  4. ioBroker startet nicht mehr
    3.2k
    3.1k
46 Beiträge 3 Kommentatoren 4.7k Aufrufe 3 Beobachtet
    Magnus 0
    Nach einem Neustart meines Raspberry Pi startet ioBroker nicht mehr.
    Vor dem Neustart lief ioBroker ohne Probleme.
    Folgende meine Versionen:
    node -v
    v16.17.1
    nodejs -v
    v16.17.1
    npm -v
    8.15.0
    iobroker -v
    4.0.23
    Wenn ich den Befehl "iobroker logs" ausführe, erscheint immer wieder folgender Fehler:
    2022-09-30 20:33:48.748  - info: host.DELO0150 iobroker _restart
    2022-09-30 20:33:49.603  - info: host.DELO0150 connected to Objects and States
    2022-09-30 20:33:49.633  - info: host.DELO0150 added notifications configuration of host
    2022-09-30 20:33:49.642  - info: host.DELO0150 Node.js version has changed from 16.16.0 to 16.17.1
    2022-09-30 20:33:49.731  - info: host.DELO0150 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2022-09-30 20:33:54.238  - info: host.DELO0150 iobroker.js-controller version 4.0.23 js-controller starting
    2022-09-30 20:33:54.245  - info: host.DELO0150 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-09-30 20:33:54.246  - info: host.DELO0150 hostname: DELO0150, node: v16.17.1
    2022-09-30 20:33:54.247  - info: host.DELO0150 ip addresses: 192.168.178.150 fe80::5068:6694:ad08:cc79
    2022-09-30 20:34:24.266  - error: host.DELO0150 No connection to databases possible, restart
    2022-09-30 20:34:24.276  - info: host.DELO0150 iobroker _restart
    2022-09-30 20:34:24.863  - info: host.DELO0150 connected to Objects and States
    2022-09-30 20:34:24.892  - info: host.DELO0150 added notifications configuration of host
    2022-09-30 20:34:24.901  - info: host.DELO0150 Node.js version has changed from 16.16.0 to 16.17.1
    2022-09-30 20:34:24.972  - info: host.DELO0150 Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2022-09-30 20:34:25.048  - info: host.DELO0150 Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-09-30 20:34:25.160  - info: host.DELO0150 7 instances found
    2022-09-30 20:34:25.191  - info: host.DELO0150 starting 7 instances
    2022-09-30 20:34:25.295  - info: host.DELO0150 instance system.adapter.admin.0 started with pid 3390
    2022-09-30 20:34:29.967  - info: host.DELO0150 iobroker.js-controller version 4.0.23 js-controller starting
    2022-09-30 20:34:29.974  - info: host.DELO0150 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-09-30 20:34:29.975  - info: host.DELO0150 hostname: DELO0150, node: v16.17.1
    2022-09-30 20:34:29.976  - info: host.DELO0150 ip addresses: 192.168.178.150 fe80::5068:6694:ad08:cc79
    Ich habe nun schon einige Beiträge im Forum durchgelesen, aber kam bisher noch zu keiner Lösung.
    Weiß jemand, was ich hier machen kann?
    • M Magnus 0
      node -v
      v16.17.1
      nodejs -v
      v16.17.1
      npm -v
      8.15.0
      iobroker -v
      4.0.23
      @magnus-0
      systemctl status iobroker.service
        @magnus-0
        Magnus 0
        @thomas-braun sagte in ioBroker startet nicht mehr:
        pi@DELO0150:~ $ systemctl status iobroker.service
        ● iobroker.service - ioBroker Server
           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
           Active: active (running) since Fri 2022-09-30 20:38:37 CEST; 9s ago
             Docs: http://iobroker.net
         Main PID: 3646 (iobroker.js-con)
            Tasks: 11 (limit: 4915)
           CGroup: /system.slice/iobroker.service
                   └─3646 iobroker.js-controller
        Sep 30 20:38:37 DELO0150 systemd[1]: Started ioBroker Server.
        • Thomas BraunT Online
          @magnus-0 sagte in ioBroker startet nicht mehr:
          sudo systemctl stop iobroker.service
          iobroker status
            iobroker status
            Magnus 0
            iobroker status
            pi@DELO0150:~ $ sudo systemctl stop iobroker.service
            pi@DELO0150:~ $ iobroker status
            No connection to databases possible ...
