  4. [done] Sonoff Zigbee USB Problem: configuration-adapter mism
    6.3k
7 Beiträge 2 Kommentatoren 1.4k Aufrufe 2 Beobachtet
    tklein
    schrieb am zuletzt editiert von tklein
    Hallo ich habe auf einem neuen IOB-System auf einem 3er Raspi mit 1 GB
    pi@iobkoha:~ $ node -v
    v14.19.1
    pi@iobkoha:~ $
    pi@iobkoha:~ $ npm -v
    6.14.16
    pi@iobkoha:~ $
    js-controller: 4.0.21
    pi@iobkoha:~ $ ls -la /dev/serial/by-id/
    total 0
    drwxr-xr-x 2 root root 80 Apr 27 14:56 .
    drwxr-xr-x 4 root root 80 Apr 27 14:56 ..
    lrwxrwxrwx 1 root root 13 Apr 27 14:56 usb-1a86_USB2.0-Serial-if00-port0 -> ../../ttyUSB1
    lrwxrwxrwx 1 root root 13 Apr 27 14:56 usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_585d1a0f573bec11a9789c957a0af07f-if00-port0 -> ../../ttyUSB0
    pi@iobkoha:~ $
    Im Adapter habe ich
    /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_585d1a0f573bec11a9789c957a0af07f-if00-port0
    eingetragen.
    Leider bleibt der Adapter gelb und folgendes habe ich im Log:
    zigbee.0	2022-04-27 14:58:55.669	error	(1490) Error herdsman start
    zigbee.0	2022-04-27 14:58:55.668	error	(1490) Failed to start Zigbee
    zigbee.0	2022-04-27 14:58:55.666	error	(1490) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0	2022-04-27 14:58:55.251	info	(1490) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:58:55.210	info	(1490) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:58:55.207	info	(1490) Try to reconnect. 1 attempts left
    zigbee.0	2022-04-27 14:58:45.201	error	(1490) Error herdsman start
    zigbee.0	2022-04-27 14:58:45.200	error	(1490) Failed to start Zigbee
    zigbee.0	2022-04-27 14:58:45.198	error	(1490) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0	2022-04-27 14:58:44.774	error	(1490) Re-commissioning your network will require re-pairing of all devices!
    zigbee.0	2022-04-27 14:58:44.773	error	(1490) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0	2022-04-27 14:58:44.771	error	(1490) Please update configuration to prevent further issues.
    zigbee.0	2022-04-27 14:58:44.770	error	(1490) - Channel List: configured=11, adapter=11
    zigbee.0	2022-04-27 14:58:44.768	error	(1490) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0	2022-04-27 14:58:44.766	error	(1490) - Extended PAN ID: configured=ddddddddddddcdab, adapter=00124b0024c91f1c
    zigbee.0	2022-04-27 14:58:44.765	error	(1490) - PAN ID: configured=7754, adapter=7754
    zigbee.0	2022-04-27 14:58:44.763	error	(1490) Configuration is not consistent with adapter state/backup!
    zigbee.0	2022-04-27 14:58:44.492	info	(1490) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:58:43.378	info	(1490) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:58:43.209	info	(1490) starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.21
    zigbee.0	2022-04-27 14:58:33.871	info	(873) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2022-04-27 14:58:33.868	info	(873) terminating
    zigbee.0	2022-04-27 14:58:33.866	warn	(873) Failed to stop zigbee during startup
    zigbee.0	2022-04-27 14:58:33.674	info	(873) Zigbee: disabling joining new devices.
    zigbee.0	2022-04-27 14:58:33.663	info	(873) cleaned everything up...
    zigbee.0	2022-04-27 14:58:33.657	info	(873) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2022-04-27 14:57:15.248	error	(873) Error herdsman start
    zigbee.0	2022-04-27 14:57:15.246	error	(873) Failed to start Zigbee
    zigbee.0	2022-04-27 14:57:15.238	error	(873) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0	2022-04-27 14:57:14.763	info	(873) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:57:14.737	info	(873) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:57:14.735	info	(873) Try to reconnect. 1 attempts left
    zigbee.0	2022-04-27 14:57:04.728	error	(873) Error herdsman start
    zigbee.0	2022-04-27 14:57:04.727	error	(873) Failed to start Zigbee
    zigbee.0	2022-04-27 14:57:04.725	error	(873) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0	2022-04-27 14:57:04.291	error	(873) Re-commissioning your network will require re-pairing of all devices!
