  4. Legacy Adapter schmiert ab
    5.4k
6 Beiträge 4 Kommentatoren 1.6k Aufrufe
  • K Offline
    klassisch
    wenn ich den Legacy Adapter aktiviere, schmiert er sofort wieder ab. Auszug aus dem Logfile:
    host-raspberrypi	2015-05-28 06:00:28	info	Restart adapter system.adapter.legacy.0 because enabled
    host-raspberrypi	2015-05-28 06:00:28	error	instance system.adapter.legacy.0 terminated with code 6 (uncaught exception)
    legacy-0	2015-05-28 06:00:28	info	terminating http server
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.uptime val=245376, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432785628
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.memHeapUsed val=14.77, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432785628
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.memHeapTotal val=29.58, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432779852
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.memRss val=42.86, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432785493
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.connected val=true, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432540256
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.web.0.alive val=true, ack=true, ts=1432785628, from=system.adapter.web.0, lc=1432540256
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.uptime val=40521, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785628
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.memHeapUsed val=19.1, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785628
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.memHeapTotal val=35.39, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785583
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.memRss val=49.98, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432785583
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.connected val=true, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432745114
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.admin.0.alive val=true, ack=true, ts=1432785628, from=system.adapter.admin.0, lc=1432745114
    inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.KEQ0194610.1.BRIGHTNESS val=147, ack=true, ts=1432785628, from=system.adapter.hm-rpc.0, lc=1432785628
    inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0513285.1.ERROR val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1430495196
    inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0513285.1.VALVE_STATE val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1432756988
    inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0510473.2.ADJUSTING_DATA val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1432756806
    inMem	2015-05-28 06:00:28	debug	message * hm-rpc.0.HEQ0510473.2.ADJUSTING_COMMAND val=0, ack=true, ts=1432785626, from=system.adapter.hm-rpc.0, lc=1432756988
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.connected val=true, ack=false, ts=1432785626, lc=1432753176
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.uptime val=32451, ack=true, ts=1432785623, from=system.adapter.hm-rpc.0, lc=1432785623
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.memHeapUsed val=16.46, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432785622
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.memHeapTotal val=31.51, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432784167
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.memRss val=43.98, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432784166
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.connected val=true, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432753176
    inMem	2015-05-28 06:00:28	debug	message * system.adapter.hm-rpc.0.alive val=true, ack=true, ts=1432785622, from=system.adapter.hm-rpc.0, lc=1432753176
    inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.uptime val=245385, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
    inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.memHeapUsed val=39.5, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
    inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.memHeapTotal val=54.59, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
    inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.memRss val=94.91, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
    inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.mem val=19, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
    inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.load val=0.58, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432785620
    inMem	2015-05-28 06:00:28	debug	message * system.host.raspberrypi.alive val=true, ack=true, ts=1432785620, from=system.host.raspberrypi, lc=1432745307
    TypeError:	2015-05-28 06:00:28	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    TypeError:	2015-05-28 06:00:28	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2015-05-28 06:00:28	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
    TypeError:	2015-05-28 06:00:28	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    TypeError:	2015-05-28 06:00:28	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2015-05-28 06:00:28	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
    TypeError:	2015-05-28 06:00:28	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
    TypeError:	2015-05-28 06:00:28	error	at Socket. (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:416:17)
    TypeError:	2015-05-28 06:00:28	error	at obj2rega (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:344:102)
    TypeError:	2015-05-28 06:00:28	error	at translate (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:107:14)
    TypeError:	2015-05-28 06:00:28	error	Cannot read property 'words' of undefined
    uncaught	2015-05-28 06:00:28	error	exception: Cannot read property 'words' of undefined
    legacy-0	2015-05-28 06:00:27	info	creating ccu.io objects
    legacy-0	2015-05-28 06:00:19	info	received all objects
    legacy-0	2015-05-28 06:00:17	info	webserver listening on port 8088
    legacy-0	2015-05-28 06:00:16	info	starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.legacy
    legacy-0	2015-05-28 06:00:16	debug	statesDB connected
    legacy-0	2015-05-28 06:00:16	debug	objectDB connected
    host-raspberrypi	2015-05-28 06:00:13	info	instance system.adapter.legacy.0 started with pid 18115
    host-raspberrypi	2015-05-28 06:00:13	info	object change system.adapter.legacy.0
    host-raspberrypi	2015-05-28 05:59:59	info	instance system.adapter.legacy.0 terminated with code 0 (OK)
    legacy-0	2015-05-28 05:59:59	info	terminating
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.legacy.0.alive val=false, ack=true, ts=1432785599, from=system.adapter.legacy.0, lc=1432785599
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.uptime val=245350, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785599
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.memHeapUsed val=13.76, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785599
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.memHeapTotal val=30.55, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785164
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.memRss val=42.95, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432785584
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.connected val=true, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432540255
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.hm-rega.0.alive val=true, ack=true, ts=1432785599, from=system.adapter.hm-rega.0, lc=1432540255
    legacy-0	2015-05-28 05:59:59	info	terminating http server
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.uptime val=245346, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432785598
