  4. Time-Switch Adapter: Exceptions bei Astrotrigger
6 Beiträge 3 Kommentatoren 589 Aufrufe 3 Beobachtet
  • D Online
    D Online
    diwoma
    schrieb am zuletzt editiert von diwoma
    Ich habe den Time-Switch-Adapter mit 3 Trigger über Astro:
    1 x bei Sonnenuntergang
    1 x bei Sonnenaufgang
    1 x bei Sonnenaufgang - 30min
    Um 02:00, anscheinend wenn die neuen Astro-Zeiten eingelesen/übernommen werden bekomme ich diese Error-Meldungen:
    2022-10-12 02:00:00.029 - error: time-switch.0 (1175) uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=6, minute=39, weekdays=[1]} is not registered.
    2022-10-12 02:00:00.031 - error: time-switch.0 (1175) Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=6, minute=39, weekdays=[1]} is not registered.
    at TimeTriggerScheduler.unregister (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:34:19)
    at /opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:73
    at Array.forEach ()
    at Object.execute (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/AstroTriggerScheduler.js:25:32)
    at Job.job (/opt/iobroker/node_modules/iobroker.time-switch/build/scheduler/TimeTriggerScheduler.js:22:33)
    at Job.invoke (/opt/iobroker/node_modules/iobroker.time-switch/node_modules/node-schedule/lib/schedule.js:175:17)
    at /opt/iobroker/node_modules/iobroker.time-switch/node_modules/node-schedule/lib/schedule.js:555:26
    at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.time-switch/node_modules/node-schedule/lib/schedule.js:512:7)
    at listOnTimeout (node:internal/timers:559:17)
    at processTimers (node:internal/timers:502:7)
    2022-10-12 02:00:00.031 - error: time-switch.0 (1175) Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=6, minute=39, weekdays=[1]} is not registered.
    2022-10-12 02:00:00.034 - info: time-switch.0 (1175) cleaning everything up...
    2022-10-12 02:00:00.035 - info: time-switch.0 (1175) terminating
    2022-10-12 02:00:00.035 - warn: time-switch.0 (1175) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-10-12 02:00:00.041 - error: time-switch.0 (1175) uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=7, minute=9, weekdays=[1]} is not registered.
    2022-10-12 02:00:00.042 - error: time-switch.0 (1175) Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=7, minute=9, weekdays=[1]} is not registered.
    at Array.forEach ()
    2022-10-12 02:00:00.042 - error: time-switch.0 (1175) Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:1, hour=7, minute=9, weekdays=[1]} is not registered.
    2022-10-12 02:00:00.047 - info: javascript.0 (456) script.js.Temperatur.Temperatur_Verwaltung: CRON Startet: 12.10.2022 02:00:00
    2022-10-12 02:00:00.051 - error: time-switch.0 (1175) uncaught exception: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:2, hour=18, minute=23, weekdays=[1]} is not registered.
    2022-10-12 02:00:00.051 - error: time-switch.0 (1175) Error: Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:2, hour=18, minute=23, weekdays=[1]} is not registered.
    at Array.forEach ()
    2022-10-12 02:00:00.052 - error: time-switch.0 (1175) Trigger TimeTrigger {id=TimeTriggerForAstroTrigger:2, hour=18, minute=23, weekdays=[1]} is not registered.
    2022-10-12 02:00:00.076 - info: mqtt.0 (576) send2Server mqtt.0.haus.Panels.NSPanel_1.cmnd.CustomSend[haus/Panels/NSPanel_1/cmnd/CustomSend]
    2022-10-12 02:00:00.095 - info: mqtt.0 (576) send2Server mqtt.0.haus.Panels.NSPanel_1.cmnd.CustomSend[haus/Panels/NSPanel_1/cmnd/CustomSend]
    2022-10-12 02:00:00.254 - error: javascript.0 (456) Error in request callback: TypeError: Cannot read properties of undefined (reading 'channels')
    2022-10-12 02:00:00.573 - error: host.ioBroker instance system.adapter.time-switch.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    2022-10-12 02:00:00.574 - info: host.ioBroker Restart adapter system.adapter.time-switch.0 because enabled
    Die Schaltung löst aber korrekt aus.
    Funktional stört es zwar nicht, aber vielleicht lässt sich herausfinden woran es liegt
    Edit:
    ein paar der Zeilen gehören mit ziemlicher Sicherheit nicht zu den Meldungen des Adapters
    -- diwoma
    ioBroker in LX-Container in Proxmox
    Zigbee-Coordinator: CC2652P2-TCP FW: 20230507
    • D diwoma
      at Array.forEach ()
      at Array.forEach ()
      at Array.forEach ()
      Edit:
      BananaJoeB Offline
      BananaJoeB Offline
      BananaJoe
      @diwoma da nehmen wir doch mal @walli545 mit rein und eventuell solltest du das als Issue auf Github melden: https://github.com/walli545/ioBroker.time-switch
      • BananaJoeB BananaJoe
        D Online
        D Online
        diwoma
        @bananajoe said in Time-Switch Adapter: Exceptions bei Astrotrigger:
        Vielleicht sieht er das schon hier in den nächsten Tagen, sonst werde ich das Issue auf Github melden
        -- diwoma
        • BananaJoeB Offline
          BananaJoeB Offline
          BananaJoe
          @diwoma er war seit dem 3. Januar nicht mehr Online, ich hoffe es geht ihm gut ... auf Github hat er im April zuletzt was beantwortet ...
            D Online
            D Online
            diwoma
            Das habe ich auf Github gesehen, deswegen hoffte ich, er wäre hier aktiver.
            Ich hoffe auch, das es ihm gut geht.
            -- diwoma
            A 1 Antwort Letzte Antwort
            • D diwoma
              andibr
              @diwoma
              Hallo zusammen, hoffen wir mal das es ihm gut geht und er den Adapter weiterbetreut?
              Ich habe gestern ein komplett neues System aufgesetzt und folgende Probleme festgestellt:
              • bei mir zwar die Schaltbefehle ausgeführt werden, aber auch mit den Astrotrigger da Error-Meldungen entstehen. Immer um ca. 02.00.
              • das Widget über das Cloud Login nicht angezeigt wird. Da gehe ich aber davon aus, dass ich irgend was noch nicht oder falsch eingestellt habe?
              Vieleicht hat ja jemand bereits eine Lösung gefunden? Es wäre nämlich sehr schade wenn dieser Adapter der so simpel und einfach ist, verloren gehen würde. Leider beherrsche ich keine Programiersprache sonst könnte man das ja anschauen.
