  3. Einsteigerfragen
  4. auf einmal Probleme mit Lupus und Web
    5.7k
4 Beiträge 3 Kommentatoren 359 Aufrufe 3 Beobachtet
    decnet
    nach der ersten Installation habe ich einige Adapter eingebunden, u.a. Lupus und Web. Jetzt kommen auf einmal ständig Fehler, das ganze System ist irgendwie sehr langsam.
    Die Adapter stehen auf grün.
    Im Anhang das Protokoll. Wo kommen die Fehler her?
    2022-02-18 15:32:35.824 - info: web.0 (1384) <==Disconnect system.user.admin from ::ffff:192.168.178.110
    2022-02-18 15:32:36.836 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
    2022-02-18 15:33:48.771 - info: web.0 (1384) <==Disconnect system.user.admin from ::ffff:192.168.178.110
    2022-02-18 15:33:49.783 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
    2022-02-18 15:36:48.533 - error: lupusec.0 (6712) Cannot find search "folder" in "system"
    2022-02-18 15:36:54.917 - error: lupusec.0 (6712) Cannot find search "folder" in "system"
    2022-02-18 15:37:05.234 - error: lupusec.0 (6712) Cannot find search "folder" in "system"
    2022-02-18 15:39:30.429 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 (force=false, process=true)
    2022-02-18 15:39:30.435 - info: lupusec.0 (6712) Got terminate signal TERMINATE_YOURSELF
    2022-02-18 15:39:30.435 - info: lupusec.0 (6712) terminating
    2022-02-18 15:39:30.436 - info: lupusec.0 (6712) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-02-18 15:39:30.447 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 send kill signal
    2022-02-18 15:39:30.999 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-02-18 15:39:33.556 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 started with pid 8256
    2022-02-18 15:39:34.937 - info: lupusec.0 (8256) starting. Version 1.3.6 in C:/iobroker/SmartHome/node_modules/iobroker.lupusec, node: v14.18.3, js-controller: 3.3.22
    2022-02-18 15:39:34.946 - info: lupusec.0 (8256) Starting Adapter lupusec.0 in version 1.3.6
    2022-02-18 15:39:34.956 - info: lupusec.0 (8256) Changed LocalLink to https://192.168.178.111:80
    2022-02-18 15:39:34.965 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 (force=false, process=true)
    2022-02-18 15:39:34.967 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 send kill signal
    2022-02-18 15:39:34.988 - info: lupusec.0 (8256) Got terminate signal TERMINATE_YOURSELF
    2022-02-18 15:39:34.989 - info: lupusec.0 (8256) terminating
    2022-02-18 15:39:34.990 - info: lupusec.0 (8256) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-02-18 15:39:35.045 - info: lupusec.0 (8256) Lupusec Alarmsystem 192.168.178.111 is alive
    2022-02-18 15:39:35.046 - info: lupusec.0 (8256) Checking the ioBroker Lupusec configuration
    2022-02-18 15:39:35.048 - error: lupusec.0 (8256) Cannot find search "folder" in "system"
    2022-02-18 15:39:35.234 - info: lupusec.0 (8256) Connecting to Lupusec with https://192.168.178.111:80
    2022-02-18 15:39:35.234 - info: lupusec.0 (8256) Polltime 1 sec.
    2022-02-18 15:39:35.273 - error: lupusec.0 (8256) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:39:35.273 - error: lupusec.0 (8256) Poll rythmus chnaged to 15 seconds because of error!
    2022-02-18 15:39:35.552 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-02-18 15:39:38.004 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 started with pid 8400
    2022-02-18 15:39:39.498 - info: lupusec.0 (8400) starting. Version 1.3.6 in C:/iobroker/SmartHome/node_modules/iobroker.lupusec, node: v14.18.3, js-controller: 3.3.22
    2022-02-18 15:39:39.507 - info: lupusec.0 (8400) Starting Adapter lupusec.0 in version 1.3.6
    2022-02-18 15:39:39.566 - info: lupusec.0 (8400) Lupusec Alarmsystem 192.168.178.111 is alive
    2022-02-18 15:39:39.567 - info: lupusec.0 (8400) Checking the ioBroker Lupusec configuration
    2022-02-18 15:39:39.569 - error: lupusec.0 (8400) Cannot find search "folder" in "system"
    2022-02-18 15:39:39.751 - info: lupusec.0 (8400) Connecting to Lupusec with https://192.168.178.111:80
    2022-02-18 15:39:39.752 - info: lupusec.0 (8400) Polltime 1 sec.
    2022-02-18 15:39:39.789 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:39:39.790 - error: lupusec.0 (8400) Poll rythmus chnaged to 15 seconds because of error!
    2022-02-18 15:39:54.125 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:39:54.126 - error: lupusec.0 (8400) Poll rythmus chnaged to 30 seconds because of error!
    2022-02-18 15:40:25.001 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:40:25.002 - error: lupusec.0 (8400) Poll rythmus chnaged to 45 seconds because of error!
    2022-02-18 15:41:10.894 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:41:10.894 - error: lupusec.0 (8400) Poll rythmus chnaged to 60 seconds because of error!
    2022-02-18 15:41:27.643 - warn: info.0 (7728) State "info.0.uuid" has no existing object, this might lead to an error in future versions
    2022-02-18 15:42:10.216 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:42:10.216 - error: lupusec.0 (8400) Poll rythmus chnaged to 75 seconds because of error!
