  4. Meldung: "ADAPTER_ALREADY_RUNNING" nach Neustart
    6.3k
windows 10log-eintragalready running
4 Beiträge 2 Kommentatoren 299 Aufrufe
  • surfer09S Offline
    surfer09S Offline
    surfer09
    mir ist vor Kurzem aufgefallen, das nach einem Systemneustart immer diese Meldung ("ADAPTER_ALREADY_RUNNING") bei fast allen Adaptern auftaucht:
    Hier mal ein kurzer Auszug aus dem LOG:
    2022-01-15 08:36:58.697 - info: host.IO-Broker-Server instance system.adapter.info.0 started with pid 11744
    2022-01-15 08:36:59.776 - error: info.0 (11744) info.0 already running
    2022-01-15 08:36:59.777 - warn: info.0 (11744) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-01-15 08:37:00.314 - error: host.IO-Broker-Server instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:00.314 - info: host.IO-Broker-Server Restart adapter system.adapter.info.0 because enabled
    2022-01-15 08:37:01.798 - info: host.IO-Broker-Server instance system.adapter.hm-rpc.1 started with pid 2232
    2022-01-15 08:37:02.514 - info: hm-rpc.1 (2232) starting. Version 1.15.0 in I:/iobroker/node_modules/iobroker.hm-rpc, node: v14.18.1, js-controller: 3.3.22
    2022-01-15 08:37:02.568 - info: hm-rpc.1 (2232) xmlrpc server is trying to listen on 0.0.0.0:2010
    2022-01-15 08:37:02.568 - info: hm-rpc.1 (2232) xmlrpc client is trying to connect to 192.168.1.100:2010/ with ["http://192.168.1.14:2010","IO-Broker-Server:hm-rpc.1"]
    2022-01-15 08:37:02.603 - info: hm-rpc.1 (2232) Connected
    2022-01-15 08:37:02.638 - info: hm-rpc.1 (2232) xmlrpc <- listDevices ["IO-Broker-Server:hm-rpc.1"]
    2022-01-15 08:37:02.679 - info: hm-rpc.1 (2232) xmlrpc -> 0 devices
    2022-01-15 08:37:02.689 - info: host.IO-Broker-Server instance system.adapter.hs100.0 started with pid 11964
    2022-01-15 08:37:02.993 - info: hm-rpc.1 (2232) xmlrpc <- newDevices 264
    2022-01-15 08:37:03.029 - info: hm-rpc.1 (2232) new HMIP devices/channels after filter: 0
    2022-01-15 08:37:03.202 - error: hs100.0 (11964) hs100.0 already running
    2022-01-15 08:37:03.203 - warn: hs100.0 (11964) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-01-15 08:37:03.758 - error: host.IO-Broker-Server instance system.adapter.hs100.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:03.758 - info: host.IO-Broker-Server Restart adapter system.adapter.hs100.0 because enabled
    2022-01-15 08:37:05.984 - info: host.IO-Broker-Server instance system.adapter.ping.0 started with pid 3520
    2022-01-15 08:37:06.674 - info: ping.0 (3520) starting. Version 1.5.0 in I:/iobroker/node_modules/iobroker.ping, node: v14.18.1, js-controller: 3.3.22
    2022-01-15 08:37:06.685 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 started with pid 4368
    2022-01-15 08:37:07.136 - error: simple-api.0 (4368) simple-api.0 already running
    2022-01-15 08:37:07.137 - warn: simple-api.0 (4368) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-01-15 08:37:07.689 - error: host.IO-Broker-Server instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:07.689 - info: host.IO-Broker-Server Restart adapter system.adapter.simple-api.0 because enabled
    2022-01-15 08:37:08.710 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 started with pid 11468
    2022-01-15 08:37:09.378 - info: simple-api.0 (11468) starting. Version 2.6.2 in I:/iobroker/node_modules/iobroker.simple-api, node: v14.18.1, js-controller: 3.3.22
    2022-01-15 08:37:09.429 - info: simple-api.0 (11468) simpleAPI server listening on port 8087
    2022-01-15 08:37:09.429 - info: simple-api.0 (11468) Allow states only when user is owner: false
    2022-01-15 08:37:09.430 - info: simple-api.0 (11468) http server listening on port 8087
    2022-01-15 08:37:10.702 - info: host.IO-Broker-Server instance system.adapter.deconz.0 started with pid 3008
    2022-01-15 08:37:11.185 - error: deconz.0 (3008) deconz.0 already running
    2022-01-15 08:37:11.743 - error: host.IO-Broker-Server instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:11.743 - info: host.IO-Broker-Server Restart adapter system.adapter.deconz.0 because enabled
    2022-01-15 08:37:14.280 - info: host.IO-Broker-Server instance system.adapter.mihome-vacuum.0 started with pid 11200
    2022-01-15 08:37:14.700 - info: host.IO-Broker-Server instance system.adapter.squeezeboxrpc.0 started with pid 3620
    2022-01-15 08:37:15.418 - error: squeezeboxrpc.0 (3620) squeezeboxrpc.0 already running
