                xcecc@iobroker:~$
                @xcecc
                Der User xcecc fehlt in der Gruppe 'iobroker'.
                Minimum, eigentlich sollte der um handlungsfähig zu sein wohl auch noch in weiteren Gruppen sein.
                  @xcecc
                  XceccX Offline
                  XceccX Offline
                  Xcecc
                  @thomas-braun ok dürfte ich erfahren wie ich diesen hinzufüge :). Habe dein thread mit root Rechten verfolgt und extra xcecc als. Benutzer angelegt damit. Ich nicht das System abschieße mit root Rechten 😂
                  • XceccX Xcecc
                    @xcecc
                    sudo usermod -aG iobroker xcecc
                    So zum Vergleich:
                    Mein Standard-User läuft hier jeweils mit:
                    echad@chet:~ $ groups
                    echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
                    Jetzt nicht auf die Idee kommen die alle zu kopieren, da ist auch die ein oder andere Gruppe dabei die du nicht haben wirst.
                      @xcecc
                      So zum Vergleich:
                      XceccX Offline
                      XceccX Offline
                      Xcecc
                      @thomas-braun nene ich copy und paste nicht keine sorge. will ja schon verstehen was wie wo macht. ich interpretiere es so das ich mit:
                      xcecc also den Benutzernamen in iobroker Ordner hinzufüge und ihm rechte gebe stimmt? Aber für was steht -aG?
                      • XceccX Xcecc
                        @xcecc
                        add Group
                        bzw. genauer
                        append Group
                        Tip: Der user muss einmal aus- und wieder eingeloggt werden, damit man die neue Gruppenzugehörigkeit sieht.
                          @xcecc
                          add Group
                          bzw. genauer
                          append Group
                          XceccX Offline
                          XceccX Offline
                          Xcecc
                          @thomas-braun oh ok danke hast evtl noch tipp wo man das alles erlernen kann :)
                          • XceccX Xcecc
                            @xcecc
                            Gibt da so was wie Bücher. Der Herr Kofler schreibt da ganz wunderbare Grundlagenwerke.
                              @xcecc
                              XceccX Offline
                              XceccX Offline
                              Xcecc
                              @thomas-braun da je dafür 👍👌 werde ich mir bestellen :) dachte rheinwerk computing macht nur Programmiersprachen 😁 war jedenfalls mein Stand vor 10 Jahren
                              • XceccX Xcecc
                                @xcecc
                                Hmmm. Ich glaube mein erster 'Kofler' war noch von SuSE-Press.
