  4. info Adapter: Cannot read property 'log' of undefined
    5.8k
4 Beiträge 2 Kommentatoren 608 Aufrufe 2 Beobachtet
  • FoggF Offline
    FoggF Offline
    Fogg
    schrieb am zuletzt editiert von Fogg
    seit neustem stürzt mein info-Adapter ab. Er sucht wohl ein log-Objekt was er nicht hat. Hier der Fehler:
    2022-06-25 17:51:33.300 - error: host.xxxx-Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/usr/local/iobroker/iobroker-data/objects.jsonl"!
    2022-06-25 17:51:33.411 - error: host.xxxx Caught by controller[0]: dyld: lazy symbol binding failed: Symbol not found: ____chkstk_darwin
    2022-06-25 17:51:33.411 - error: host.xxxx Caught by controller[0]: Referenced from: /usr/local/bin/node (which was built for Mac OS X 10.15)
    2022-06-25 17:51:33.411 - error: host.xxxx Caught by controller[0]: Expected in: /usr/lib/libSystem.B.dylib
    2022-06-25 17:51:33.411 - error: host.xxxx Caught by controller[0]: dyld: Symbol not found: ____chkstk_darwin
    2022-06-25 17:51:33.411 - error: host.xxxx Caught by controller[1]: /usr/local/iobroker/node_modules/iobroker.info/main.js:88
    2022-06-25 17:51:33.411 - error: host.xxxx Caught by controller[1]: adapter.log.error("Could not check npm version: " + e);
    2022-06-25 17:51:33.411 - error: host.xxxx Caught by controller[1]: ^
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: TypeError: Cannot read property 'log' of undefined
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at getSystemVersions (/usr/local/iobroker/node_modules/iobroker.info/main.js:88:11)
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at Object. (/usr/local/iobroker/node_modules/iobroker.info/main.js:57:18)
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at Module.load (internal/modules/cjs/loader.js:950:32)
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
    2022-06-25 17:51:33.412 - error: host.xxxx Caught by controller[1]: at internal/main/run_main_module.js:17:47
    2022-06-25 17:51:33.412 - error: host.xxxx instance system.adapter.info.0 terminated with code 1 (JS_CONTROLLER_STOPPED)```
    Ich habe
    - jsController 4.0.23
    - info-Adapter 1.9.19
    Gruss,
    Fogg
    • FoggF Fogg
      Ich habe
      Gruss,
      Fogg
      @fogg
      Das ganze läuft auf? MacOS?
      Da scheinen mir unpassende Versionen installiert zu sein.
      FoggF 1 Antwort Letzte Antwort
        @fogg
        FoggF Offline
        FoggF Offline
        Fogg
        @thomas-braun Ja, auf einem recht alten Mac Mini. Ging bis jetzt ganz gut, vermutlich das letzte Update was schief lief.
        • FoggF Fogg
          @fogg
          Da wird wohl nodejs gegen eine geänderte ABI gebaut werden müssen.
