  4. js-controller lässt sich nicht updaten...
    1.7k
35 Beiträge 3 Kommentatoren 2.8k Aufrufe 3 Beobachtet
  • Mr. BurnsM Mr. Burns
    Das Ergebnis des update Versuchs vor dem neuen update:
    iobroker upgrade self --debug
    Update js-controller from @4.0.21 to @4.0.23
    Stopped Objects DB
    Stopped States DB
    NPM version: 8.19.2
    Installing iobroker.js-controller@4.0.23... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated appdirectory@0.1.0: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/openzwave-shared
    npm ERR! command failed
    npm ERR! command sh -c -- node-gyp rebuild
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird betreten
    npm ERR!   CXX(target) Release/obj.target/openzwave_shared/src/callbacks.o
    npm ERR! make: Verzeichnis „/opt/iobroker/node_modules/openzwave-shared/build“ wird verlassen
    npm ERR! gyp info it worked if it ends with ok
    npm ERR! gyp info using node-gyp@9.1.0
    npm ERR! gyp info using node@16.17.1 | linux | arm
    npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"
    npm ERR! gyp info spawn /usr/bin/python3
    npm ERR! gyp info spawn args [
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
    npm ERR! gyp info spawn args   'binding.gyp',
    npm ERR! gyp info spawn args   '-f',
    npm ERR! gyp info spawn args   'make',
    npm ERR! gyp info spawn args   '-I',
    npm ERR! gyp info spawn args   '/opt/iobroker/node_modules/openzwave-shared/build/config.gypi',
    npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
    npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/16.17.1/include/node/common.gypi',
    npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
    npm ERR! gyp info spawn args   '-Dvisibility=default',
    npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/16.17.1',
    npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
    npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/16.17.1/<(target_arch)/node.lib',
    npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/openzwave-shared',
    npm ERR! gyp info spawn args   '-Dnode_engine=v8',
    npm ERR! gyp info spawn args   '--depth=.',
    npm ERR! gyp info spawn args   '--no-parallel',
    npm ERR! gyp info spawn args   '--generator-output',
    npm ERR! gyp info spawn args   'build',
    npm ERR! gyp info spawn args   '-Goutput_dir=.'
    npm ERR! gyp info spawn args ]
    npm ERR! gyp info spawn make
    npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
    npm ERR! In file included from /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8.h:30,
    npm ERR!                  from ../src/openzwave.hpp:27,
    npm ERR!                  from ../src/callbacks.cc:18:
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
    npm ERR!   492 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
    npm ERR!       |                                      ^~~~~~~~~~~
    npm ERR!       |                                      remove_cv
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:50: error: template argument 2 is invalid
    npm ERR!       |                                                  ^
    npm ERR! /home/iobroker/.cache/node-gyp/16.17.1/include/node/v8-internal.h:492:63: error: ‘::Perform’ has not been declared
    npm ERR!       |                                                               ^~~~~~~
    npm ERR! make: *** [openzwave_shared.target.mk:148: Release/obj.target/openzwave_shared/src/callbacks.o] Fehler 1
    npm ERR! gyp ERR! build error
    npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
    npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:201:23)
    npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:513:28)
    npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
    npm ERR! gyp ERR! System Linux 5.15.61-v7l+
    npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/openzwave-shared
    npm ERR! gyp ERR! node -v v16.17.1
    npm ERR! gyp ERR! node-gyp -v v9.1.0
    npm ERR! gyp ERR! not ok
    npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T16_58_37_038Z-debug-0.log
    Teil 2:
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.17.1
    v16.17.1
    8.19.2
    4.0.21
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    /home
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://repos.influxdata.com/debian bullseye InRelease
    OK:4 https://phoscon.de/apt/deconz bullseye InRelease
    OK:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Aktualisierung für 4 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
    nodejs:
     Installiert:           16.17.1-deb-1nodesource1
     Installationskandidat: 16.17.1-deb-1nodesource1
     Versionstabelle:
    *** 16.17.1-deb-1nodesource1 500
           500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
           100 /var/lib/dpkg/status
        12.22.12~dfsg-1~deb11u1 500
           500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
    [/s]
    @mr-burns sagte in js-controller lässt sich nicht updaten...:
    Lass die Finger von individuellen Updates von npm. Egal ob das irgendwo empfohlen wird.