    zigbee.0	2022-04-27 14:57:04.289	error	(873) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0	2022-04-27 14:57:04.288	error	(873) Please update configuration to prevent further issues.
    zigbee.0	2022-04-27 14:57:04.287	error	(873) - Channel List: configured=11, adapter=11
    zigbee.0	2022-04-27 14:57:04.285	error	(873) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0	2022-04-27 14:57:04.284	error	(873) - Extended PAN ID: configured=ddddddddddddcdab, adapter=00124b0024c91f1c
    zigbee.0	2022-04-27 14:57:04.282	error	(873) - PAN ID: configured=7754, adapter=7754
    zigbee.0	2022-04-27 14:57:04.280	error	(873) Configuration is not consistent with adapter state/backup!
    zigbee.0	2022-04-27 14:57:04.000	info	(873) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:57:02.641	info	(873) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:57:02.399	info	(873) starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.21
    zigbee.0	2022-04-27 14:56:04.076	info	(17058) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    zigbee.0	2022-04-27 14:56:03.992	info	(17058) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2022-04-27 14:56:03.965	warn	(17058) Failed to stop zigbee during startup
    zigbee.0	2022-04-27 14:56:03.502	info	(17058) Zigbee: disabling joining new devices.
    zigbee.0	2022-04-27 14:56:03.433	info	(17058) cleaned everything up...
    zigbee.0	2022-04-27 14:54:10.923	error	(17058) Error herdsman start
    zigbee.0	2022-04-27 14:54:10.922	error	(17058) Failed to start Zigbee
    zigbee.0	2022-04-27 14:54:10.920	error	(17058) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0	2022-04-27 14:54:10.476	info	(17058) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:54:10.438	info	(17058) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:54:10.436	info	(17058) Try to reconnect. 1 attempts left
    zigbee.0	2022-04-27 14:54:00.430	error	(17058) Error herdsman start
    zigbee.0	2022-04-27 14:54:00.429	error	(17058) Failed to start Zigbee
    zigbee.0	2022-04-27 14:54:00.428	error	(17058) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0	2022-04-27 14:54:00.009	error	(17058) Re-commissioning your network will require re-pairing of all devices!
    zigbee.0	2022-04-27 14:54:00.008	error	(17058) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0	2022-04-27 14:54:00.007	error	(17058) Please update configuration to prevent further issues.
    zigbee.0	2022-04-27 14:54:00.006	error	(17058) - Channel List: configured=11, adapter=11
    zigbee.0	2022-04-27 14:54:00.004	error	(17058) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0	2022-04-27 14:54:00.002	error	(17058) - Extended PAN ID: configured=ddddddddddddcdab, adapter=00124b0024c91f1c
    zigbee.0	2022-04-27 14:54:00.000	error	(17058) - PAN ID: configured=7754, adapter=7754
    zigbee.0	2022-04-27 14:53:59.999	error	(17058) Configuration is not consistent with adapter state/backup!
    zigbee.0	2022-04-27 14:53:59.803	info	(17058) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:53:58.706	info	(17058) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:53:58.532	info	(17058) starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.21
    zigbee.0	2022-04-27 14:51:41.571	info	(16948) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2022-04-27 14:51:41.568	info	(16948) terminating
    zigbee.0	2022-04-27 14:51:41.566	warn	(16948) Failed to stop zigbee during startup
    zigbee.0	2022-04-27 14:51:41.473	info	(16948) Zigbee: disabling joining new devices.
    zigbee.0	2022-04-27 14:51:41.460	info	(16948) cleaned everything up...
