  4. LOG quillt mit javascript Fehler über.
    6.3k
7 Beiträge 3 Kommentatoren 820 Aufrufe 2 Beobachtet
  • H Offline
    hertob81
    mein LOG quillt mit den folgenden Meldungen über.
    Ich bin noch Laie, alles was ich vor ein paar Tagen gemacht habe war, die Adapter so zu aktuallisieren:
    sudo iobroker stop
    sudo iobroker update
    sudo iobroker upgrade self
    sudo iobroker start
    Könnt ihr mir helfen?
    2021-11-23 18:46:23.598  - warn: javascript.0 (29184) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:46:23.601  - warn: javascript.0 (29184)     at Object.<anonymous> (script.js.Beleuchtung.Film_Ab:125:7)
    2021-11-23 18:46:23.601  - warn: javascript.0 (29184)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
    2021-11-23 18:46:23.601  - warn: javascript.0 (29184)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2021-11-23 18:46:23.602  - warn: javascript.0 (29184)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    2021-11-23 18:46:23.602  - warn: javascript.0 (29184)     at processImmediate (internal/timers.js:461:21)
    2021-11-23 18:46:23.603  - warn: javascript.0 (29184) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:46:23.604  - warn: javascript.0 (29184)     at Object.<anonymous> (script.js.Energieüberwachung.Trockner:125:7)
    2021-11-23 18:46:23.605  - warn: javascript.0 (29184)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
    2021-11-23 18:46:23.605  - warn: javascript.0 (29184)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2021-11-23 18:46:23.605  - warn: javascript.0 (29184)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    2021-11-23 18:46:23.606  - warn: javascript.0 (29184)     at processImmediate (internal/timers.js:461:21)
    2021-11-23 18:46:23.606  - warn: javascript.0 (29184) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:46:23.608  - warn: javascript.0 (29184)     at Object.<anonymous> (script.js.Energieüberwachung.Waschmaschine:125:7)
    2021-11-23 18:46:23.608  - warn: javascript.0 (29184)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
    2021-11-23 18:46:23.608  - warn: javascript.0 (29184)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2021-11-23 18:46:23.609  - warn: javascript.0 (29184)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    2021-11-23 18:46:23.609  - warn: javascript.0 (29184)     at processImmediate (internal/timers.js:461:21)
    2021-11-23 18:46:28.030  - warn: meross.0 (9860) Can not get Abilities for Device 1909127140323125186448e1e9038373: Error: Timeout / undefined
    2021-11-23 18:46:46.231  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
    2021-11-23 18:46:46.248  - info: javascript.0 (29184) Got terminate signal TERMINATE_YOURSELF
    2021-11-23 18:46:46.249  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
    2021-11-23 18:46:46.251  - info: javascript.0 (29184) Stop script script.js.Beleuchtung.Film_Ab
    2021-11-23 18:46:46.253  - info: javascript.0 (29184) Stop script script.js.Energieüberwachung.Trockner
    2021-11-23 18:46:46.253  - info: javascript.0 (29184) Stop script script.js.Energieüberwachung.Waschmaschine
    2021-11-23 18:46:46.258  - info: javascript.0 (29184) terminating
    2021-11-23 18:46:46.260  - info: javascript.0 (29184) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-23 18:46:46.895  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-11-23 18:46:49.491  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 29478
    2021-11-23 18:46:52.615  - info: javascript.0 (29478) starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.7, js-controller: 3.3.19
    2021-11-23 18:46:52.745  - info: javascript.0 (29478) requesting all states
    2021-11-23 18:46:52.747  - info: javascript.0 (29478) requesting all objects
    2021-11-23 18:46:54.048  - info: javascript.0 (29478) received all objects
    2021-11-23 18:46:54.102  - info: javascript.0 (29478) received all states
    2021-11-23 18:47:04.027  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
    2021-11-23 18:47:04.060  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
    2021-11-23 18:47:04.233  - info: javascript.0 (29478) Start javascript script.js.Beleuchtung.Film_Ab
    2021-11-23 18:47:04.337  - warn: javascript.0 (29478) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:04.347  - warn: javascript.0 (29478)     at script.js.Beleuchtung.Film_Ab:57:10
    2021-11-23 18:47:04.348  - warn: javascript.0 (29478)     at script.js.Beleuchtung.Film_Ab:15:3
    2021-11-23 18:47:04.348  - info: javascript.0 (29478) script.js.Beleuchtung.Film_Ab: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:04.357  - info: javascript.0 (29478) Start javascript script.js.Energieüberwachung.Trockner
