  4. [geloest] Gembird, Energenie Lan-Steckdosen
    5.9k
24 Beiträge 4 Kommentatoren 6.8k Aufrufe
    mickyboys
    Ich habe die CURL mit Chrome Dev-Inspector ausgelesen und in ein shellskript gepackt. Dieses starte ich nun per skript aus iobroker. Damit funktioniert es super…
    so sieht der CURL vom Socket01 aus, aufgeteilt in Login, Delay 2 Sekunden, An oder aus, Delay 2 Sekunden, Logout
    #!/bin/bash
    curl 'http://192.168.1.9/login.html' -H 'Origin: http://192.168.1.9' -H 'Accept-Encoding: gzip, deflate' -H 'Accept-Language: en-US,en;q=0.8,de;q=0.6' -H 'Upgrade-Insecure-Requests: 1' -H 'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.110 Safari/537.36' -H 'Content-Type: application/x-www-form-urlencoded' -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8' -H 'Cache-Control: max-age=0' -H 'Referer: http://192.168.1.9/' -H 'Connection: keep-alive' --data 'pw=1' --compressed
    sleep 2
    curl 'http://192.168.1.9/' -H 'Origin: http://192.168.1.9' -H 'Accept-Encoding: gzip, deflate' -H 'Accept-Language: en-US,en;q=0.8,de;q=0.6' -H 'Upgrade-Insecure-Requests: 1' -H 'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.110 Safari/537.36' -H 'Content-Type: application/x-www-form-urlencoded' -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8' -H 'Cache-Control: max-age=0' -H 'Referer: http://192.168.1.9/login.html' -H 'Connection: keep-alive' --data 'cte1=0&cte2=&cte3=&cte4=' --compressed
    sleep 2
    curl 'http://192.168.1.9/login.html' -H 'Accept-Encoding: gzip, deflate, sdch' -H 'Accept-Language: en-US,en;q=0.8,de;q=0.6' -H 'Upgrade-Insecure-Requests: 1' -H 'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_12_3) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.110 Safari/537.36' -H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8' -H 'Referer: http://192.168.1.9/' -H 'Connection: keep-alive' --compressed
    Und so das Script was aus iobroker gestartet wird. Hier werden jeweils der An oder Aus Befehl getriggert in abhaengigkeit zum Status.
    on({id: "javascript.0.scriptEnabled.common.HardShutdown.LeftSocket-1_Dummy"/*scriptEnabled.common.HardShutdown.LeftSocket-1_Dummy*/, change: "ne"}, function (obj) {
      var value = obj.state.val;
      if (getState("javascript.0.scriptEnabled.common.HardShutdown.LeftSocket-1_Dummy").val == true) {
        exec('bash /home/pi/GembirdPowerSocket/LeftSocket1-on.sh');
        console.log("exec: " + 'bash /home/pi/GembirdPowerSocket/LeftSocket1-on.sh');
      } else if (getState("javascript.0.scriptEnabled.common.HardShutdown.LeftSocket-1_Dummy").val == false) {
        exec('bash /home/pi/GembirdPowerSocket/LeftSocket1-off.sh');
        console.log("exec: " + 'bash /home/pi/GembirdPowerSocket/LeftSocket1-off.sh');
    Basti97B 1 Antwort Letzte Antwort
    • Basti97B Offline
      Basti97B Offline
      Basti97
      schrieb am zuletzt editiert von Basti97
      Hat jemand eine Lösung für die Gembird Steckdose gefunden um sie in iob zu integrieren?
      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
      • M mickyboys
        Ich wuerde gerne meine LAN Steckdosen (http://energenie.com/item.aspx?id=7416) in iobroker implementieren.
        Einfache Befehle wie Ein oder Aus wuerden schonmal reichen. Ich habe im Netz nicht viel gefunden was mich weiter bringt.
        FHEM oder OpenHab haben das schon implementiert. Soweit so gut, es soll gehen und die Befehle sehen wohl wie folgt aus.
        1. Befehl: http://Deine-IP/login.html
        Dann einen POST Befehl –> pw=1 (Dein Passwort um dich auf die Seite zu loggen)
        2. Befehl: http://192.168.1.90/status.html
        Dann einen POST Befehl –> cte1=0 (cteX steht fuer die jeweilige Steckdose, 0 oder 1 fuer Aus oder An)
        Auf der Seite gibt es mehr Infos. http://forum.micasaverde.com/index.php/ … ek8u6jn3m0
        Ich bin auf eure Hilfe angewiesen - Komme bei diesem einfachen Tasks nicht mehr weiter.
        Vielen Dank
        Basti97B Offline
        Basti97B Offline
        Basti97
        @mickyboys Hast du das irgendwie hinbekommen die Steckdose in iob zu integrieren bzw zu steuern da dein Post als gelöst markiert wurde. Ich habe es nun mehrmals mit meiner Steckdose probiert und bekomme es einfach nicht hin.
        • M mickyboys
          #!/bin/bash
          sleep 2
          sleep 2
          Basti97B Offline
          Basti97B Offline
          Basti97
          @mickyboys Denkst du da man das Script auch direkt per iobroker auslösen kann. Ich weiß der Beitrag ist schon alt aber vielleicht hast du es ja in der zwischen Zeit laufen?
