  3. Einsteigerfragen
  4. Zigbee Adapter lässt sich nicht einrichten
    5.6k
5 Beiträge 2 Kommentatoren 686 Aufrufe 2 Beobachtet
  • H Offline
    hausautomation.digital
    Seit Stunden lese ich hier und suche im Netz, aber ich bekomm den Adapter nicht zum laufen.
    zigbee.0
    	2022-10-11 20:12:36.643	error	Error herdsman start
    zigbee.0
    	2022-10-11 20:12:36.642	error	Failed to start Zigbee
    zigbee.0
    	2022-10-11 20:12:36.641	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0
    	2022-10-11 20:12:36.407	info	Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    	2022-10-11 20:12:36.364	info	Starting Zigbee npm ...
    Was mach ich falsch? 😧
    • H hausautomation.digital
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @hausautomation-digital
      Zeig mal einen vollständigen Start des Adapters.
      H 1 Antwort Letzte Antwort
        zigbee.0
        	2022-10-11 20:44:08.130	error	Error herdsman start
        zigbee.0
        	2022-10-11 20:44:08.129	error	Failed to start Zigbee
        zigbee.0
        	2022-10-11 20:44:08.128	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        zigbee.0
        	2022-10-11 20:44:07.844	info	Installed Version: iobroker.zigbee@1.7.5
        zigbee.0
        	2022-10-11 20:44:07.820	info	Starting Zigbee npm ...
        zigbee.0
        	2022-10-11 20:44:07.819	info	Try to reconnect. 1 attempts left
        zigbee.0
        	2022-10-11 20:43:57.813	error	Error herdsman start
        zigbee.0
        	2022-10-11 20:43:57.812	error	Failed to start Zigbee
        zigbee.0
        	2022-10-11 20:43:57.811	error	Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
        zigbee.0
        	2022-10-11 20:43:57.676	error	Re-commissioning your network will require re-pairing of all devices!
        zigbee.0
        	2022-10-11 20:43:57.675	error	If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
        zigbee.0
        	2022-10-11 20:43:57.675	error	Please update configuration to prevent further issues.
        zigbee.0
        	2022-10-11 20:43:57.674	error	- Channel List: configured=26, adapter=20
        zigbee.0
        	2022-10-11 20:43:57.673	error	- Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
        zigbee.0
        	2022-10-11 20:43:57.673	error	- Extended PAN ID: configured=00124b0024c11445, adapter=00124b0024c11445
        zigbee.0
        	2022-10-11 20:43:57.671	error	- PAN ID: configured=6754, adapter=6754
        zigbee.0
        	2022-10-11 20:43:57.671	error	Configuration is not consistent with adapter state/backup!
        zigbee.0
        	2022-10-11 20:43:57.443	info	Installed Version: iobroker.zigbee@1.7.5
        zigbee.0
        	2022-10-11 20:43:56.911	info	Starting Zigbee npm ...
        zigbee.0
        	2022-10-11 20:43:56.908	info	delete old Backup files. keep only last 10
        zigbee.0
        	2022-10-11 20:43:56.804	info	starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.17.1, js-controller: 4.0.23
        host.homebutler
        	2022-10-11 20:43:53.357	info	instance system.adapter.zigbee.0 started with pid 27988
        host.homebutler
        	2022-10-11 20:43:53.289	info	"system.adapter.zigbee.0" enabled
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          host.homebutler
          host.homebutler
          @hausautomation-digital sagte in Zigbee Adapter lässt sich nicht einrichten:
          Stell es übereinstimmend ein.
            @thomas-braun 🍻 DANKE! Hatte ich doch glatt übersehen.... Läuft!