    2021-11-23 18:47:04.376  - warn: javascript.0 (29478) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:04.378  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Trockner:57:10
    2021-11-23 18:47:04.378  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Trockner:16:3
    2021-11-23 18:47:04.380  - info: javascript.0 (29478) script.js.Energieüberwachung.Trockner: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:04.381  - info: javascript.0 (29478) Start javascript script.js.Energieüberwachung.Waschmaschine
    2021-11-23 18:47:04.406  - warn: javascript.0 (29478) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:04.408  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Waschmaschine:57:10
    2021-11-23 18:47:04.408  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Waschmaschine:16:3
    2021-11-23 18:47:04.409  - info: javascript.0 (29478) script.js.Energieüberwachung.Waschmaschine: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:04.414  - info: javascript.0 (29478) Got terminate signal TERMINATE_YOURSELF
    2021-11-23 18:47:04.416  - info: javascript.0 (29478) Stop script script.js.Beleuchtung.Film_Ab
    2021-11-23 18:47:04.417  - info: javascript.0 (29478) Stop script script.js.Energieüberwachung.Trockner
    2021-11-23 18:47:04.418  - info: javascript.0 (29478) Stop script script.js.Energieüberwachung.Waschmaschine
    2021-11-23 18:47:04.428  - info: javascript.0 (29478) terminating
    2021-11-23 18:47:04.430  - info: javascript.0 (29478) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-23 18:47:05.064  - info: host.raspberrypi stopInstance system.adapter.javascript.0 killing pid 29478
    2021-11-23 18:47:05.186  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-11-23 18:47:07.188  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 29597
    2021-11-23 18:47:07.732  - warn: meross.0 (9860) Can not get Abilities for Device 1909127140323125186448e1e9038373: Error: Timeout / undefined
    2021-11-23 18:47:10.103  - info: javascript.0 (29597) starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.7, js-controller: 3.3.19
    2021-11-23 18:47:10.223  - info: javascript.0 (29597) requesting all states
    2021-11-23 18:47:10.225  - info: javascript.0 (29597) requesting all objects
    2021-11-23 18:47:11.602  - info: javascript.0 (29597) received all objects
    2021-11-23 18:47:11.658  - info: javascript.0 (29597) received all states
    2021-11-23 18:47:21.341  - info: javascript.0 (29597) Start javascript script.js.Beleuchtung.Film_Ab
    2021-11-23 18:47:21.434  - warn: javascript.0 (29597) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:21.444  - warn: javascript.0 (29597)     at script.js.Beleuchtung.Film_Ab:57:10
    2021-11-23 18:47:21.444  - warn: javascript.0 (29597)     at script.js.Beleuchtung.Film_Ab:15:3
    2021-11-23 18:47:21.445  - info: javascript.0 (29597) script.js.Beleuchtung.Film_Ab: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:21.449  - info: javascript.0 (29597) Start javascript script.js.Energieüberwachung.Trockner
    2021-11-23 18:47:21.469  - warn: javascript.0 (29597) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:21.470  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Trockner:57:10
    2021-11-23 18:47:21.471  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Trockner:16:3
    2021-11-23 18:47:21.473  - info: javascript.0 (29597) script.js.Energieüberwachung.Trockner: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:21.473  - info: javascript.0 (29597) Start javascript script.js.Energieüberwachung.Waschmaschine
    2021-11-23 18:47:21.490  - warn: javascript.0 (29597) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:21.492  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Waschmaschine:57:10
    2021-11-23 18:47:21.492  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Waschmaschine:16:3
    2021-11-23 18:47:21.493  - info: javascript.0 (29597) script.js.Energieüberwachung.Waschmaschine: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:27.110  - info: web.0 (10070) <==Disconnect system.user.admin from ::ffff:192.168.0.108 flot
    2021-11-23 18:47:27.850  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
    2021-11-23 18:47:27.859  - info: javascript.0 (29597) Got terminate signal TERMINATE_YOURSELF
    2021-11-23 18:47:27.859  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
    2021-11-23 18:47:27.862  - info: javascript.0 (29597) Stop script script.js.Beleuchtung.Film_Ab
    2021-11-23 18:47:27.864  - info: javascript.0 (29597) Stop script script.js.Energieüberwachung.Trockner