    2022-02-18 15:43:02.066 - info: host.DESKTOP-ACJ5M6C(SmartHome) Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
    2022-02-18 15:43:25.706 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:43:25.706 - error: lupusec.0 (8400) Poll rythmus chnaged to 90 seconds because of error!
    2022-02-18 15:44:55.237 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:44:55.237 - error: lupusec.0 (8400) Poll rythmus chnaged to 105 seconds because of error!
    2022-02-18 15:46:40.451 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:46:40.451 - error: lupusec.0 (8400) Poll rythmus chnaged to 120 seconds because of error!
    2022-02-18 15:48:40.976 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:48:40.976 - error: lupusec.0 (8400) Poll rythmus chnaged to 135 seconds because of error!
    2022-02-18 15:50:55.761 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:50:55.761 - error: lupusec.0 (8400) Poll rythmus chnaged to 150 seconds because of error!
    2022-02-18 15:52:23.923 - info: web.0 (1384) ==>Connected system.user.admin from ::ffff:192.168.178.110
    2022-02-18 15:52:24.924 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
    2022-02-18 15:52:41.999 - info: web.0 (1384) ==>Connected system.user.admin from ::ffff:192.168.178.110
    2022-02-18 15:52:43.001 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
    2022-02-18 15:52:45.613 - warn: web.0 (1384) State "dev3" has no existing object, this might lead to an error in future versions
    2022-02-18 15:52:46.616 - warn: web.0 (1384) State "dev3" has no existing object, this might lead to an error in future versions
    2022-02-18 15:52:47.044 - warn: web.0 (1384) State "dev3" has no existing object, this might lead to an error in future versions
    2022-02-18 15:53:25.608 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:53:25.608 - error: lupusec.0 (8400) Poll rythmus chnaged to 165 seconds because of error!
    2022-02-18 15:56:10.844 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:56:10.844 - error: lupusec.0 (8400) Poll rythmus chnaged to 180 seconds because of error!
    2022-02-18 15:59:10.494 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
    2022-02-18 15:59:10.495 - error: lupusec.0 (8400) Poll rythmus chnaged to 195 seconds because of error!
    LG
    Lutz
    MOD EDIT: Log in Code Tags gesetzt
    • D decnet
      LG
      Lutz
      @decnet
      LogFile als Text in CodeTags setzen. Danke.
      • wendy2702W Offline
        wendy2702W Offline
        wendy2702
        @decnet sagte in auf einmal Probleme mit Lupus und Web:
        Lupusec sieht nach verbindungsproblem aus.
        Um genaueres sagen zu können fehlen uns leider nähere Infos zu deiner Installation und HW setup.
        • wendy2702W wendy2702
          decnet
          Bis jetzt lief das System eigentlich problemlos. Die Lupus funktioniert problemlos ohne Fehlermeldungen, seht auch im Status grün, die einzelnen Objekte der Lupus sind vorhanden und werden scheinbar aktualisiert.
          Der web-Adapter steht auf 3.4.9 und lässt sich nicht aktualisieren auf 3.4.9 .
          Das ist mein System.
              Plattform: Windows
              Betriebssystem: win32
              Architektur: x64
              CPUs: 4
              Geschwindigkeit: 1995 MHz
              Modell: Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
              RAM: 7.8 GB
              System-Betriebszeit: 00:00:00
              Node.js: v14.18.3
              NPM: 6.14.15
              Adapter-Anzahl: 396
              Datenträgergröße: 118.6 GB
              Festplatte frei: 70.7 GB
              Betriebszeit: 01:39:20
              Aktive Instanzen: 23
              Pfad: C:\iobroker\SmartHome\
          und die Fehlemeldungen von eben:
          lupusec.0
          	2022-02-18 16:58:26.165	error	Poll rythmus chnaged to 315 seconds because of error!
          lupusec.0
          	2022-02-18 16:58:26.165	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
          lupusec.0
          	2022-02-18 16:53:11.060	error	Poll rythmus chnaged to 315 seconds because of error!
          lupusec.0
          	2022-02-18 16:53:11.060	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
          lupusec.0
          	2022-02-18 16:47:55.592	error	Poll rythmus chnaged to 315 seconds because of error!
          lupusec.0
          	2022-02-18 16:47:55.592	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
          lupusec.0
          	2022-02-18 16:42:40.722	error	Poll rythmus chnaged to 315 seconds because of error!
          lupusec.0
          	2022-02-18 16:42:40.722	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
          info.0
          	2022-02-18 16:41:27.646	warn	State "info.0.uuid" has no existing object, this might lead to an error in future versions
          lupusec.0
          	2022-02-18 16:37:25.842	error	Poll rythmus chnaged to 315 seconds because of error!
          lupusec.0
          	2022-02-18 16:37:25.842	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
          lupusec.0
          	2022-02-18 16:32:10.804	error	Poll rythmus chnaged to 315 seconds because of error!
          lupusec.0
          	2022-02-18 16:32:10.804	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
          lupusec.0
          	2022-02-18 16:27:10.065	error	Poll rythmus chnaged to 300 seconds because of error!
          lupusec.0
          	2022-02-18 16:27:10.065	error	Error: Error in deviceGenericPost (/action/deviceEditThermoGet - ZS:1b8801) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
          LG
          Lutz