    zigbee.0	2022-04-27 14:51:41.456	info	(16948) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2022-04-27 14:51:28.005	error	(16948) Error herdsman start
    zigbee.0	2022-04-27 14:51:28.004	error	(16948) Failed to start Zigbee
    zigbee.0	2022-04-27 14:51:28.002	error	(16948) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
    zigbee.0	2022-04-27 14:51:27.576	info	(16948) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:51:27.515	info	(16948) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:51:27.511	info	(16948) Try to reconnect. 1 attempts left
    zigbee.0	2022-04-27 14:51:17.505	error	(16948) Error herdsman start
    zigbee.0	2022-04-27 14:51:17.504	error	(16948) Failed to start Zigbee
    zigbee.0	2022-04-27 14:51:17.503	error	(16948) Starting zigbee-herdsman problem : "startup failed - configuration-adapter mismatch - see logs above for more information"
    zigbee.0	2022-04-27 14:51:17.057	error	(16948) Re-commissioning your network will require re-pairing of all devices!
    zigbee.0	2022-04-27 14:51:17.056	error	(16948) If you wish to re-commission your network, please remove coordinator backup at /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json.
    zigbee.0	2022-04-27 14:51:17.055	error	(16948) Please update configuration to prevent further issues.
    zigbee.0	2022-04-27 14:51:17.054	error	(16948) - Channel List: configured=11, adapter=11
    zigbee.0	2022-04-27 14:51:17.052	error	(16948) - Network Key: configured=01030507090b0d0f00020406080a0c0d, adapter=01030507090b0d0f00020406080a0c0d
    zigbee.0	2022-04-27 14:51:17.051	error	(16948) - Extended PAN ID: configured=ddddddddddddcdab, adapter=00124b0024c91f1c
    zigbee.0	2022-04-27 14:51:17.049	error	(16948) - PAN ID: configured=7754, adapter=7754
    zigbee.0	2022-04-27 14:51:17.048	error	(16948) Configuration is not consistent with adapter state/backup!
    zigbee.0	2022-04-27 14:51:16.743	info	(16948) Installed Version: iobroker.zigbee@1.6.16
    zigbee.0	2022-04-27 14:51:15.510	info	(16948) Starting Zigbee npm ...
    zigbee.0	2022-04-27 14:51:15.336	info	(16948) starting. Version 1.6.16 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.21
    zigbee.0	2022-04-27 14:51:06.489	info	(16883) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    zigbee.0	2022-04-27 14:51:06.486	info	(16883) terminating
    zigbee.0	2022-04-27 14:51:05.987	info	(16883) Zigbee: disabling joining new devices.
    zigbee.0	2022-04-27 14:51:05.983	info	(16883) cleaned everything up...
    zigbee.0	2022-04-27 14:51:05.980	info	(16883) Got terminate signal TERMINATE_YOURSELF
    zigbee.0	2022-04-27 14:51:05.977	warn	(16883) State "zigbee.0.info.undefinedDevices" has no existing object, this might lead to an error in future versions
    zigbee.0	2022-04-27 14:51:05.710	error	(16883) Unable to apply ExtPanID changes: Error: SRSP - SYS - osalNvRead after 0,2ms
    zigbee.0	2022-04-27 14:51:05.702	info	(16883) Zigbee started
    zigbee.0	2022-04-27 14:51:05.700	info	(16883) Currently no devices.
    Was kann ich tun?
    Grüße
    Thomas
    • T tklein
      v14.19.1
      pi@iobkoha:~ $
      6.14.16
      pi@iobkoha:~ $
      total 0
      pi@iobkoha:~ $
      Im Adapter habe ich
      eingetragen.
      Was kann ich tun?
      Grüße
      Thomas
      @tklein sagte in Sonoff Zigbee USB Problem: configuration-adapter mismatch:
      Bring die übereinander.
      00124b0024c91f1c in den Einstellungen eintragen.
        tklein
        @thomas-braun said in Sonoff Zigbee USB Problem: configuration-adapter mismatch:
        00124b0024c91f1c
        danke für die sehr schenlle Antwort. Hat geklappt. Kann ich die PAN-ID nicht frei vergeben?
        • T tklein
          00124b0024c91f1c
          @tklein
          Jein.
          Wolltest du lustige Worte aus den Hex-Ziffern bilden?
            @tklein
            Jein.
            tklein
            @tklein
            Jein.
            hatte das etwas frei eingegeben:-)
            • T tklein
              @tklein
              Jein.
              @tklein
              Der Adapter würfelt eine PAN-ID, wenn die nicht komplex genug ist.
                @tklein
                tklein
                @thomas-braun danke für die Infos.