            • M Magnus 0
              iobroker status
              @magnus-0
              ps aux | grep ^io
                @magnus-0
                ps aux | grep ^io
                Magnus 0
                pi@DELO0150:~ $ ps aux | grep ^io
                pi@DELO0150:~ $
                • M Magnus 0
                  pi@DELO0150:~ $
                  @magnus-0
                  uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    @magnus-0
                    Magnus 0
                    pi@DELO0150:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                    pi@DELO0150:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                    armv7l
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    v16.17.1
                    v16.17.1
                    8.15.0
                    4.0.23
                    pi
                    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                    /home/pi
                    OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                    Alle Pakete sind aktuell.
                    nodejs:
                      Installiert:           16.17.1-deb-1nodesource1
                      Installationskandidat: 16.17.1-deb-1nodesource1
                      Versionstabelle:
                     *** 16.17.1-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                            100 /var/lib/dpkg/status
                         10.24.0~dfsg-1~deb10u1 500
                    • M Magnus 0
                      armv7l
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.1
                      v16.17.1
                      8.15.0
                      4.0.23
                      pi
                      /home/pi
                      nodejs:
                        Versionstabelle:
                      @magnus-0
                      Starte die Kiste mal sauber durch.
                        @magnus-0
                        Magnus 0
                        also "sudo reboot"?
                        • M Magnus 0
                          also "sudo reboot"?
                          @magnus-0
                          Ja.
                          M 2 Antworten Letzte Antwort
                            @magnus-0
                            Ja.
                            Magnus 0
                            Gleiches Problem immer noch.
                            • M Magnus 0
                              @magnus-0
                              iobroker status
                              iobroker update -i
                                @magnus-0
                                Ja.
                                Magnus 0
                                Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                                  @magnus-0
                                  iobroker status
                                  iobroker update -i
                                  Magnus 0
                                  pi@DELO0150:~ $ iobroker update -i
                                  • M Magnus 0
                                    @magnus-0
                                    iobroker status
                                    iobroker start
                                      @magnus-0
                                      iobroker status
                                      iobroker start
                                      Magnus 0
                                      iobroker start
                                         Active: active (running) since Fri 2022-09-30 20:56:19 CEST; 28s ago
                                       Main PID: 882 (iobroker.js-con)
                                                 └─882 iobroker.js-controller
                                      Sep 30 20:56:19 DELO0150 systemd[1]: Started ioBroker Server.
                                      pi@DELO0150:~ $ iobroker start
                                      • M Magnus 0
                                        iobroker start
                                        sudo apt install lsof
                                        sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                                          Magnus 0
                                          schrieb am zuletzt editiert von Magnus 0
                                          pi@DELO0150:~ $ sudo apt install lsof
                                          Die folgenden NEUEN Pakete werden installiert:
                                            lsof
                                          0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                          Es müssen 307 kB an Archiven heruntergeladen werden.
                                          Nach dieser Operation werden 447 kB Plattenplatz zusätzlich benutzt.
                                          Holen:1 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf lsof armhf 4.91+dfsg-1 [307 kB]
                                          Es wurden 307 kB in 2 s geholt (196 kB/s).
                                          Vormals nicht ausgewähltes Paket lsof wird gewählt.
                                          (Lese Datenbank ... 53671 Dateien und Verzeichnisse sind derzeit installiert.)
                                          Vorbereitung zum Entpacken von .../lsof_4.91+dfsg-1_armhf.deb ...
                                          Entpacken von lsof (4.91+dfsg-1) ...
                                          lsof (4.91+dfsg-1) wird eingerichtet ...
                                          Trigger für man-db (2.8.5-2) werden verarbeitet ...
                                          pi@DELO0150:~ $ sudo lsof /opt/iobroker/iobroker-data/objects.jsonl
                                          COMMAND    PID     USER   FD   TYPE DEVICE  SIZE/OFF   NODE NAME
                                          iobroker. 1226 iobroker   19u   REG  179,2 972533859 261398 /opt/iobroker/iobroker-data/objects.jsonl