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.memHeapUsed val=17.08, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432785598
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.memHeapTotal val=29.58, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432779852
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.memRss val=42.86, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432785493
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.connected val=true, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432540256
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.web.0.alive val=true, ack=true, ts=1432785598, from=system.adapter.web.0, lc=1432540256
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.uptime val=40491, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785598
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.memHeapUsed val=16.34, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785598
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.memHeapTotal val=35.39, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785583
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.memRss val=49.98, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432785583
    inMem	2015-05-28 05:59:59	debug	message * system.adapter.admin.0.connected val=true, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432745114
    inMem	2015-05-28 05:59:58	debug	message * system.adapter.admin.0.alive val=true, ack=true, ts=1432785598, from=system.adapter.admin.0, lc=1432745114
    inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.uptime val=32421, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432785592
    inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.memHeapUsed val=16.33, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432785592
    inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.memHeapTotal val=31.51, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432784167
    inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.memRss val=43.98, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432784166
    inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.connected val=true, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432753176
    inMem	2015-05-28 05:59:58	debug	message * system.adapter.hm-rpc.0.alive val=true, ack=true, ts=1432785592, from=system.adapter.hm-rpc.0, lc=1432753176
    inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.uptime val=245355, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
    inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.memHeapUsed val=31.51, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
    inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.memHeapTotal val=50.41, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
    inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.memRss val=89.54, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
    inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.mem val=20, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
    inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.load val=0.53, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432785590
    inMem	2015-05-28 05:59:58	debug	message * system.host.raspberrypi.alive val=true, ack=true, ts=1432785590, from=system.host.raspberrypi, lc=1432745307
    TypeError:	2015-05-28 05:59:58	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    TypeError:	2015-05-28 05:59:58	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2015-05-28 05:59:58	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:301:8)
    TypeError:	2015-05-28 05:59:58	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:134:20)
    TypeError:	2015-05-28 05:59:58	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	2015-05-28 05:59:58	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:220:12)
    TypeError:	2015-05-28 05:59:58	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:295:6)
    TypeError:	2015-05-28 05:59:58	error	at Socket. (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:416:17)
    TypeError:	2015-05-28 05:59:58	error	at obj2rega (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:344:102)
    TypeError:	2015-05-28 05:59:58	error	at translate (/opt/iobroker/node_modules/iobroker.legacy/legacy.js:107:14)
    TypeError:	2015-05-28 05:59:58	error	Cannot read property 'words' of undefined
    uncaught	2015-05-28 05:59:58	error	exception: Cannot read property 'words' of undefined
    legacy-0	2015-05-28 05:59:58	info	creating ccu.io objects
    host-raspberrypi	2015-05-28 05:59:58	info	stopInstance system.adapter.legacy.0 killing pid 18109
    host-raspberrypi	2015-05-28 05:59:58	info	object change system.adapter.legacy.0
    legacy-0	2015-05-28 05:59:50	info	received all objects
    legacy-0	2015-05-28 05:59:47	info	webserver listening on port 8088
    legacy-0	2015-05-28 05:59:47	info	starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.legacy
    legacy-0	2015-05-28 05:59:47	debug	statesDB connected
    legacy-0	2015-05-28 05:59:47	debug	objectDB connected
    host-raspberrypi	2015-05-28 05:59:43	info	instance system.adapter.legacy.0 started with pid 18109
    host-raspberrypi	2015-05-28 05:59:13	info	Restart adapter system.adapter.legacy.0 because enabled
    host-raspberrypi	2015-05-28 05:59:13	error	instance system.adapter.legacy.0 terminated with code 6 (uncaught exception)
    legacy-0	2015-05-28 05:59:12	info	creating ccu.io objects
    legacy-0	2015-05-28 05:59:04	info	received all objects
    legacy-0	2015-05-28 05:59:01	info	webserver listening on port 8088
    legacy-0	2015-05-28 05:59:01	info	starting. Version 0.1.12 in /opt/iobroker/node_modules/iobroker.legacy
    legacy-0	2015-05-28 05:59:00	debug	statesDB connected
    legacy-0	2015-05-28 05:59:00	debug	objectDB connected
    host-raspberrypi	2015-05-28 05:58:57	info	instance system.adapter.legacy.0 started with pid 18103
    host-raspberrypi	2015-05-28 05:58:27	info	Restart adapter system.adapter.legacy.0 because enabled
    host-raspberrypi	2015-05-28 05:58:27	error	instance system.adapter.legacy.0 terminated with code 6 (uncaught exception)
    Habe alles automatisch installiert und gestern nochmals nach updates gesucht und upgedatet. Was kann ich noch machen?
      ak1
      Hallo!
      Ich habe gerade begonnen mich mit ioBroker zu beschäftigen und stoße auch auf auf das von "klassisch" beschriebene Problem.
      Hat jemand einen Rat?
      ak1
        Ja!
        Legacy meiden[GRINNING FACE WITH SMILING EYES]
        Erst einmal Willkommen im Forum!
        Ganz im ernst. Der legacy Adapter wird nicht mehr gepflegt und wahrscheinlich bald aus dem Repository genommen.
        Wenn du ihn für dashui nutzen wolltest, ist jetzt vis die bessere Alternative.
        Für yahui wird es den mobile Adapter geben.
        Rainer
        Gesendet von meinem LIFETAB_S785X mit Tapatalk
          ak1
          Rainer, danke für die schnelle und schonungslose Antwort ;)
          Bei mir geht es tatsächlich um Yahui. Dann wart ich halt mal, was da so mit dem Mobile Adapter geben wird. Gibt es dazu schon irgendwelche Informationen?
          ak1
          • BluefoxB Offline
            BluefoxB Offline
            Ich habe jetzt legacy endgültig aus dem Repository gelöscht… Um die Leute nicht zu verwirren.
              ak1
              Ich habe die Tage nun erstmalig etwas genauer auf ioBroker geschaut und damit etwas herumprobiert. Es ist ziemlich beeindruckend, was das ioBroker Team hier bislang geschaffen hat! Klasse!
              Der mobile Adapter hat aber wohl zur Zeit keinen Fokus, so interpretiere ich als Laie zumindest den Status des Adapters auf Github. Ich denke aber, dass meine Yahui-Installation noch eine Zeit lang durchhält …
              ak1
