Meldung: "ADAPTER_ALREADY_RUNNING" nach Neustart
mir ist vor Kurzem aufgefallen, das nach einem Systemneustart immer diese Meldung ("ADAPTER_ALREADY_RUNNING") bei fast allen Adaptern auftaucht:
Hier mal ein kurzer Auszug aus dem LOG:2022-01-15 08:36:58.697 - info: host.IO-Broker-Server instance system.adapter.info.0 started with pid 11744 2022-01-15 08:36:59.776 - error: info.0 (11744) info.0 already running 2022-01-15 08:36:59.777 - warn: info.0 (11744) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-01-15 08:37:00.314 - error: host.IO-Broker-Server instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:00.314 - info: host.IO-Broker-Server Restart adapter system.adapter.info.0 because enabled 2022-01-15 08:37:01.798 - info: host.IO-Broker-Server instance system.adapter.hm-rpc.1 started with pid 2232 2022-01-15 08:37:02.514 - info: hm-rpc.1 (2232) starting. Version 1.15.0 in I:/iobroker/node_modules/iobroker.hm-rpc, node: v14.18.1, js-controller: 3.3.22 2022-01-15 08:37:02.568 - info: hm-rpc.1 (2232) xmlrpc server is trying to listen on 0.0.0.0:2010 2022-01-15 08:37:02.568 - info: hm-rpc.1 (2232) xmlrpc client is trying to connect to 192.168.1.100:2010/ with ["http://192.168.1.14:2010","IO-Broker-Server:hm-rpc.1"] 2022-01-15 08:37:02.603 - info: hm-rpc.1 (2232) Connected 2022-01-15 08:37:02.638 - info: hm-rpc.1 (2232) xmlrpc <- listDevices ["IO-Broker-Server:hm-rpc.1"] 2022-01-15 08:37:02.679 - info: hm-rpc.1 (2232) xmlrpc -> 0 devices 2022-01-15 08:37:02.689 - info: host.IO-Broker-Server instance system.adapter.hs100.0 started with pid 11964 2022-01-15 08:37:02.993 - info: hm-rpc.1 (2232) xmlrpc <- newDevices 264 2022-01-15 08:37:03.029 - info: hm-rpc.1 (2232) new HMIP devices/channels after filter: 0 2022-01-15 08:37:03.202 - error: hs100.0 (11964) hs100.0 already running 2022-01-15 08:37:03.203 - warn: hs100.0 (11964) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-01-15 08:37:03.758 - error: host.IO-Broker-Server instance system.adapter.hs100.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:03.758 - info: host.IO-Broker-Server Restart adapter system.adapter.hs100.0 because enabled 2022-01-15 08:37:05.984 - info: host.IO-Broker-Server instance system.adapter.ping.0 started with pid 3520 2022-01-15 08:37:06.674 - info: ping.0 (3520) starting. Version 1.5.0 in I:/iobroker/node_modules/iobroker.ping, node: v14.18.1, js-controller: 3.3.22 2022-01-15 08:37:06.685 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 started with pid 4368 2022-01-15 08:37:07.136 - error: simple-api.0 (4368) simple-api.0 already running 2022-01-15 08:37:07.137 - warn: simple-api.0 (4368) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-01-15 08:37:07.689 - error: host.IO-Broker-Server instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:07.689 - info: host.IO-Broker-Server Restart adapter system.adapter.simple-api.0 because enabled 2022-01-15 08:37:08.710 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 started with pid 11468 2022-01-15 08:37:09.378 - info: simple-api.0 (11468) starting. Version 2.6.2 in I:/iobroker/node_modules/iobroker.simple-api, node: v14.18.1, js-controller: 3.3.22 2022-01-15 08:37:09.429 - info: simple-api.0 (11468) simpleAPI server listening on port 8087 2022-01-15 08:37:09.429 - info: simple-api.0 (11468) Allow states only when user is owner: false 2022-01-15 08:37:09.430 - info: simple-api.0 (11468) http server listening on port 8087 2022-01-15 08:37:10.702 - info: host.IO-Broker-Server instance system.adapter.deconz.0 started with pid 3008 2022-01-15 08:37:11.185 - error: deconz.0 (3008) deconz.0 already running 2022-01-15 08:37:11.743 - error: host.IO-Broker-Server instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:11.743 - info: host.IO-Broker-Server Restart adapter system.adapter.deconz.0 because enabled 2022-01-15 08:37:14.280 - info: host.IO-Broker-Server instance system.adapter.mihome-vacuum.0 started with pid 11200 2022-01-15 08:37:14.700 - info: host.IO-Broker-Server instance system.adapter.squeezeboxrpc.0 started with pid 3620 2022-01-15 08:37:15.418 - error: squeezeboxrpc.0 (3620) squeezeboxrpc.0 already running 2022-01-15 08:37:15.419 - warn: squeezeboxrpc.0 (3620) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-01-15 08:37:15.972 - error: host.IO-Broker-Server instance system.adapter.squeezeboxrpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:15.972 - info: host.IO-Broker-Server Restart adapter system.adapter.squeezeboxrpc.0 because enabled 2022-01-15 08:37:18.699 - info: