  4. Canvas Package korrekt installieren
    5.4k
32 Beiträge 3 Kommentatoren 2.7k Aufrufe 5 Beobachtet
  • Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    schrieb am zuletzt editiert von Damrak2022
    Nur ein kurze Frage,
    da ich im Protokoll sehe das mir das Canvas Package fehlt, würde ich gerne wissen mit welchem Befehl ich das korrekt installiere?
    2022-08-23 18:35:57.941	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      @damrak2022
      Error at installation
      if your installation runs in error. The canvas package could not be installed
      npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
      Please install canvas and the libs manually with:
      sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
      switch into :
      cd /opt/iobroker/node_modules/iobroker.mihome-vacuum
      npm install canvas --unsafe-perm=true
      Damrak2022D 2 Antworten Letzte Antwort
        @damrak2022
        switch into :
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        Das wird mir anschließend ausgegeben:
        pi@homebridge:~ $ sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
        Reading package lists... Done
        Building dependency tree... Done
        build-essential is already the newest version (12.9).
        libgif-dev is already the newest version (5.1.9-2).
        libjpeg-dev is already the newest version (1:2.0.6-4).
        librsvg2-dev is already the newest version (2.50.3+dfsg-1).
        libpango1.0-dev is already the newest version (1.46.2-3).
        libcairo2-dev is already the newest version (1.16.0-5+rpt1).
        0 upgraded, 0 newly installed, 0 to remove and 66 not upgraded.
        pi@homebridge:~ $ cd /opt/iobroker/node_modules/iobroker.mihome-vacuum
        pi@homebridge:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ sudo npm install canvas --unsafe-perm=true
        npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
        npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
        npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
        npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        added 676 packages, changed 1 package, and audited 678 packages in 3m
        53 packages are looking for funding
          run `npm fund` for details
        6 high severity vulnerabilities
        To address issues that do not require attention, run:
          npm audit fix
        To address all issues (including breaking changes), run:
          npm audit fix --force
        Run `npm audit` for details.
        npm notice
        npm notice New minor version of npm available! 8.11.0 -> 8.18.0
        npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.18.0
        npm notice Run npm install -g npm@8.18.0 to update!
        npm notice
        Mit besten Grüßen
        Andy
            npm audit fix
          npm notice
          npm notice
          @damrak2022 sagte in Canvas Package korrekt installieren:
          Bring dein System auf Stand!
          Hinter die Ohren schreiben und regelmäßig einmal in der Woche ausführen:
          iobroker stop
          sudo apt update
          sudo apt full-upgrade
          sudo reboot
            iobroker stop
            sudo apt update
            sudo reboot
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            @thomas-braun Okay, mache ich. Mir war nicht bewusst das ich das so häufig machen sollte. Aber ich werde das befolgen.
            Mit besten Grüßen
            Andy
            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
              @damrak2022
              Ich hatte oben auch einen Fehler drin.
              Wenn das System auf Stand ist und wieder läuft:
              iobroker stop
              iobroker fix
              iobroker start
                @damrak2022 Deine Windose macht das bei jedem Start.
                warum nicht bei Linux?
                Wenn es alle 2 Wochen sind ist auch gut, aber wie lange hast du es nicht mehr gemacht bei 66 alten Paketen?
                  Mit 66 Updates in der Pipeline machst du es entweder nicht häufig genug oder du hast da den ganzen Desktop-Zirkus mitlaufen. Oder beides.
                    iobroker stop
                    sudo apt update
                    sudo reboot
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    @thomas-braun Nach dem sudo reboot bekomme ich das:
                    pi@homebridge:~ $ sudo reboot
                    Connection to homebridge closed by remote host.
                    Connection to homebridge closed.
                    Nach kurzer Wartezeit kommt das:
                    damrak2022@iMac ~ % sudo reboot
                    Password:
                    Sorry, try again.
                    Password:
                    Sorry, try again
                    Das ist doch das gleiche Passwort mit dem ich mich per ssh anmelde, oder?
