  4. npm neu installieren
    6.0k
5 Beiträge 3 Kommentatoren 1.4k Aufrufe 2 Beobachtet
  • H Offline
    hardy_01
    Beim nodejs Update auf 16 scheint wohl was schief gelaufen zu sein. Wie bekomme ich da wieder ne saubere Installation hin?
    pi@raspberrypi-iob:~ $ node -v
    v16.14.2
    pi@raspberrypi-iob:~ $ nodejs -v
    -bash: nodejs: Kommando nicht gefunden.
    pi@raspberrypi-iob:~ $ npm -v
    TypeError: Class extends value undefined is not a constructor or null
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/agent.js:114:44)
        at Module._compile (node:internal/modules/cjs/loader:1103:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1157:10)
        at Module.load (node:internal/modules/cjs/loader:981:32)
        at Function.Module._load (node:internal/modules/cjs/loader:822:12)
        at Module.require (node:internal/modules/cjs/loader:1005:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/socks-proxy-agent/dist/index.js:5:33)
        at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/make-fetch-happen/lib/agent.js:169:25)
    pi@raspberrypi-iob:~ $ iobroker upgrade self
    Update js-controller from @3.1.6 to @4.0.21
    Error trying to check npm version: Error: Command failed: npm -v
    Aborting install because the npm version could not be checked!
    Please check that npm is installed correctly.
    Use "npm install -g npm@4" or "npm install -g npm@latest" to install a supported version.
    You need to make sure to repeat this step after installing an update to NodeJS and/or npm
    Thomas BraunT haselchenH 2 Antworten Letzte Antwort
    • H hardy_01
      v16.14.2
      @hardy_01
      Schau in meiner Signatur wie man das sauber installiert. Und wie man zuvor prüft wo es klemmt.
      • H hardy_01
        v16.14.2
        haselchenH Offline
        haselchenH Offline
        haselchen
        @hardy_01
        Und immer vorher ins Iobroker Verzeichnis gehen
        cd /opt/iobroker
        Du hast da jetzt wild auf deinem Gerät was installiert.
        H 1 Antwort Letzte Antwort
        • haselchenH haselchen
          @hardy_01
          cd /opt/iobroker
          hardy_01
          schrieb am zuletzt editiert von hardy_01
          Brauche leider nochmal eure Hilfe. Wollte nodejs 16 neu installieren:
          sudo apt remove node*
          anschließend
          sudo rm /usr/bin/nodejs
          sudo rm /usr/bin/npm
          Dann
          pi@raspberrypi-iob:/opt/iobroker $ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
          ## Installing the NodeSource Node.js 16.x repo...
          ## Populating apt-get cache...
          + apt-get update
          OK:3 https://deb.nodesource.com/node_14.x buster InRelease
          OK:4 https://repo.ebusd.eu/apt/default/buster buster InRelease
          OK:5 https://repos.influxdata.com/debian buster InRelease
          OK:6 https://dl.ubnt.com/unifi/debian stable InRelease
          ## Confirming "buster" is supported...
          und
          pi@raspberrypi-iob:/opt/iobroker $ sudo apt-get install -y nodejs
          nodejs ist schon die neueste Version (16.14.2-deb-1nodesource1).
          Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
            gyp libbrotli1 libc-ares2 libjs-inherits libjs-is-typedarray libssl-dev libuv1-dev python-pkg-resources
          Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          bringt
          pi@raspberrypi-iob:/opt/iobroker $ node -v
          -bash: node: Kommando nicht gefunden.
          pi@raspberrypi-iob:/opt/iobroker $ nodejs -v
          und mein iobroker lässt sich nicht starten bzw. ist nicht erreichbar.
          Hilfe^^
          edit: Habe es hinbekommen.
          sudo apt remove nodejs
          hat gefehlt. Danach konnte ich node wieder installieren.
          • H hardy_01
            anschließend
            Dann
            + apt-get update
            und
            bringt
            Hilfe^^
            @hardy_01
            Da hast du die nodejs von dfsg und nodesource gleichzeitig installiert gehabt.
            Und man deinstalliert nicht so:
            Wo haste den Mist denn her?
            Wie schaut der Kram jetzt aus?
            Ausgabe von
            sudo apt autoremove
            which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            posten.
