  4. Fehlermeldung bei Installation des iobroker
7 Beiträge 4 Kommentatoren 3.3k Aufrufe
  • J Offline
    jawr
    ich habe heute auf meinem Odroid C2 nodejs 6 installiert. Hierbei gab es keine Fehlermeldungen. Im Anschluss habe ich iobroker installiert. Der läuft, allerdings gab es bei der Installation ein paar Fehlermeldungen (zumindest sieht es für mich so aus)
    `install:yargs             â
    npm install iobroker.js-controller --production --prefix /opt/iobroker
    npm WARN deprecated letsencrypt@2.1.8: letsencrypt has been renamed to greenlock. Please find it at npm greenlock
    npm WARN deprecated localhost.daplie.com-certificates@1.2.5: Moved to localhost.daplie.me-certificates
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    npm install iobroker.admin --production --prefix /opt/iobroker
    sh: 0: getcwd() failed: No such file or directory
    path.js:424
        var path = (i >= 0) ? arguments[i] : process.cwd();
    Error: ENOENT: no such file or directory, uv_cwd
        at Error (native)
        at Object.posix.resolve (path.js:424:50)
        at Function.Module._resolveLookupPaths (module.js:250:17)
        at Function.Module._resolveFilename (module.js:317:31)
        at Function.Module._load (module.js:277:25)
        at Module.require (module.js:354:17)
        at require (internal/module.js:12:17)
        at /opt/iobroker/node_modules/npm/bin/npm-cli.js:23:11
        at Object. <anonymous>(/opt/iobroker/node_modules/npm/bin/npm-cli.js:75:3)
        at Module._compile (module.js:410:26)
    Write "./iobroker start" to start the ioBroker
    shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
    insserv: pushd() can not change to directory /etc/init.d: No such file or directory
    update-rc.d: error: insserv rejected the script header
    chdir: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
    Auto-start was enabled. Write "update-rc.d -f iobroker.sh remove" to disable auto-start
    iobroker is started. Go to "http://ip-addr:8081" to open the admin UI.
    install:yargs             â
    postinstall:decamelize â  â â¢ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ
    postinstall:os-locale     â â¢ââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââââ
    /opt/iobroker
    ââ⬠iobroker@0.7.1
      ââ⬠yargs@4.8.1
        ââ⬠cliui@3.2.0
        â ââ⬠strip-ansi@3.0.1
        â â âââ ansi-regex@2.1.1
        â âââ wrap-ansi@2.1.0
        âââ decamelize@1.2.0
        âââ get-caller-file@1.0.2
        âââ lodash.assign@4.2.0
        ââ⬠os-locale@1.4.0
        â ââ⬠lcid@1.0.0
        â   âââ invert-kv@1.0.0
        ââ⬠read-pkg-up@1.0.1
        â ââ⬠find-up@1.1.2
        â â âââ path-exists@2.1.0
        â â ââ⬠pinkie-promise@2.0.1
        â â   âââ pinkie@2.0.4
        â ââ⬠read-pkg@1.1.0
        â   ââ⬠load-json-file@1.1.0
        â   â âââ graceful-fs@4.1.11
        â   â ââ⬠parse-json@2.2.0
        â   â â ââ⬠error-ex@1.3.0
        â   â â   âââ is-arrayish@0.2.1
        â   â âââ pify@2.3.0
        â   â ââ⬠strip-bom@2.0.0
        â   â   âââ is-utf8@0.2.1
        â   ââ⬠normalize-package-data@2.3.5
        â   â âââ hosted-git-info@2.2.0
        â   â ââ⬠is-builtin-module@1.0.0
        â   â â âââ builtin-modules@1.1.1
        â   â âââ semver@5.3.0
        â   â ââ⬠validate-npm-package-license@3.0.1
        â   â   ââ⬠spdx-correct@1.0.2
        â   â   â âââ spdx-license-ids@1.2.2
        â   â   âââ spdx-expression-parse@1.0.4
        â   âââ path-type@1.1.0
        âââ require-directory@2.1.1
        âââ require-main-filename@1.0.1
        âââ set-blocking@2.0.0
        ââ⬠string-width@1.0.2
        â âââ code-point-at@1.1.0
        â ââ⬠is-fullwidth-code-point@1.0.0
        â   âââ number-is-nan@1.0.1
        âââ which-module@1.0.0
        âââ window-size@0.2.0
        âââ y18n@3.2.1
        ââ⬠yargs-parser@2.4.1
          âââ camelcase@3.0.0
    runTopLevelLifecycles     â
    root@odroid64:/opt/iobroker#</anonymous>`
    Kann mir jemand sagen was die Meldungen zu bedeuten haben und ob ich an irgendeiner Stelle mit Problemen im iobroker zu rechnen habe? Wie gesagt, iobroker läuft und die ersten Adapter sind installiert. Bevor ich weitermache wollte ich mich aber erkundigen ob bei der Installation etwas "ernsthaft" schiefgelaufen ist.
    Gruß,
    jawr[/i]
    • andreA Offline
      andreA Offline
      andre
      @jawr:
      `install:yargs             â
      path.js:424
          at Error (native)
      install:yargs             â
      /opt/iobroker
      ââ⬠iobroker@0.7.1
        ââ⬠yargs@4.8.1
          ââ⬠cliui@3.2.0
          ââ⬠os-locale@1.4.0
          â ââ⬠lcid@1.0.0
          â ââ⬠find-up@1.1.2
          â ââ⬠read-pkg@1.1.0
          â   â âââ pify@2.3.0
          âââ y18n@3.2.1
            âââ camelcase@3.0.0
      Gruß,
      jawr
      ich muss das hier nochmal raus holen, weil ich sonst irgendwie nichts finde. :)
      Ich habe eben auch mal versucht einen iobroker unter node 6 zu installieren (unter debian).