host.IO-Broker-Server instance system.adapter.upnp.0 started with pid 4160 2022-01-15 08:37:19.334 - error: upnp.0 (4160) upnp.0 already running 2022-01-15 08:37:19.335 - warn: upnp.0 (4160) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-01-15 08:37:19.983 - error: host.IO-Broker-Server instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:19.983 - info: host.IO-Broker-Server Restart adapter system.adapter.upnp.0 because enabled 2022-01-15 08:37:21.798 - info: host.IO-Broker-Server instance system.adapter.web.0 started with pid 10204 2022-01-15 08:37:22.527 - info: web.0 (10204) starting. Version 3.4.16 in I:/iobroker/node_modules/iobroker.web, node: v14.18.1, js-controller: 3.3.22 2022-01-15 08:37:22.655 - info: web.0 (10204) socket.io server listening on port 8082 2022-01-15 08:37:22.657 - info: web.0 (10204) http server listening on port 8082 2022-01-15 08:37:22.667 - info: host.IO-Broker-Server instance system.adapter.yahka.0 started with pid 11636 2022-01-15 08:37:23.390 - error: yahka.0 (11636) yahka.0 already running 2022-01-15 08:37:23.391 - warn: yahka.0 (11636) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-01-15 08:37:23.942 - error: host.IO-Broker-Server instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:23.943 - info: host.IO-Broker-Server Restart adapter system.adapter.yahka.0 because enabled 2022-01-15 08:37:26.683 - info: host.IO-Broker-Server instance system.adapter.yahka.2 started with pid 9348 2022-01-15 08:37:27.282 - error: yahka.2 (9348) yahka.2 already running 2022-01-15 08:37:27.282 - warn: yahka.2 (9348) Terminated (ADAPTER_ALREADY_RUNNING): Without reason 2022-01-15 08:37:27.826 - error: host.IO-Broker-Server instance system.adapter.yahka.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING) 2022-01-15 08:37:27.826 - info: host.IO-Broker-Server Restart adapter system.adapter.yahka.2 because enabled 2022-01-15 08:37:30.342 - info: host.IO-Broker-Server instance system.adapter.info.0 started with pid 7240 2022-01-15 08:37:30.695 - info: host.IO-Broker-Server instance scheduled system.adapter.coronavirus-statistics.0 30 6 * * * 2022-01-15 08:37:30.698 - info: host.IO-Broker-Server instance system.adapter.coronavirus-statistics.0 started with pid 12212 2022-01-15 08:37:31.494 - info: coronavirus-statistics.0 (12212) starting. Version 0.8.7 in I:/iobroker/node_modules/iobroker.coronavirus-statistics, node: v14.18.1, js-controller: 3.3.22 2022-01-15 08:37:33.769 - info: host.IO-Broker-Server instance system.adapter.hs100.0 started with pid 12192 2022-01-15 08:37:34.533 - info: sql.0 (11496) enabled logging of hs100.0.192_168_1_188.power, Alias=false 2022-01-15 08:37:34.677 - info: host.IO-Broker-Server instance system.adapter.fritzbox.0 started with pid 9404Ich habe mir zuerst nichts dabei gedacht, wollte jedoch mal einmal nachfragen, ob das so okay ist. Das System an sich macht so keine Probleme - nur halt nach dem Neustart erscheinen immer wieder diese Hinweise im LOG.
Systemdata Bitte Ausfüllen Hardwaresystem: NUC Arbeitsspeicher: 12GB Festplattenart: SSD Betriebssystem: Windows 10 Nodejs-Version: 14.18.1 NPM-Version: 6.14.15 Installationsart: Manuell -
Systemdata Bitte Ausfüllen Hardwaresystem: NUC Arbeitsspeicher: 12GB Festplattenart: SSD Betriebssystem: Windows 10 Nodejs-Version: 14.18.1 NPM-Version: 6.14.15 Installationsart: Manuell @surfer09 sagte in Meldung: "ADAPTER_ALREADY_RUNNING" nach Neustart:
- was ist ein "Systemstart"?
- wie führst du den aus?
- wirklich immer?
- das deutet darauf hin, dass bei dem Systemstart" iobroker nicht beendet wird
- oder dein ioB startet doppelt????
- wirklich immer?
@homoran: Mit Systemneustart meine ich einen kompletten Neustart vom Windows und somit logischerweise auch vom IOBroker.
Wo kann ich denn nachsehen, ob der IOBroker doppelt startet? Wenn ich den Windows Dienst stoppe, dann komme ich auch nicht mehr auf die Weboberfläche, somit gehe ich davon aus, dass dort nicht noch eine 2. Geschichte irgendwo im Hintergrund läuft. "iobroker status" liefert dann auch die Info, dass er nicht mehr läuft. - was ist ein "Systemstart"?
Wo kann ich denn nachsehen, ob der IOBroker doppelt startet? Wenn ich den Windows Dienst stoppe, dann komme ich auch nicht mehr auf die Weboberfläche, somit gehe ich davon aus, dass dort nicht noch eine 2. Geschichte irgendwo im Hintergrund läuft. "iobroker status" liefert dann auch die Info, dass er nicht mehr läuft.@surfer09 sagte in Meldung: "ADAPTER_ALREADY_RUNNING" nach Neustart:
vom Windows
da kann ich nichts zu beitragen - Sorry
