  4. [Gelöst] Beim updaten der Adapter "cannot upgrade:DB closed"
    5.8k
11 Beiträge 3 Kommentatoren 993 Aufrufe 3 Beobachtet
  • Bahadir ErgüllüB Offline
    Bahadir Ergüllü
    schrieb am zuletzt editiert von Bahadir Ergüllü
    habe folgenden Fehler beim updaten der Adapter und komme leider nicht weiter.
    IOB fix
    IOB update / Upgrade habe ich schon durch.
    $ iobroker upgrade backitup@2.4.10
    Update backitup from @2.4.6 to @2.4.10
    host.bahadir-Virtual-Machine Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 8.15.0
    Installing iobroker.backitup@2.4.10... (System call)
    host.bahadir-Virtual-Machine Cannot install iobroker.backitup@2.4.10: 217
    host.bahadir-Virtual-Machine Adapter "system.adapter.backitup.0" is started
    Cannot upgrade: DB closed
    ERROR: Process exited with code 25bolded text
    • Bahadir ErgüllüB Bahadir Ergüllü
      IOB fix
      NPM version: 8.15.0
      @bahadir-ergüllü sagte in Beim updaten der Adapter "cannot upgrade:DB closed":
      iobroker upgrade backitup@2.4.10 --debug
      NPM version: 8.15.0
      ist auch mit Sicherheit nicht die für dein nodeJS16 vorgesehene Version, da ist noch 8.11.0 der letzte Stand.
      Bahadir ErgüllüB 1 Antwort Letzte Antwort
        NPM version: 8.15.0
        Bahadir Ergüllü
        @thomas-braun said in Beim updaten der Adapter "cannot upgrade:DB closed":
        code_text
        ```Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y
        NPM version: 8.15.0
        npm ERR! code ENOTEMPTY
        npm ERR! syscall rename
        npm ERR! path /opt/iobroker/node_modules/@babel/runtime
        npm ERR! dest /opt/iobroker/node_modules/@babel/.runtime-cSN2FFol
        npm ERR! errno -39
        npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@babel/runtime' -> '/opt/iobroker/node_modules/@babel/.runtime-cSN2FFol'
        npm ERR!     /home/iobroker/.npm/_logs/2022-08-05T08_52_53_609Z-debug-0.log
        Cannot set system.adapter.backitup: DB closed
         Cannot find view "system" for search "instance" : Connection is closed.
        Cannot upgrade: Cannot find view "system"
          code_text
          NPM version: 8.15.0
          npm ERR! errno -39
          @bahadir-ergüllü
          Wie bist du da jetzt unterwegs?
          uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          Zum 'Problem':
          cd /opt/iobroker/node_modules
          for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
            @bahadir-ergüllü
            Zum 'Problem':
            Bahadir Ergüllü
            zu 1.
            [10:53:01] root@bahadir-Virtual-Machine:~# sudo ln -s /usr/bin/node /usr/bin/nodejs
            ln: Die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
            [11:03:29] root@bahadir-Virtual-Machine:~# uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v18.7.0
            v18.7.0
            8.15.0
            root
            /root
            Zu 2.
            [11:04:23] root@bahadir-Virtual-Machine:/opt/iobroker/node_modules# for i in $(ls -d .[^.]*-*/); do rm -rf ${i%%/}; done
            ls: Zugriff auf '.[^.]*-*/' nicht möglich: Datei oder Verzeichnis nicht gefunden
            code_text
            Ich weiß leider nicht weiter.
            Thomas BraunT G 2 Antworten Letzte Antwort
              zu 1.
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v18.7.0
              v18.7.0
              8.15.0
              root
              /root
              Zu 2.
              code_text
              @bahadir-ergüllü
              Warum root und warum nodejs18?
                zu 1.
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v18.7.0
                v18.7.0
                8.15.0
                root
                /root
                Zu 2.
                code_text
                guergen
                @bahadir-ergüllü Warum müsst ihr alle als root angemeldet sein? 50% der Probleme kommen davon!
                Linux ist nicht umsonst ein Multiuser-System!
                  @bahadir-ergüllü
                  Bahadir Ergüllü
                  Hallo Thomas,
                  aus Unwissenheit. Habe mein SSH Verbindung so hinbekommen.
                    Hallo Thomas,
                    @bahadir-ergüllü
                    Dann schau dir jetzt an wie man gescheit mit usern arbeitet und lass den root in Ruhe.
                    Und warum nodejs18? Die Version ist nicht die vorgesehene und wird daher auch nicht vom ioBroker-Installer installiert, die musst du bewusst installiert haben. Ich frag mich nur warum?
                      @bahadir-ergüllü
                      Bahadir Ergüllü
                      @thomas-braun Wahrscheinlich aus versehen.
                      Ich kümmere mich um den SSH Zugang und deinstalliere dann Nodejs18
                        Bahadir Ergüllü
                        @bahadir-ergüllü Das Problem wurde folgendermaßen gelöst von mir.
                        nodejs wurde auf Version 14.x downgegradet.
                        iob darüber neu installiert mit folgendem Befehl :
                        curl -sLf https://iobroker.net/install.sh | bash -
                        Alle Daten und Adapter sind noch vorhanden und können jetzt ohne Problem upgedatet werden.
                        Danke für die Hilfe.
