  2. English
  3. ioBroker general
  4. How to fix this error
    apollon77A
Geplant Angeheftet Gesperrt Verschoben ioBroker general
4 Beiträge 3 Kommentatoren 725 Aufrufe 3 Beobachtet
  • J
    J
    jonnyhk
    Hello
    I have some strange issue with my installtion
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   'C:\\Program Files\\iobroker\\SmartHome\\nodejs\\node.exe',
    1 verbose cli   'C:\\Program Files\\iobroker\\SmartHome\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
    1 verbose cli   'audit',
    1 verbose cli   'fix'
    1 verbose cli ]
    2 info using npm@6.14.16
    3 info using node@v14.19.1
    4 verbose npm-session f6c27cdf1024e538
    5 verbose stack Error: Errors were found in your package-lock.json, run  npm install  to fix them.
    5 verbose stack     Missing: iobroker.discovery@stable
    5 verbose stack     Missing: iobroker.info@stable
    5 verbose stack     at C:\Program Files\iobroker\SmartHome\nodejs\node_modules\npm\lib\audit.js:184:19
    6 verbose cwd C:\Program Files\iobroker\SmartHome
    7 verbose Windows_NT 10.0.19044
    8 verbose argv "C:\\Program Files\\iobroker\\SmartHome\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\SmartHome\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "audit" "fix"
    9 verbose node v14.19.1
    10 verbose npm  v6.14.16
    11 error code ELOCKVERIFY
    12 error Errors were found in your package-lock.json, run  npm install  to fix them.
    12 error     Missing: iobroker.discovery@stable
    12 error     Missing: iobroker.info@stable
    13 verbose exit [ 1, true ]
    Mod-Edit: Code in </> Code-Tag gepackt!
    • J jonnyhk
      Hello
      1 verbose cli [
      1 verbose cli   'fix'
      1 verbose cli ]
      Thomas BraunT
      Thomas BraunT
      @jonnyhk sagte in How to fix this error:
      npm install
      NEVER run npm audit fix.
      Go to the directory where iobroker is installed and run
      npm install
      Maybe it helps.
      Maybe it makes things worse.
      J 1 Antwort Letzte Antwort
        npm install
        npm install
        Maybe it helps.
        J
        J
        jonnyhk
        Hello
        Here is what happend:
        C:\Program Files\iobroker\SmartHome>npm install
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        > @serialport/bindings-cpp@10.7.0 install C:\Program Files\iobroker\SmartHome\node_modules\@serialport\bindings-cpp
        > node-gyp-build
        > iobroker.inst@2.0.3 install C:\Program Files\iobroker\SmartHome
        > node lib/checkVersions.js
        NPM version: 6.14.16
        > iobroker.inst@2.0.3 postinstall C:\Program Files\iobroker\SmartHome
        > node lib/install.js
        Write "iobroker start" to start the ioBroker
        npm install node-windows@0.1.14 --production --save --prefix "C:/Program Files/iobroker/SmartHome"
        + node-windows@0.1.14
        added 5 packages from 8 contributors in 2.665s
        This service is already installed.
        ioBroker service installed. Write "serviceIoBroker start" to start the service and go to http://localhost:8081 to open the admin UI.
        To see the outputs do not start the service, but write "node node_modules/iobroker.js-controller/controller"
        npm notice created a lockfile as package-lock.json. You should commit this file.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.7 (node_modules\iobroker.info\node_modules\osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules\chokidar\node_modules\fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
        added 46 packages from 104 contributors and audited 575 packages in 16.858s
        36 packages are looking for funding
          run `npm fund` for details
        found 14 vulnerabilities (4 low, 5 moderate, 5 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        Thanks in advance
        • J jonnyhk
          Hello
          > node-gyp-build
          > node lib/install.js
          Thanks in advance
          Thomas BraunT
          Thomas BraunT
          @jonnyhk
          Please post terminal output in CodeTags.
          Thx.
          Does it run now?
          If not, I can't help, Windows is unknown to me.
          84.0k
          1.4m