                    Mit besten Grüßen
                    Andy
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      @homoran Nein Desktop nutze ich nicht, aber ich muss zugeben, das ich es sehr lange nicht gemacht habe.
                      Mit besten Grüßen
                      Andy
                        Password:
                        Sorry, try again.
                        Password:
                        Sorry, try again
                        Das sind andere Hosts...
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          @thomas-braun Okay, nach dem dritten Fehlversuch musste ich mich neu anmelden. Dann habe ich noch den stop - fix und start durchlaufen lassen.
                          Somit sollte jetzt alles passen. Der Fehler im Log ist auch weg - Danke
                          Mit besten Grüßen
                          Andy
                            @damrak2022
                            cd /opt/iobroker
                            npm ls canvas
                            sagt?
                              @damrak2022
                              cd /opt/iobroker
                              npm ls canvas
                              sagt?
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              @thomas-braun Da kommt folgendes:
                              pi@homebridge:~ $ cd/opt/iobroker
                              -bash: cd/opt/iobroker: No such file or directory
                              pi@homebridge:~ $
                              Mit besten Grüßen
                              Andy
                                pi@homebridge:~ $
                                @damrak2022 Hinter dem Kommando cd (Change directory) kommt ein Leerzeichen.
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  @thomas-braun So jetzt richtig:
                                  pi@homebridge:/opt/iobroker $ npm ls canvas
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├─┬ iobroker.echarts@1.0.12
                                  │ ├── canvas@2.9.3
                                  │ └─┬ jsdom@19.0.0
                                  │   └── canvas@2.9.3 deduped
                                  ├─┬ iobroker.iot@1.11.8
                                  │ └── canvas@2.9.3
                                  └─┬ iobroker.mihome-vacuum@3.4.2
                                    └── canvas@2.9.3
                                  Mit besten Grüßen
                                  Andy
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    @thomas-braun Ich muss mal nachfragen da im Protokoll stand das kein Canvas installiert ist. Also habe ich es nach Deiner Anleitung nachinstalliert und vorher alles aktualisiert und auch einen fix durchgeführt.
                                    Nun bekomme ich diese Ausgabe:
                                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                                    pi@homebridge:/opt/iobroker/node_modules/iobroker.mihome-vacuum $ npm install canvas --unsafe-perm=true
                                    added 678 packages, and audited 679 packages in 2m
                                    55 packages are looking for funding
                                      npm audit fix
                                    Ist das jetzt alles korrekt oder muss ich hier irgendwo Hand anlegen. Falls ja, was muss ich genau eingeben?
                                    Im Log steht allerdings immer noch:
                                    2022-10-13 22:54:21.038	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                                    Mit besten Grüßen
                                    Andy
                                        npm audit fix
                                      @damrak2022
                                      cd /opt/iobroker
                                      npm ls canvas
                                        @damrak2022
                                        cd /opt/iobroker
                                        npm ls canvas
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        @thomas-braun sagte in (Gelöst) Canvas Package korrekt installieren:
                                        npm ls canvas
                                        │ ├── canvas@2.9.3
                                        │ └─┬ jsdom@19.0.0
                                        ├─┬ iobroker.iot@1.11.9
                                        ├─┬ iobroker.mihome-vacuum@3.4.2
                                        │ └── canvas@2.10.1
                                        └─┬ iobroker.parcel@0.0.23
                                          └─┬ jsdom@20.0.1
                                        Aber weiterhin die Meldung im Log:
                                        2022-10-14 00:36:14.562	warn	CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                                        Wieso habe ich immer noch diese Warnmeldung und was kann ich jetzt noch machen?
                                        Mit besten Grüßen
                                        Andy
                                          npm ls canvas
                                          │ ├── canvas@2.9.3
                                          │ └─┬ jsdom@19.0.0
                                          │ └── canvas@2.10.1
                                            └─┬ jsdom@20.0.1
                                          Installier den mal neu. Log File beobachten.