      `~~[code]~~root@iobroker_dev:/# node -v
      v6.10.3
      root@iobroker_dev:/# npm -v
      3.10.10[/code]`
      Dabei habe ich auch eine deiner npm-Warnmeldungen bekommen, undzwar diese hier:
      `~~[code]~~npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'
      [/code]`
      ioBroker läuft danach zwar, aber irgendwas scheint da ja nicht rund zu sein, oder?
      Kann das jemand aufklären? Würde gerne Node 6 zum Standard in meinem Docker-image machen, aber so ein bisschen Bauchgrummeln habe ich dabei schon... ;)
      MfG,
      André[/i]
      Bitte keine Support-Fragen per PN! Nutzt die öffentliche Kanäle damit auch andere von den Antworten profitieren können!
        Dies ist keine Fehlermeldung!
        Um etwas genaues sagen zu können brauchen wir etwas mehr Infos
        Rainer
        • andreA Offline
          andreA Offline
          andre
          @Homoran:
          Rainer `
          Hallo Rainer,
          alles wird gut. Mir ist bewusst dass es sich nicht um eine Fehlermeldung handelt, deshalb schrieb ich ja auch:
          @andre:
          Zur Vermeidung von doppelten Themen habe ich, als vorbildlicher Forenuser, zu allererst die Suchfunktion genutzt. :) Dabei ist mir dieser, noch unbeantwortete Thread in die Hände gefallen. Da hier die selbe Warnmeldung beschrieben wird, habe ich mich mal dran gehängt.
          Leider bin ich weder Thread Starter noch Admin, sodass wohl einer von euch den Betreff ändern müsste…
          Was Informationen angeht, bitte einfach Fragen stellen. Ich liefere was ich kann, weiß aber nicht was zur Analyse noch notwendig ist. Aktuell stellt es sich so dar:
          Bei der installation von iobroker auf meinem debian testsystem mit Node 6 erscheint die ober genannte Warnmeldung. Im Installationslog sieht das dann so aus:
          Step 15 : RUN npm install iobroker --unsafe-perm && echo $(hostname) > .install_host
           ---> Running in 9186d78d959d
          > iobroker@1.0.0 install /opt/iobroker/node_modules/iobroker
          > node lib/setup.js
          npm install iobroker.discovery --production --prefix /opt/iobroker
          /opt/iobroker
          `-- iobroker@1.0.0
            `-- yargs@7.1.0
              +-- camelcase@3.0.0
              +-- cliui@3.2.0
              | +-- strip-ansi@3.0.1
              | | `-- ansi-regex@2.1.1
              | `-- wrap-ansi@2.1.0
              +-- decamelize@1.2.0
              +-- get-caller-file@1.0.2
              +-- os-locale@1.4.0
              | `-- lcid@1.0.0
              |   `-- invert-kv@1.0.0
              +-- read-pkg-up@1.0.1
              | +-- find-up@1.1.2
              | | +-- path-exists@2.1.0
              | | `-- pinkie-promise@2.0.1
              | |   `-- pinkie@2.0.4
              | `-- read-pkg@1.1.0
              |   +-- load-json-file@1.1.0
              |   | +-- graceful-fs@4.1.11
              |   | +-- parse-json@2.2.0
              |   | | `-- error-ex@1.3.1
              |   | |   `-- is-arrayish@0.2.1
              |   | +-- pify@2.3.0
              |   | `-- strip-bom@2.0.0
              |   |   `-- is-utf8@0.2.1
              |   +-- normalize-package-data@2.3.8
              |   | +-- hosted-git-info@2.4.2
              |   | +-- is-builtin-module@1.0.0
              |   | | `-- builtin-modules@1.1.1
              |   | +-- semver@5.3.0
              |   | `-- validate-npm-package-license@3.0.1
              |   |   +-- spdx-correct@1.0.2
              |   |   | `-- spdx-license-ids@1.2.2
              |   |   `-- spdx-expression-parse@1.0.4
              |   `-- path-type@1.1.0
              +-- require-directory@2.1.1
              +-- require-main-filename@1.0.1
              +-- set-blocking@2.0.0
              +-- string-width@1.0.2
              | +-- code-point-at@1.1.0
              | `-- is-fullwidth-code-point@1.0.0
              |   `-- number-is-nan@1.0.1
              +-- which-module@1.0.0
              +-- y18n@3.2.1
              `-- yargs-parser@5.0.0
          Nicht wundern, dass ist ein Auszug aus meinem Docker Build Prozess, funktioniert aber wie eine Konsole (Daher das "STEP 15" am Anfang). Letztendlich wird schlicht````
          Als ich gestern meinen Test-Pi mit Raspian und Node 6 neu aufgesetzt habe, hatte ich die selbe Warnmeldung…
          MfG,
          André
            Hallo André,
            Danke für den extended log :D
            Ich sehe darin nichts besorgniserregendes.
            Die Installation findet einen Ordner nicht, läuft aber korrekt durch.
            Seit npm 3 hat sich die Ordnerstruktur geändert, mag sein, dass die Meldung daher rührt.
            Rainer
            • F Offline
              frank62
              @Homoran:
              Rainer `
              Weiss da jetzt jemand etwas genaueres?
              MfG
              Frank62
                Hallo und Willkommenim Forum!
                könntest du deine Frage bitte etwas präzisieren
                Rainer
