  4. nodered startet nicht
    2.0k
5 Beiträge 3 Kommentatoren 669 Aufrufe 3 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    liv-in-sky
    @mickym
    @flehmann1234
    noch ne frage zu nodered: @flehmann1234 hat in nodered eine node installiert (ttn node) installiert. heute läuft nodered nicht mehr und bringt fehler und terminiert den nodered adapter
    node-red.0	2022-02-03 10:35:36.890	error	(173485) Exception-Code: 14: 14 UNAVAILABLE: DNS resolution failed
    node-red.0	2022-02-03 10:35:36.890	error	at callback (/opt/iobroker/iobroker-data/node-red/node_modules/grpc/src/client_interceptors.js:847:24)
    node-red.0	2022-02-03 10:35:36.890	error	at InterceptingListener.onReceiveStatus (/opt/iobroker/iobroker-data/node-red/node_modules/grpc/src/client_interceptors.js:618:8)
    node-red.0	2022-02-03 10:35:36.890	error	at InterceptingListener._callNext (/opt/iobroker/iobroker-data/node-red/node_modules/grpc/src/client_interceptors.js:568:42)
    node-red.0	2022-02-03 10:35:36.890	error	at Object.onReceiveStatus (/opt/iobroker/iobroker-data/node-red/node_modules/grpc/src/client_interceptors.js:1209:28)
    node-red.0	2022-02-03 10:35:36.890	error	at Object.exports.createStatusError (/opt/iobroker/iobroker-data/node-red/node_modules/grpc/src/common.js:91:15)
    node-red.0	2022-02-03 10:35:36.890	error	(173485) Error: 14 UNAVAILABLE: DNS resolution failed
    node-red.0	2022-02-03 10:35:36.888	error	(173485) unhandled promise rejection: 14 UNAVAILABLE: DNS resolution failed
    node-red.0	2022-02-03 10:35:36.887	error	(173485) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    node-red.0	2022-02-03 10:35:36.887	error	(171067) 3 Feb 10:35:36 - [error] [ttn app:2b0e4093.823b1] Error on connection for TTN application fenstersensoren@ttn: Error: 14 UNAVAILABLE: DNS resolution failed
    node-red.0	2022-02-03 10:35:36.829	warn	3 Feb 10:35:36 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
    node-red.0	2022-02-03 10:35:36.829	warn	3 Feb 10:35:36 - [warn] No active project : using default flows file
    node-red.0	2022-02-03 10:35:36.829	warn	(171067) 3 Feb 10:35:36 - [info] Projects directory: /opt/iobroker/iobroker-data/node-red/projects
    node-red.0	2022-02-03 10:35:35.409	info	(171067) Starting node-red: --max-old-space-size=1024 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    node-red.0	2022-02-03 10:35:30.409	info	(171067) node-red exited with 6
    node-red.0	2022-02-03 10:35:29.896	warn	(173459) Terminated (UNCAUGHT_EXCEPTION): Without reason
    node-red.0	2022-02-03 10:35:29.895	info	(173459) terminating
    dns auf dem iobroker findet eigentlich die adresse.
    meine frage;: wie kann man die node aus dem system löschen, um kein backup einzuspielen und node red wieder startet oder wie kann ich den flow löschen
    mickymM liv-in-skyL 2 Antworten Letzte Antwort
    • liv-in-skyL liv-in-sky
      @mickym
      @flehmann1234
      mickymM Offline
      mickymM Offline
      mickym
      @liv-in-sky Du kannst Node-Red im Sicherheitsmodus starten und dann kann man den Flow öffen und die schadhafte Node oder den Flow reparieren, und dann halt Adapter wieder neu starten.
        @mickym
        @flehmann1234
        liv-in-skyL Offline
        liv-in-skyL Offline
        liv-in-sky
        @flehmann1234
        geht hier:
        @mickym vielen dank
          liv-in-skyL Offline
          liv-in-sky
          @flehmann1234
          evtl ist das noch eine idee
          https://forum.iobroker.net/post/755290
          oder
          https://forum.iobroker.net/post/755276
          F 1 Antwort Letzte Antwort
            @flehmann1234
            oder
            flehmann1234
            @liv-in-sky
            Nach zahlreichen Versuchen, z.B. löschen der Node-red-Nodes im Dateisystem hat folgendes Vorgehen die Lösung gebracht:
            Habe den Red-Node Adapter deinstalliert, neu installiert und im abgesicherten Modus neu gestartet.
            Dann als erstes die globalen Konfigurations-Nodes für TTN und MQTT gelöscht... neu starten von node red...
            Dann gings!
            Danke für die Unterstützung
