  4. Decoonz unter Zigbee Adapter funktioniert nicht (gelöst)
13 Beiträge 2 Kommentatoren 768 Aufrufe 2 Beobachtet
  • L Offline
    lustig29
    schrieb am zuletzt editiert von lustig29
    Ich probiere gerade einen Decoonz Conbee 2 Stick unter dem Zigbee Adapter zum laufen zu bringen. Leider wird die Instanz nicht grün.
    zigbee.0
    2022-05-20 19:42:08.020	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    zigbee.0
    2022-05-20 19:42:08.018	info	terminating
    zigbee.0
    2022-05-20 19:42:08.011	info	Zigbee: disabling joining new devices.
    zigbee.0
    2022-05-20 19:42:08.001	info	cleaned everything up...
    zigbee.0
    2022-05-20 19:42:07.973	error	Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'
    zigbee.0
    2022-05-20 19:42:07.972	error	Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
    zigbee.0
    2022-05-20 19:42:07.970	error	unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'
    zigbee.0
    2022-05-20 19:42:07.969	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    zigbee.0
    2022-05-20 19:41:48.395	error	Error herdsman start
    zigbee.0
    2022-05-20 19:41:48.395	error	Failed to start Zigbee
    zigbee.0
    2022-05-20 19:41:48.393	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'"
    • L lustig29
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      zigbee.0
      @lustig29
      ls -l /dev/serial/by-id
      anschauen ob der Geräte-Link wirklich so lautet.
      In den Einstellungen des Adapters steht der komplette Pfad drin?
      Müsste sowas wie
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00
      dann sein.
      L 1 Antwort Letzte Antwort
        @lustig29
        Müsste sowas wie
        dann sein.
        lustig29
        @thomas-braun said in Decoonz unter Zigbee Adapter funktioniert nicht:
        /dev/serial/by-id/
        Pfad hab ich angepasst.
        Leider immer noch der Fehler.
        Hatte vorher den Decoonz Adapter laufen. Muss ich da eventuell noch was deinstallieren, oder spielt das keine Rolle?
        Thomas BraunT 3 Antworten Letzte Antwort
        • L lustig29
          /dev/serial/by-id/
          @lustig29
          Und was sagt nun
          Und wie sieht ein Neustart des Adapters jetzt im Log aus?
          • L lustig29
            /dev/serial/by-id/
            @lustig29 sagte in Decoonz unter Zigbee Adapter funktioniert nicht:
            Läuft der deconz-Kram noch?
            systemctl status deconz deconz-gui
              @lustig29
              Und was sagt nun
              lustig29
               usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00 -> ../../ttyACM0
              zigbee.0
              2022-05-20 20:26:23.483	error	Error herdsman start
              zigbee.0
              2022-05-20 20:26:23.482	error	Failed to start Zigbee
              zigbee.0
              2022-05-20 20:26:23.479	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'"
                lustig29
                 ^[[200~systemctl status deconz deconz-gui
                -bash: $'\E[200~systemctl': Kommando nicht gefunden.
                • L lustig29
                  /dev/serial/by-id/
                  Nein, es ist nicht 'der Fehler'. Die Meldung ist nun eine andere.
                    lustig29
                    @thomas-braun Wie kann ich das Problem lösen?
                    • L lustig29
                      @lustig29
                      Bitte genau abtippen oder kopieren...
                        @lustig29
                        lustig29
                        Warning: The unit file, source configuration file or drop-ins of deconz.service>
                        Unit deconz-gui.service could not be found.
                        ● deconz.service - deCONZ: ZigBee gateway -- REST API
                             Loaded: loaded (/lib/systemd/system/deconz.service; bad; vendor preset: en>
                             Active: active (running) since Tue 2022-03-29 19:18:27 CEST; 1 months 21 d>
                           Main PID: 346 (deCONZ)
                              Tasks: 4 (limit: 4915)
                                CPU: 7h 55min 5.049s
                             CGroup: /system.slice/deconz.service
                                     └─346 /usr/bin/deCONZ -platform minimal --http-port=80
                        Mär 29 19:18:27 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST >
                        Mär 29 19:18:29 raspberrypi deCONZ[346]: QStandardPaths: XDG_RUNTIME_DIR not se>
                        Mär 29 19:18:30 raspberrypi deCONZ[346]: libpng warning: iCCP: known incorrect >
                        Mär 29 19:18:31 raspberrypi deCONZ[346]: This plugin does not support propagate>
                        Mär 29 19:18:34 raspberrypi deCONZ[346]: This plugin does not support propagate>
                        lines 1-17/17 (END)...skipping...
                        Warning: The unit file, source configuration file or drop-ins of deconz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                             Loaded: loaded (/lib/systemd/system/deconz.service; bad; vendor preset: enabled)
                             Active: active (running) since Tue 2022-03-29 19:18:27 CEST; 1 months 21 days ago
                        Mär 29 19:18:27 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                        Mär 29 19:18:29 raspberrypi deCONZ[346]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                        Mär 29 19:18:30 raspberrypi deCONZ[346]: libpng warning: iCCP: known incorrect sRGB profile
                        Mär 29 19:18:31 raspberrypi deCONZ[346]: This plugin does not support propagateSizeHints()
                        Mär 29 19:18:34 raspberrypi deCONZ[346]: This plugin does not support propagateSizeHints()
                        • L lustig29
                          @lustig29
                          sudo systemctl stop deconz
                          sudo systemctl disable deconz
                          Dann sollte ein Neustart auch 'grün' werden.
                            @lustig29
                            lustig29
                            Super. Hat funktioniert. Besten Dank
