  3. Einsteigerfragen
  4. Fehler bei Boschintegration
    5.6k
bosch iobroker
4 Beiträge 3 Kommentatoren 440 Aufrufe 2 Beobachtet
  • Jörg KnechtenJ Offline
    Jörg Knechten
    Hi. Habe ein Problem mit der Integration Bosch Smart Home / IOBroker.
    Alles lt. Video von "verdrahtet soweit durchgeführt. BOSCH Controller Taste gedrückt....
    Und denn kommt das als Protokoll. Komme leider nicht weiter.
    HomoranH S 2 Antworten Letzte Antwort
    • Jörg KnechtenJ Jörg Knechten
      @jörg-knechten Text bitte als Text in code-tags posten
      Keine Screenshots.
        Smartuser_1
        @jörg-knechten
        ich habe leider das gleiche Problem. Hast Du eine Lösung gefunden?
        host.raspberrypi
        2022-07-22 00:46:04.779	warn	Do not restart adapter system.adapter.bshb.0 because restart loop detected
        host.raspberrypi
        2022-07-22 00:46:04.778	info	Restart adapter system.adapter.bshb.0 because enabled
        host.raspberrypi
        2022-07-22 00:46:04.777	error	instance system.adapter.bshb.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        bshb.0
        2914	2022-07-22 00:46:04.177	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        bshb.0
        2914	2022-07-22 00:46:04.176	info	terminating
        bshb.0
        2914	2022-07-22 00:46:04.175	info	cleaned everything up...
        bshb.0
        2914	2022-07-22 00:46:04.172	error	error during call to BSHC:
        bshb.0
        2914	2022-07-22 00:46:04.172	error	BshbError: error during call to BSHC: at BshcClient.AbstractBshcClient.handleError (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:171:32) at ClientRequest.<anonymous> (/opt/iobroker/node_modules/bosch-smart-home-bridge/dist/api/abstract-bshc-client.js:155:23) at ClientRequest.emit (events.js:400:28) at TLSSocket.socketErrorListener (_http_client.js:475:9) at TLSSocket.emit (events.js:400:28) at emitErrorNT (internal/streams/destroy.js:106:8) at emitErrorCloseNT (internal/streams/destroy.js:74:3) at processTicksAndRejections (internal/process/task_queues.js:82:21)
        bshb.0
        2914	2022-07-22 00:46:04.170	error	uncaught exception: error during call to BSHC:
        bshb.0
        2914	2022-07-22 00:46:03.688	info	Start detecting open doors/windows...
        bshb.0
        2914	2022-07-22 00:46:03.674	info	Start detecting devices...
        bshb.0
        2914	2022-07-22 00:46:03.668	info	Start detecting intrusion detection system...
        bshb.0
        2914	2022-07-22 00:46:03.666	info	Start detecting messages...
        Jörg KnechtenJ 1 Antwort Letzte Antwort
        • S Smartuser_1
          @jörg-knechten
          host.raspberrypi
          host.raspberrypi
          host.raspberrypi
          bshb.0
          bshb.0
          bshb.0
          bshb.0
          bshb.0
          bshb.0
          bshb.0
          bshb.0
          bshb.0
          bshb.0
          Jörg Knechten
          @smartuser_1
          kleines Update. JA. Das Passwort wurde nicht richtig erkannt. Nach dem ca. 20ten mal funktioniert es jetzt.
