  4. Widget wird aktiviert beim überfahren mit Mauszeiger
    6.0k
6 Beiträge 2 Kommentatoren 399 Aufrufe 2 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    wendy2702
    ich habe in meiner VIS (1.4.15) einige Taster Widgets wie dieses hier:
    [{"tpl":"tplHqButton","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"hm-rpc.0.MEQ0675904.1.LEVEL","min":"0","max":"","iconName":"/icons-mfd-png/control_centr_arrow_down.png","btIconWidth":"75","offsetAuto":true,"leftOffset":"35","topOffset":"0","timeAsInterval":"true","infoLeftFontSize":"12","infoFontRightSize":"12","infoLeftPaddingLeft":"15","infoLeftPaddingRight":"50","infoRightPaddingRight":"15","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"pushButton":true,"oid-working":"hm-rpc.0.MEQ0675904.1.WORKING","descriptionLeft":"Rollladen Arbeitszimmer Vorne.LEVEL","descriptionLeftDisabled":true,"usejQueryStyle":true,"iconOn":"","changeEffect":"","testActive":false,"name":"Rolllade BAD runter"},"style":{"left":"5px","top":"202px","width":"70px","height":"114px","border-width":"1px","border-style":"solid","border-color":"#FFFFFF","border-radius":"2px","z-index":"5"},"widgetSet":"hqwidgets"}]
    Wenn ich die VIS jetzt im Browser öffne Chrome/Firefox und nur schon den Mauszeiger darüber bewege wird die Aktion ausgeführt, ich muss das Widget nicht extra anklicken.
    Ist das eine Einstellung vom Widget, Browser oder woher kommt diese störende verhalten?
    Danke und Gruß
    • wendy2702W wendy2702
      Danke und Gruß
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @wendy2702 sagte in Widget wird aktiviert beim überfahren mit Mauszeiger:
      Sehr komisches verhalten ...
      habe auch den Homematic Rollladen-Aktor Datenpunkt auf meinen umgeändert , damit ich 1:1 testen kann und den gleichen Effekt mit dem Mouseover .
      Muß eher sagen , ich habe andere Widget´s und dies ist mir noch nie aufgefallen , ob es ein Bug ist bei einem Wert von 0 ..100 bei einem Aktor
      Dieses wird angesteuert ... aber soweit kenne ich mich nicht aus .
      ich habe mal einen Testdatenpunkt genommen um zu sehen was er macht bei Mouseover.
      Er setzt den angegeben Datenpunkt immer auf den Wert 33 von dem eingetragenen Wert min
      Noch was verrücktes !!
      Bei einem Wert **true ** im min , schreibt er beim Mouesover " true " in den Datenpunkt
      Dabei wird auch ein Schaltaktor Aktor angeschaltet
      Also Licht aus , Mouseover macht true , Licht an , "klicke" drauf licht aus
      ich denke mal das kommt von hier :
        wendy2702W Offline
        wendy2702
        @glasfaser Hi,
        Danke für deine Untersuchungen.
        Ich denke dann hilft nur ein Issue aber wobei? VIS oder den Widgets ?
        Welches Widget für Rollladen verwendest du?
        • GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @wendy2702
          Eher beim Widget das Issues machen .
          Nutze das hier :
          • GlasfaserG Glasfaser
            @wendy2702
            Nutze das hier :
            wendy2702W Offline
            wendy2702W Offline
            wendy2702
            @glasfaser Nutzt du Shuttercontrol ?
              GlasfaserG Offline
              GlasfaserG Offline
              Glasfaser
              @wendy2702
              Nee ...
              das hier :
              https://forum.iobroker.net/topic/23346/vorlage-variable-zeitsteuerung-mit-vis-editor
              EDIT:
              sah so am Anfang aus
              https://forum.iobroker.net/post/274912