    2022-01-15 08:37:15.419 - warn: squeezeboxrpc.0 (3620) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-01-15 08:37:15.972 - error: host.IO-Broker-Server instance system.adapter.squeezeboxrpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:15.972 - info: host.IO-Broker-Server Restart adapter system.adapter.squeezeboxrpc.0 because enabled
    2022-01-15 08:37:18.699 - info: host.IO-Broker-Server instance system.adapter.upnp.0 started with pid 4160
    2022-01-15 08:37:19.334 - error: upnp.0 (4160) upnp.0 already running
    2022-01-15 08:37:19.335 - warn: upnp.0 (4160) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-01-15 08:37:19.983 - error: host.IO-Broker-Server instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:19.983 - info: host.IO-Broker-Server Restart adapter system.adapter.upnp.0 because enabled
    2022-01-15 08:37:21.798 - info: host.IO-Broker-Server instance system.adapter.web.0 started with pid 10204
    2022-01-15 08:37:22.527 - info: web.0 (10204) starting. Version 3.4.16 in I:/iobroker/node_modules/iobroker.web, node: v14.18.1, js-controller: 3.3.22
    2022-01-15 08:37:22.655 - info: web.0 (10204) socket.io server listening on port 8082
    2022-01-15 08:37:22.657 - info: web.0 (10204) http server listening on port 8082
    2022-01-15 08:37:22.667 - info: host.IO-Broker-Server instance system.adapter.yahka.0 started with pid 11636
    2022-01-15 08:37:23.390 - error: yahka.0 (11636) yahka.0 already running
    2022-01-15 08:37:23.391 - warn: yahka.0 (11636) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-01-15 08:37:23.942 - error: host.IO-Broker-Server instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:23.943 - info: host.IO-Broker-Server Restart adapter system.adapter.yahka.0 because enabled
    2022-01-15 08:37:26.683 - info: host.IO-Broker-Server instance system.adapter.yahka.2 started with pid 9348
    2022-01-15 08:37:27.282 - error: yahka.2 (9348) yahka.2 already running
    2022-01-15 08:37:27.282 - warn: yahka.2 (9348) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
    2022-01-15 08:37:27.826 - error: host.IO-Broker-Server instance system.adapter.yahka.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
    2022-01-15 08:37:27.826 - info: host.IO-Broker-Server Restart adapter system.adapter.yahka.2 because enabled
    2022-01-15 08:37:30.342 - info: host.IO-Broker-Server instance system.adapter.info.0 started with pid 7240
    2022-01-15 08:37:30.695 - info: host.IO-Broker-Server instance scheduled system.adapter.coronavirus-statistics.0 30 6 * * *
    2022-01-15 08:37:30.698 - info: host.IO-Broker-Server instance system.adapter.coronavirus-statistics.0 started with pid 12212
    2022-01-15 08:37:31.494 - info: coronavirus-statistics.0 (12212) starting. Version 0.8.7 in I:/iobroker/node_modules/iobroker.coronavirus-statistics, node: v14.18.1, js-controller: 3.3.22
    2022-01-15 08:37:33.769 - info: host.IO-Broker-Server instance system.adapter.hs100.0 started with pid 12192
    2022-01-15 08:37:34.533 - info: sql.0 (11496) enabled logging of hs100.0.192_168_1_188.power, Alias=false
    2022-01-15 08:37:34.677 - info: host.IO-Broker-Server instance system.adapter.fritzbox.0 started with pid 9404
    Ich habe mir zuerst nichts dabei gedacht, wollte jedoch mal einmal nachfragen, ob das so okay ist. Das System an sich macht so keine Probleme - nur halt nach dem Neustart erscheinen immer wieder diese Hinweise im LOG.
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC
    Arbeitsspeicher: 12GB
    Festplattenart: SSD
    Betriebssystem: Windows 10
    Nodejs-Version: 14.18.1
    NPM-Version: 6.14.15
    Installationsart: Manuell
    • surfer09S surfer09
      Hardwaresystem: NUC
      Festplattenart: SSD
      @surfer09 sagte in Meldung: "ADAPTER_ALREADY_RUNNING" nach Neustart:
      • was ist ein "Systemstart"?
        • wie führst du den aus?
      • wirklich immer?
        • das deutet darauf hin, dass bei dem Systemstart" iobroker nicht beendet wird
        • oder dein ioB startet doppelt????
      surfer09S 1 Antwort Letzte Antwort
        • wirklich immer?
        surfer09S Offline
        surfer09S Offline
        surfer09
        @homoran: Mit Systemneustart meine ich einen kompletten Neustart vom Windows und somit logischerweise auch vom IOBroker.
        Wo kann ich denn nachsehen, ob der IOBroker doppelt startet? Wenn ich den Windows Dienst stoppe, dann komme ich auch nicht mehr auf die Weboberfläche, somit gehe ich davon aus, dass dort nicht noch eine 2. Geschichte irgendwo im Hintergrund läuft. "iobroker status" liefert dann auch die Info, dass er nicht mehr läuft.
          vom Windows
          da kann ich nichts zu beitragen - Sorry