    2021-11-23 18:47:27.865  - info: javascript.0 (29597) Stop script script.js.Energieüberwachung.Waschmaschine
    2021-11-23 18:47:27.872  - info: javascript.0 (29597) terminating
    2021-11-23 18:47:27.876  - info: javascript.0 (29597) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-11-23 18:47:28.492  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-11-23 18:47:29.032  - info: web.0 (10070) ==>Connected system.user.admin from ::ffff:192.168.0.108
    2021-11-23 18:47:31.028  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 29681
    2021-11-23 18:47:34.390  - info: javascript.0 (29681) starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.7, js-controller: 3.3.19
    2021-11-23 18:47:34.505  - info: javascript.0 (29681) requesting all states
    2021-11-23 18:47:34.506  - info: javascript.0 (29681) requesting all objects
    2021-11-23 18:47:35.727  - info: javascript.0 (29681) received all objects
    2021-11-23 18:47:35.783  - info: javascript.0 (29681) received all states
    2021-11-23 18:47:45.810  - info: javascript.0 (29681) Start javascript script.js.Beleuchtung.Film_Ab
    2021-11-23 18:47:45.906  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:45.917  - warn: javascript.0 (29681)     at script.js.Beleuchtung.Film_Ab:57:10
    2021-11-23 18:47:45.917  - warn: javascript.0 (29681)     at script.js.Beleuchtung.Film_Ab:15:3
    2021-11-23 18:47:45.918  - info: javascript.0 (29681) script.js.Beleuchtung.Film_Ab: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:45.925  - info: javascript.0 (29681) Start javascript script.js.Energieüberwachung.Trockner
    2021-11-23 18:47:45.953  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:45.955  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Trockner:57:10
    2021-11-23 18:47:45.955  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Trockner:16:3
    2021-11-23 18:47:45.957  - info: javascript.0 (29681) script.js.Energieüberwachung.Trockner: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:45.958  - info: javascript.0 (29681) Start javascript script.js.Energieüberwachung.Waschmaschine
    2021-11-23 18:47:46.007  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:46.011  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Waschmaschine:57:10
    2021-11-23 18:47:46.011  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Waschmaschine:16:3
    2021-11-23 18:47:46.012  - info: javascript.0 (29681) script.js.Energieüberwachung.Waschmaschine: registered 7 subscriptions and 2 schedules
    2021-11-23 18:47:48.032  - warn: meross.0 (9860) Can not get Abilities for Device 1909127140323125186448e1e9038373: Error: Timeout / undefined
    2021-11-23 18:47:48.335  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:48.346  - warn: javascript.0 (29681)     at Object.<anonymous> (script.js.Beleuchtung.Film_Ab:125:7)
    2021-11-23 18:47:48.346  - warn: javascript.0 (29681)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
    2021-11-23 18:47:48.347  - warn: javascript.0 (29681)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2021-11-23 18:47:48.347  - warn: javascript.0 (29681)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    2021-11-23 18:47:48.347  - warn: javascript.0 (29681)     at processImmediate (internal/timers.js:461:21)
    2021-11-23 18:47:48.348  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:48.349  - warn: javascript.0 (29681)     at Object.<anonymous> (script.js.Energieüberwachung.Trockner:125:7)
    2021-11-23 18:47:48.349  - warn: javascript.0 (29681)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
    2021-11-23 18:47:48.350  - warn: javascript.0 (29681)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2021-11-23 18:47:48.350  - warn: javascript.0 (29681)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    2021-11-23 18:47:48.350  - warn: javascript.0 (29681)     at processImmediate (internal/timers.js:461:21)
    2021-11-23 18:47:48.351  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
    2021-11-23 18:47:48.352  - warn: javascript.0 (29681)     at Object.<anonymous> (script.js.Energieüberwachung.Waschmaschine:125:7)
    2021-11-23 18:47:48.352  - warn: javascript.0 (29681)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
    2021-11-23 18:47:48.352  - warn: javascript.0 (29681)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
    2021-11-23 18:47:48.353  - warn: javascript.0 (29681)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
    2021-11-23 18:47:48.353  - warn: javascript.0 (29681)     at processImmediate (internal/timers.js:461:21)
    Systemdata Bitte Ausfüllen
    Hardwaresystem: NUC/Pi3/etc.
