  4. ? docker-compose mit redis, DNS-Fehler
    5.7k
2 Beiträge 2 Kommentatoren 365 Aufrufe 2 Beobachtet
    Morgennebel
    Hej,
    ich versuche mich an einer IOBroker-Installation mit docker-compose und redis. Die .yml-Datei:
    version: "2"
    services:
      iobroker:
        container_name: iobroker
        image: buanet/iobroker:latest-v7
        hostname: iobroker
        dns:
          - 192.168.3.10
        restart: unless-stopped
        networks:
          internal:
            ipv4_address: 172.18.0.2
        ports:
          - "1880:1880"  #node-red
          - "1883:1883"  #mqtt
          - "2001:2001"  #homematic
          - "8081:8081"  #iobroker admin
          - "8282:8282"  #flot
          - "8088:8088"  #terminal
          - "8284:8284"  #socketIO
        environment:
          - IOB_STATESDB_HOST=redis
          - IOB_STATESDB_PORT=6379
          - IOB_STATESDB_TYPE=redis
          - SETGID=1200
          - SETUID=1200
        volumes:
          - /opt/docker-iobroker/iobroker-data:/opt/iobroker
        depends_on:
          - redis
      redis:
        container_name: redis
        image: redis:latest
        hostname: redis
        networks:
          internal:
            ipv4_address: 172.18.0.3
        ports:
          - "6379:6379"
        volumes:
          - /opt/docker-iobroker/redis_data:/data
    networks:
      internal:
        driver: bridge
        ipam:
          config:
            - subnet: 172.18.0.0/16
              gateway: 172.18.0.1
              ip_range: 172.18.0.1/24
    Die erste Installation (mit gelöschten Volumes) scheitert an fehlendem DNS im Container:
    iobroker    | --------------------------------------------------------------------------------
    iobroker    | -----                  Step 1 of 5: Preparing container                   -----
    iobroker    |
    iobroker    | Updating Linux packages on first run...
    iobroker    | W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease  Temporary failure resolving 'deb.debian.org'
    iobroker    | W: Failed to fetch http://deb.debian.org/debian-security/dists/bullseye-security/InRelease  Temporary failure resolving 'deb.debian.org'
    iobroker    | W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease  Temporary failure resolving 'deb.debian.org'
    iobroker    | W: Failed to fetch https://deb.nodesource.com/node_16.x/dists/bullseye/InRelease  Temporary failure resolving 'deb.nodesource.com'
    iobroker    | W: Some index files failed to download. They have been ignored, or old ones used instead.
    iobroker    | Done.
    iobroker    |
    iobroker    | PACKAGES is set. Installing additional Linux packages.
    iobroker    | Checking the following packages: ...
    Die DNS-Konfiguration des Hosts ist /etc/resolv.conf:
    root@wyse5070-lan-docker:/opt/docker-iobroker# more /etc/resolv.conf
    nameserver 127.0.0.1
    welches von einem PiHole Docker Container zur Verfügung gestellt wird. Die DNS-Auflösung auf HOST-Seite funktioniert tadellos. Docker wurde entsprechend konfiguriert:
    root@wyse5070-lan-docker:/opt/docker-iobroker# more /etc/docker/daemon.json
        "dns": ["192.168.3.10"]
    Auch im docker-compose.yml ist ein DNS-Server mit identischer IP konfiguriert.
    Ich bin docker-Anfänger und nun etwas ratlos, was denn wohl hier flasch ist. Ein RTFM oder eine Lösungsidee wäre sehr hilfreich.
    Danke, -MN
    IOBroker nach 5.5 Jahren FHEM.
    Docker: IOB+redis+InfluxDB mit Devuan 6.0 (Linux).
    OPNSense, Ruckus, Homematic, HeatingControl, Hue, InfluxDB, Kodi, LinkedDevices, LGTV, LGTV11, Luftdaten, MQTT, MiHome-Vaccum, Pi-Hole, Pollenflug, Shelly, Telegram, Vis, Wolf,
    • M Morgennebel
      Hej,
      version: "2"
      services:
        iobroker:
          hostname: iobroker
          dns:
            - 192.168.3.10
          networks:
            internal:
          ports:
            - "1883:1883"  #mqtt
            - "8282:8282"  #flot
          environment:
            - SETGID=1200
            - SETUID=1200
          volumes:
          depends_on:
            - redis
        redis:
          image: redis:latest
          hostname: redis
          networks:
            internal:
          ports:
            - "6379:6379"
          volumes:
      networks:
        internal:
          driver: bridge
          ipam:
            config:
                gateway: 172.18.0.1
      iobroker    |
      iobroker    | Done.
      iobroker    |
      Danke, -MN
      OliverIOO Offline
      OliverIOO Offline
      OliverIO
      @morgennebel
      darf ich fragen warum du den dns und die ganzen ip-adressen selbst definierst?
      überlasse das doch docker
      oder hast du da einen speziellen dns laufen?
      hier meine docker-compose, allerdings mit macvlan für eine eigene ip für den iobroker.
      wenn du aber die mit #x markierten zeilen weglässt, dann müsste es doch gehen
      der rest müsste selbsterklärend sein
      version: '3'
      services:
        iobrokerprod4:
          restart: always
          container_name: iobrokerprod4
          hostname: iobrokerprod4
          ports:
            - "8081:8081"
            - "1234:1234"
          environment:
              SETGID: 1001
              SETUID: 1001
          volumes:
            - /home/iobroker/docker/volume/iobroker_prod4:/opt/iobroker
            - /media/iobroker_backup/:/opt/iobroker/backup
          networks:
            dockerMACVLAN:                       #x
              ipv4_address: 192.168.1.85         #x
            iobrokerprod4:
        redis4:
          image: "redis:alpine"
          volumes:
            - /home/iobroker/docker/volume/redis_prod4:/data
          networks:
            iobrokerprod4:
      networks:
        dockerMACVLAN:      #x
          external: true    #x
        iobrokerprod4:
      wenn du dann später zur Konfiguration die ip-Adressen benötigst, dann kannst du die jeweiligen labels der services nehmen. diese werden automatisch von docker im jeweiligen netz als hostnamen registriert und aufgelöst.
      bspw wenn du dann in der konfiguration des iobrokers auf redis umstellen willst, dann verwendest du anstatt der ip einfach "redis4"
      Meine Adapter und Widgets
      Links im Profil