    iobroker stop
    sudo apt update
    sudo apt full-upgrade
    sudo apt install --reinstall nodejs
    cd /opt/iobroker
    sudo -H -u iobroker npm cache clear --force
    sudo reboot
      Stopped Objects DB
      Stopped States DB
      NPM version: 8.19.2
      npm ERR! code 1
      npm ERR!       |                                                  ^
      npm ERR!       |                                                               ^~~~~~~
      Teil 2:
      armv7l
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      8.19.2
      4.0.21
      pi
      /home
      nodejs:
       Versionstabelle:
      [/s]
      @mr-burns
      Warum wird da eigentlich openzwave gebaut?
      Wenn ich der readme von zwave2 vertrauen darf wird das (anders als iobroker.zwave) da garnicht benötigt?
      Was haste da also am Start?
      iob update -i
      Mr. BurnsM 1 Antwort Letzte Antwort
        @mr-burns
        iob update -i
        Mr. BurnsM Offline
        Mr. BurnsM Offline
        Mr. Burns
        @thomas-braun Das ist ein gute Frage...kann ich nicht beantworten.
        Ich habe die zwave adapter installiert aber nicht aktiviert (haben nicht funktioniert oder so, weiß nicht mehr genau)
          Das Zeug spukt da aber noch herum.
          Kein Wunder...
            Kein Wunder...
            Mr. BurnsM Offline
            Mr. BurnsM Offline
            Mr. Burns
            iob update -i
            Used repository: stable
            Adapter    "admin"        : 6.2.22   , installed 6.2.22
            Adapter    "amazon-dash"  : 1.1.0    , installed 0.3.1  [Updatable]
            Adapter    "backitup"     : 2.4.12   , installed 2.4.12
            Adapter    "ble"          : 0.13.0   , installed 0.13.0
            Adapter    "bsblan"       : 0.2.2    , installed 0.2.2
            Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "flot"         : 1.11.0   , installed 1.11.0
            Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
            Adapter    "geofency"     : 1.1.1    , installed 1.1.1
            Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "history"      : 2.2.0    , installed 2.2.0
            Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
            Adapter    "homekit-controller": 0.5.1, installed 0.5.1
            Adapter    "ical"         : 1.13.1   , installed 1.13.1
            Adapter    "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-mfd-png": 1.1.0    , installed 1.1.0
            Adapter    "icons-mfd-svg": 1.1.0    , installed 1.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "icons-ultimate-png": 1.0.1, installed 1.0.1
            Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
            Adapter    "info"         : 1.9.19   , installed 1.9.19
            Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
            Adapter    "javascript"   : 6.0.3    , installed 6.0.3
            Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
            Adapter    "mielecloudservice": 6.3.2, installed 6.3.2
            Adapter    "mihome"       : 1.4.0    , installed 1.4.0
            Adapter    "mihome-vacuum": 3.4.2    , installed 3.4.2
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "modbus"       : 5.0.5    , installed 5.0.5
            Adapter    "openweathermap": 0.3.0   , installed 0.3.0
            Adapter    "paw"          : 0.3.2    , installed 0.3.2
            Adapter    "proxy"        : 1.3.1    , installed 1.3.1
            Adapter    "pushover"     : 3.0.3    , installed 3.0.3
            Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
            Adapter    "s7"           : 1.3.13   , installed 1.3.13
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
            Adapter    "socketio"     : 4.2.0    , installed 4.2.0
            Adapter    "sonos"        : 2.2.3    , installed 2.2.3
            Adapter    "synology"     : 2.1.9    , installed 2.1.9
            Adapter    "telegram"     : 1.14.1   , installed 1.14.1
            Adapter    "terminal"     : 0.2.6    , installed 0.2.6
            Adapter    "tinker"       : 1.1.1    , installed 1.1.1
            Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
            Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
            Adapter    "trashschedule": 2.0.3    , installed 2.0.3
            Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
            Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
            Adapter    "vis-plumb"    : 1.0.2    , installed 1.0.2
            Adapter    "vis-rgraph"   : 0.0.2    , installed 0.0.2
            Adapter    "weatherunderground": 3.4.2, installed 3.4.2
            Adapter    "web"          : 4.3.0    , installed 4.3.0
            Adapter    "ws"           : 1.3.0    , installed 1.3.0
            Adapter    "yahka"        : 0.13.1   , installed 0.13.1
            Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
            Adapter    "zwave2"       : 3.0.3    , installed 3.0.3
              iob update -i
              @mr-burns
              Hast du jetzt die Befehle aus Post #21 ausgeführt?
