  4. [gelöst] Fehlermeldungen daswetter
    6.0k
12 Beiträge 3 Kommentatoren 577 Aufrufe 2 Beobachtet
  • GregorSG Offline
    GregorSG Offline
    GregorS
    schrieb am zuletzt editiert von GregorS
    Jetzt meckert der Adapter "daswetter".
    Diese Fehler kommen immer wieder sobald der Adapter gestartet wird (perCron alle halbe Stunde)
    Hängt das vieleicht mit einem Update der folgenden Adapter zusammen.
    iot, web, socket-io
    host.TinkerboardS
    	2022-03-26 15:01:43.647	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    daswetter.0
    	2022-03-26 15:01:43.535	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_15.symbol": Connection is closed.
    daswetter.0
    	2022-03-26 15:01:43.514	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_2.Hour_15.temp: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_15.temp": Connection is closed.]
    daswetter.0
    	2022-03-26 15:01:43.510	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_15.temp": Connection is closed.
    daswetter.0
    	2022-03-26 15:01:43.506	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_2.Hour_15.hour: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_15.hour": Connection is closed.]
    daswetter.0
    	2022-03-26 15:01:43.502	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_15.hour": Connection is closed.
    daswetter.0
    	2022-03-26 15:01:43.487	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_2.Hour_15: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_15": Connection is closed.]
    daswetter.0
    	2022-03-26 15:01:43.484	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_15": Connection is closed.
    daswetter.0
    	2022-03-26 15:01:43.480	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_2.Hour_14.windchill: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_14.windchill": Connection is closed.]
    daswetter.0
    	2022-03-26 15:01:43.462	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_14.windchill": Connection is closed.
    daswetter.0
    	2022-03-26 15:01:43.458	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours2.Location_1.Day_2.Hour_14.snowline: Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_14.snowline": Connection is closed.]
    daswetter.0
    	2022-03-26 15:01:43.441	error	Cannot check object existence of "daswetter.0.NextHours2.Location_1.Day_2.Hour_14.snowline": Connection is closed.
    daswetter.0
    	2022-03-26 15:01:43.437	error	exception in await insertIntoList [Error: Connection is closed.]
    daswetter.0
    	2022-03-26 15:01:42.696	error	force terminate
    Hoffe ich bekomme mal wieder mein log sauber.
    INTEL NUC i7, Sonoff, hmIP, AVM, Jeelink, T-Link, Alexa, Saia-Burgess, uvm.
    • GregorSG GregorS
      iot, web, socket-io
      host.TinkerboardS
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      haselchenH Offline
      haselchenH Offline
      haselchen
      @gregors
      Was für ein Timeout hast Du in den Einstellungen?
      Stell mal auf 300 sek.
      Hab das Problem beim Neustart manchmal . Da reichen die 300 Sekunden manchmal nicht .
      Aber bei dir sollte der Fehler dann weg sein .
      Ansonsten musste das anpassen auf 400 oder mehr .
      GregorSG 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @gregors
        GregorSG Offline
        GregorSG Offline
        GregorS
        @haselchen
        hatte 90sek drin, habe sie mal auf 300 geändert.
        Bis dato gab es damit keine Probleme.
        • GregorSG GregorS
          @haselchen
          haselchenH Offline
          haselchenH Offline
          haselchen
          @gregors
          Dann beobachte das mal .
          Und gib dann bitte Feedback.
            @gregors
            GregorSG Offline
            GregorSG Offline
            GregorS
            @haselchen
            Daran lag es nicht.
            Habe erst auf 300 dann auf 800 sek umgestellt.
            Zuerst war es ok, jetzt sind die Fehler wieder da.
            • GregorSG GregorS
              @haselchen
              Daran lag es nicht.
              haselchenH Offline
              haselchenH Offline
              haselchen
              @gregors
              Die gleichen Connection Fehler?
