  4. Fehler beim DECONZ Adapter
11 Beiträge 3 Kommentatoren 2.4k Aufrufe 2 Beobachtet
    bauzi
    Probleme mit Devons adapter.
    Was ist heir falsch und wie kann ich das fixen?
    Quelle
    Zeit
    warn
    Nachricht
    deconz.0
    2021-11-26 21:51:12.371	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:48:53.170	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:46:59.207	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:45:02.764	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:43:21.048	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:42:19.227	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:40:49.432	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:38:38.923	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:36:37.122	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:35:35.507	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:34:33.830	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:32:03.626	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:30:09.200	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    deconz.0
    2021-11-26 21:30:03.477	warn	Object of state "deconz.0.info.connection" is missing the required property "common.type"
    • B bauzi
      Quelle
      Zeit
      warn
      Nachricht
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      deconz.0
      haselchenH Offline
      haselchenH Offline
      haselchen
      @bauzi
      Wie Du gerade schon gelernt hast, Logs in Code Tags packen ;)
      Welche JS Controller Version hast Du?
      Adapter Version?
      B 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @bauzi
        Adapter Version?
        bauzi
        @haselchen
        Ok das war für mich ein Log deshalb nicht als Code aber man lernt ja nie aus.
        Mach ich natürlich dann auch.
        NODE.JS: V14.18.1
        NPM: V6.14.15
        • B bauzi
          @haselchen
          NODE.JS: V14.18.1
          NPM: V6.14.15
          haselchenH Offline
          haselchenH Offline
          haselchen
          @bauzi
          Bitte genau lesen!
          JS Controller
          Deconz Adapter
            @bauzi
            Bitte genau lesen!
            JS Controller
            Deconz Adapter
            bauzi
            @haselchen
            JS Controller
            Sorry wie finde ich das heraus?
            Deconz Adapter
            2.0.5 (1~)
            Wahrscheinlich das Thema mit Beta beim Adapter von heute Abend.
            Beta ist jetzt abgestellt.
            • B bauzi
              @haselchen
              JS Controller
              Deconz Adapter
              2.0.5 (1~)
              haselchenH Offline
              haselchenH Offline
              haselchen
              @bauzi
              Puh, da würfelst du aber ne Menge durcheinander.
              Der Deconz Adapter ist im stable bei 1.3.19
              Wenn du links auf der Leiste auf Host klickst, da steht dann die JS Controller Version
              Wo steht bei dir die 2.0.5 bzw wo hast du die her?
                @bauzi
                bauzi
                @haselchen
                Also JS Controller sollte dann 3.3.20 sein.
                Die 2.05 steht neben dem Devonz Adapter und ja daneben wiederum steht 1.3.19 verfügbar.
                Deshalb auch meine Aussage das ich da im Beta Modus den Adapter geladen habe.
                Wie downgade ich den wieder?
                • B bauzi
                  @haselchen
                  @bauzi
                  iobroker upgrade deconz@1.3.19
                  haut die stable Version rein.
                    @bauzi
                    bauzi
                    @thomas-braun said in Fehler beim DECONZ Adapter:
                    Danke!
                    Ich habe da noch ein paar 'Leichen' im Keller.
                    Um die stable reinzuhauen gehe ich genauso mit allen Adaptern vor richtig?
                    Also zum Beispiel
                    iobroker upgrade admin@5.1.25
                    • B bauzi
                      Danke!
                      Also zum Beispiel
                      @bauzi
                      Ja, das würde ich aber nur machen wenn es mit der jetzigen Version Probleme gibt. Sonst einfach abwarten bis eine höhere Versionsnummer irgendwann im stable auftaucht und dann da draufspringen.
                        @bauzi
                        bauzi
                        Ja klar.
                        Ich habe aber durch meine fehlerhafte Einstellung als Betanutzer vile Adapter nicht im Stable Mode.
                        Ich beobachte das jetzt und wenn ich Probleme habe, dann gehe ich auf die Stable Version.
                        So für heute genug.
                        Vielen Dank!
                        Ist schon klasse was einem hier geholfen wir.