    Arbeitsspeicher: 1GB
    Festplattenart: SD-Karte/SSD/HDD
    Betriebssystem: Ubuntu/Windows/Mac
    Node-Version: 10.x.x
    Nodejs-Version: 10.x.x
    NPM-Version: 6.x.x
    Installationsart: Skript/Manuell
    Image genutzt: Ja/Nein
    Ort/Name der Imagedatei: Link Hallo zusammen,
    sudo iobroker stop
    sudo iobroker start
    • H hertob81
      sudo iobroker stop
      sudo iobroker start
      NPM-Version: 6.x.x
      sudo iobroker stop
      sudo iobroker start
      @hertob81
      iobroker stop
      iobroker fix
      iobroker start
      Und gewöhn die das sudo an der Stelle ab, der iobroker wird ohne sudo angepackt.
      • H Offline
        hertob81
        Hallo Thomas,
        Danke für die Info.
        Magst mir noch verraten, was da dann im Hintergrund passiert?
        VG Tobias
        • H hertob81
          Hallo Thomas,
          Danke für die Info.
          VG Tobias
          @hertob81
          Das richtet die mutmaßlich verbogenen Rechte.
          H 1 Antwort Letzte Antwort
            @hertob81
            hertob81
            Muss mir das Sorgen machen?
            Oder anders gefragt:
            Be welchen "Warnungen" herrscht den Handlungsbedarf?
            Danke Dir!
            javascript.0	2021-11-24 19:31:54.938	warn	(22274) at processImmediate (internal/timers.js:461:21)
            javascript.0	2021-11-24 19:31:54.938	warn	(22274) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
            javascript.0	2021-11-24 19:31:54.938	warn	(22274) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
            javascript.0	2021-11-24 19:31:54.938	warn	(22274) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
            javascript.0	2021-11-24 19:31:54.937	warn	(22274) at Object.<anonymous> (script.js.Energieüberwachung.Waschmaschine:138:7)
            javascript.0	2021-11-24 19:31:54.936	warn	(22274) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
            javascript.0	2021-11-24 19:31:54.935	warn	(22274) at processImmediate (internal/timers.js:461:21)
            javascript.0	2021-11-24 19:31:54.935	warn	(22274) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
            javascript.0	2021-11-24 19:31:54.935	warn	(22274) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
            javascript.0	2021-11-24 19:31:54.935	warn	(22274) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
            javascript.0	2021-11-24 19:31:54.934	warn	(22274) at Object.<anonymous> (script.js.Energieüberwachung.Trockner:138:7)
            javascript.0	2021-11-24 19:31:54.933	warn	(22274) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
            javascript.0	2021-11-24 19:31:54.933	warn	(22274) at processImmediate (internal/timers.js:461:21)
            javascript.0	2021-11-24 19:31:54.933	warn	(22274) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
            javascript.0	2021-11-24 19:31:54.932	warn	(22274) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
            javascript.0	2021-11-24 19:31:54.932	warn	(22274) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
            javascript.0	2021-11-24 19:31:54.932	warn	(22274) at Object.<anonymous> (script.js.Beleuchtung.Film_Ab:138:7)
            javascript.0	2021-11-24 19:31:54.930	warn	(22274) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
            host.raspberrypi	2021-11-24 19:31:17.256	warn	Requested repository "latest" does not exist in config.
            • H hertob81
              Danke Dir!
              @hertob81 sagte:
              Das wird in 3 Skripten immer in Zeile 138 angemeckert. Gibt es diesen Datenpunkt nicht mehr oder hat er sich geändert?
                @hertob81 sagte:
                hertob81
                Ja, das ist mein Fenster-Sensor der aktuell ausgestiegen ist, da das Zigbee-Signal nicht immer reicht.
                Das sollte aber ab morgen mit den Osram-Steckdosen erledigt haben...
                Oder sollte ich den besser rausschmeißen?
                Danke!