              Zeig mal das Log bitte
                @gregors
                GregorSG Offline
                GregorSG Offline
                GregorS
                @haselchen
                Hier das Log:
                host.TinkerboardS
                	2022-03-27 16:37:21.572	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
                daswetter.0
                	2022-03-27 16:37:21.405	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_value": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.401	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_desc: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_desc": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.398	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_desc": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.392	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_value2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_value2": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.389	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_value2": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.386	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_desc2: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_desc2": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.384	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.symbol_desc2": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.381	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_12.temp_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.temp_value": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.379	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.temp_value": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.376	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_12.hour_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.hour_value": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.372	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12.hour_value": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.369	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.current: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.current": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.367	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.current": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.363	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_12: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.361	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_12": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.358	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_11.windchill_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.windchill_value": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.355	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.windchill_value": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.352	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_11.snowline_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.snowline_value": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.349	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.snowline_value": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.344	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_11.clouds_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.clouds_value": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.340	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.clouds_value": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.331	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_1.Hour_11.pressure_value: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.pressure_value": Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:21.328	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_1.Hour_11.pressure_value": Connection is closed.
                daswetter.0
                	2022-03-27 16:37:21.322	error	exception in await insertIntoList [Error: Connection is closed.]
                daswetter.0
                	2022-03-27 16:37:20.726	error	force terminate
                host.TinkerboardS
                	2022-03-27 16:35:29.699	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                host.TinkerboardS
                	2022-03-27 16:35:04.329	info	instance system.adapter.dwd.0 started with pid 22439
                host.TinkerboardS
                	2022-03-27 16:35:00.255	info	instance system.adapter.daswetter.0 started with pid 22131
                • GregorSG GregorS
                  @haselchen
                  Hier das Log:
                  host.TinkerboardS
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  daswetter.0
                  host.TinkerboardS
                  host.TinkerboardS
                  host.TinkerboardS
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Glasfaser
                  @gregors
                  Adapter stoppen , alle Datenpunkte vom Adapter dasWetter löschen , Adapter starten das er die Datenpunkte neu anlegt .
                  Was ist dann !?
                  • GlasfaserG Glasfaser
                    @gregors
                    Was ist dann !?
                    GregorSG Offline
                    GregorSG Offline
                    GregorS
                    @glasfaser
                    Habe ich versucht, konnte aber die Datenpunkte nicht löschen.
                    Dann kam in der Konsole folgendes und iobroker startete neu:
                        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                        at Object.onceWrapper (events.js:421:26)
                        at Socket.emit (events.js:314:20)
                        at TCP.<anonymous> (net.js:675:12)
                    Emitted 'error' event on ScanStream instance at:
                        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                        at processTicksAndRejections (internal/process/task_queues.js:97:5)
                    pi@TinkerboardS:~$
                    pi@TinkerboardS:~$ /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                    -bash: /opt/iobroker/node_modules/standard-as-callback/built/index.js:6: Datei oder Verzeichnis nicht gefunden
                    pi@TinkerboardS:~$         throw e;
                    Could not find the database of available applications, run update-command-not-found as root to fix this
                    throw: command not found
                    pi@TinkerboardS:~$         ^
                    ^: command not found
                    pi@TinkerboardS:~$
                    pi@TinkerboardS:~$ Error: Connection is closed.
                    Error:: command not found
                    pi@TinkerboardS:~$     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
                    -bash: Syntaxfehler beim unerwarteten Wort `('
                    pi@TinkerboardS:~$     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
                    pi@TinkerboardS:~$     at Object.onceWrapper (events.js:421:26)
                    pi@TinkerboardS:~$     at Socket.emit (events.js:314:20)
                    pi@TinkerboardS:~$     at TCP.<anonymous> (net.js:675:12)
                    pi@TinkerboardS:~$ Emitted 'error' event on ScanStream instance at:
                    Emitted: command not found
                    pi@TinkerboardS:~$     at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                    at: command not found
                    pi@TinkerboardS:~$     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                    pi@TinkerboardS:~$     at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                    pi@TinkerboardS:~$     at processTicksAndRejections (internal/process/task_queues.js:97:5)
                    Ich habe glaube ich ein ganze viel größeres Problem
                    • GregorSG GregorS
                      @glasfaser
                      pi@TinkerboardS:~$
                      pi@TinkerboardS:~$
                      GlasfaserG Offline
                      GlasfaserG Offline
                      Glasfaser
                      @gregors sagte in Fehlermeldungen daswetter:
                      das hattest du schon einmal ...
                      https://forum.iobroker.net/topic/22392/fehlermeldung-iobroker-keine-manuelles-starten-möglich?_=1648488375643
                        GregorSG Offline
                        GregorSG Offline
                        GregorS
                        @glasfaser
                        War mir nicht mehr bewusst.
                        Alleso muss ich neu installieren?
                        • GregorSG GregorS
                          @glasfaser
                          GregorSG Offline
                          GregorSG Offline
                          GregorS
                          Läuft wieder.
                          Habe die Zeit auf 600 Sekunden hochgesetzt.
                          Bis jetzt keine Fehler mehr.