                @mr-burns
                Mr. BurnsM Offline
                Mr. BurnsM Offline
                Mr. Burns
                schrieb am zuletzt editiert von Mr. Burns
                Ja...versuche gerade wieder ein update vom js-controller
                Ergebnis:
                Stopped Objects DB
                Stopped States DB
                NPM version: 8.15.0
                npm ERR! code 1
                npm ERR! command sh /tmp/install-568a43d9.sh
                npm ERR! gyp info using node-gyp@9.0.0
                npm ERR!       |                                                  ^
                npm ERR!       |                                                               ^~~~~~~
                npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                npm ERR! gyp ERR! node-gyp -v v9.0.0
                npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T17_36_01_287Z-debug-0.log
                [/s]
                  Ergebnis:
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 8.15.0
                  npm ERR! code 1
                  npm ERR!       |                                                  ^
                  npm ERR!       |                                                               ^~~~~~~
                  [/s]
                  openzwave-shared
                  Schmeiß den Kram mal raus.
                  cd /opt/iobroker
                  npm ls openzwave-shared
                  sudo -H -u iobroker npm uninstall openzwave-shared
                    openzwave-shared
                    cd /opt/iobroker
                    Mr. BurnsM Offline
                    Mr. BurnsM Offline
                    Mr. Burns
                    War nicht so erfolgreich:
                    npm ERR! code 1
                    npm ERR! command sh /tmp/install-6a225777.sh
                    npm ERR!       |                                                  ^
                    npm ERR!       |                                                               ^~~~~~~
                    npm ERR!     /home/iobroker/.npm/_logs/2022-09-30T18_02_11_700Z-debug-0.log
                    [/s]
                      npm ERR! code 1
                      npm ERR!       |                                                  ^
                      npm ERR!       |                                                               ^~~~~~~
                      [/s]
                      cd /opt/iobroker
                        cd /opt/iobroker
                        Mr. BurnsM Offline
                        Mr. BurnsM Offline
                        Mr. Burns
                        Das hatte ich vorher ausgeführt...oder?
                        iobroker.inst@2.0.3 /opt/iobroker
                        └─┬ iobroker.zwave@2.0.1
                          └── openzwave-shared@1.7.2
                          iobroker.zwave
                          Wo kommt der denn noch her?
                          iobroker del zwave
                            iobroker.zwave
                            iobroker del zwave
                            Mr. BurnsM Offline
                            Mr. BurnsM Offline
                            Mr. Burns
                            Habe die beiden adapter über die web Konsole von Biobroker deinstalliert und die beiden befehle noch mal ausgeführt. Mit dem selben Ergebnis.
                            zwischenzeitlich kam dein neuer post, welchen ich ausgeführt habe, nachdem die Deinstallation (oder der versuch) abgeschlossen war.
                            Beim letzten hängt er jetzt noch...
                            iobroker del zwave
                            Delete adapter "zwave"
                            host.ioBroker Counted 1 meta of zwave
                            host.ioBroker Counted 1 adapter for zwave
                            host.ioBroker file zwave.admin deleted
                            host.ioBroker object zwave deleted
                            host.ioBroker object zwave.admin deleted
                            host.ioBroker Deleting 2 object(s).
                            Wenn der Biobroker läuft, gehen fast alle adapter bis auf der javascript.0 ist das evtl. noch ein weiteres Symptom?
                              iobroker del zwave
                              @mr-burns
                              Irgendwie kann ich dir nicht folgen.
                              cd /opt/iobroker
                              npm ls
                                @mr-burns
                                cd /opt/iobroker
                                npm ls
                                Mr. BurnsM Offline
                                Mr. BurnsM Offline
                                Mr. Burns
                                @thomas-braun @DJMarc75
                                Danke für eure Unterstützung!
                                Am Ende hab ich es nicht hinbekommen. Also hab ich eine neue SD-Karte gekauft, neu aufgesetzt und Backup eingespielt.
                                Es läuft fast alles wieder...schönen Sonntag.
