  4. Linux Problem Gyp Error
    6.1k
5 Beiträge 3 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    Rogni
    Guten Morgen,
    ich bin nicht so der Linux Crack, kann mir da jemand helfen??
    root@IOBroker-Neu:/opt/iobroker# sudo iobroker upgrade self
    Update js-controller from @3.3.21 to @3.3.22
    NPM version: 6.14.15
    npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefi        x "/opt/iobroker" (System call)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
    ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(        v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is        deprecated [-Wdeprecated-declarations]
       Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback),        1, args);
    In file included from ../authenticate_pam.cc:23:0:
    ../../nan/nan.h:1026:46: note: declared here
       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Na        n::NAN_METHOD_ARGS_TYPE)’:
    ../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Arra        y::Get(v8::Local<v8::String>)’
       Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecke        d());
    In file included from /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h        :67:0,
                     from ../../nan/nan.h:56,
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3717:43: note: candidat        e: v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v        8::Value>)
       V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3717:43: note:   candid        ate expects 2 arguments, 1 provided
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3720:43: note: candidat        e: v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3720:43: note:   candid        ate expects 2 arguments, 1 provided
    ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::Stri        ng::WriteUtf8(char [128], long unsigned int)’
        serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3037:7: note: candidate        : int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
       int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/v8.h:3037:7: note:   no know        n conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Arra        y::Get(v8::Local<v8::String>)’
       res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
    ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::Stri        ng::WriteUtf8(char [128], long unsigned int)’
        remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
    ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::Stri        ng::WriteUtf8(char [128], long unsigned int)’
      username->WriteUtf8(m->username, sizeof(m->username) - 1);
    ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::Stri        ng::WriteUtf8(char [128], long unsigned int)’
      password->WriteUtf8(m->password, sizeof(m->password) - 1);
    ../authenticate_pam.cc: At global scope:
    ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
     void init(Handle<Object> exports) {
    ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ tok        en
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
    In file included from ../../nan/nan.h:56:0,
    ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
     NODE_MODULE(authenticate_pam, init);
    /home/iobroker/.cache/node-gyp/14.18.3/include/node/node.h:787:36: note: in defi        nition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_module        s/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_proces        s.js:282:12)
    gyp ERR! System Linux 4.9.0-16-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gy        p/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v14.18.3
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Erik :mrgreen: :mrgreen:
    Thomas BraunT GlasfaserG R 3 Antworten Letzte Antwort
    • R Rogni
      Guten Morgen,
      gyp ERR! not ok
      @rogni sagte in Linux Problem Gyp Error:
      Seh ich...
      root login und sudo, der an der Stelle dann gleich doppelt falsch ist...
      Als user:
      iobroker stop
      iobroker del terminal
      iobroker update
      iobroker upgrade
      iobroker start
      • R Rogni
        Guten Morgen,
        gyp ERR! not ok
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        Erstmal ... bist du mit root angemeldet und dann gehört vor iobroker Befehlen kein sudo
        • R Rogni
          Guten Morgen,
          gyp ERR! not ok
          Rogni
          Erstmal Dankeschön, scheint geklappt zu haben ;) was macht der clean Terminal Befehl??
          • R Rogni
            @rogni
            Der löscht den 'kaputten' Adapter Terminal. Falls du
            damit meintest. clear gibt es auch als shell-Kommando, macht aber was anderes.
