  4. RP4 - SSD defekt?
    6.3k
RP4 - SSD defekt?
3 Beiträge 2 Kommentatoren 168 Aufrufe 1 Beobachtet
    mguenther
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Pi4
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Debian
    Node-Version: 12.22.6
    Nodejs-Version: 12.22.6
    NPM-Version: 6.14.15
    Installationsart: Skript
    Image genutzt: Ja
    Ort/Name der Imagedatei: Raspian
    anscheinend ist meine Festplatte kaputt gegangen - ist da noch was zu retten? Meine Kenntnisse zu Linux sind so nix bis ganz wenig mittel...
    pi@raspberrypi:~ $ dmesg | grep -i ext4
    [    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:27:F2:57 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=b94fe324-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [    7.140429] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [    7.140538] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [    9.759846] EXT4-fs (sda2): re-mounted. Opts: (null)
    [5174417.762872] EXT4-fs error (device sda2) in add_dirent_to_buf:2019: Journal has aborted
    [5174417.763081] EXT4-fs warning (device sda2): ext4_end_bio:349: I/O error 10 writing to inode 789024 starting block 3280031)
    [5174417.763105] EXT4-fs (sda2): I/O error while writing superblock
    [5174417.763128] EXT4-fs error (device sda2): ext4_check_bdev_write_error:216: comm deCONZ: Error while async write back metadata
    [5174417.763180] EXT4-fs error (device sda2) in __ext4_new_inode:1229: Journal has aborted
    [5174417.763313] EXT4-fs (sda2): I/O error while writing superblock
    [5174417.763320] EXT4-fs (sda2): previous I/O error to superblock detected
    [5174417.763338] EXT4-fs error (device sda2) in ext4_orphan_add:3015: Journal has aborted
    [5174417.763404] EXT4-fs warning (device sda2): ext4_end_bio:349: I/O error 10 writing to inode 789024 starting block 3280287)
    [5174417.763416] EXT4-fs (sda2): I/O error while writing superblock
    [5174417.763422] EXT4-fs (sda2): previous I/O error to superblock detected
    [5174417.763458] EXT4-fs error (device sda2) in ext4_create:2634: IO failure
    [5174417.763501] EXT4-fs (sda2): previous I/O error to superblock detected
    [5174417.763609] EXT4-fs (sda2): I/O error while writing superblock
    [5174417.763615] EXT4-fs warning (device sda2): ext4_end_bio:349: I/O error 10 writing to inode 789024 starting block 3280543)
    [5174417.763620] EXT4-fs (sda2): I/O error while writing superblock
    [5174417.763648] EXT4-fs error (device sda2) in ext4_create:2634: Journal has aborted
    [5174417.763773] EXT4-fs (sda2): I/O error while writing superblock
    [5174417.763794] EXT4-fs warning (device sda2): ext4_end_bio:349: I/O error 10 writing to inode 789024 starting block 3280702)
    [5174417.763870] EXT4-fs (sda2): I/O error while writing superblock
    [5174417.763889] EXT4-fs error (device sda2): ext4_journal_check_start:83: Detected aborted journal
    [5174417.763901] EXT4-fs warning (device sda2): ext4_end_bio:349: I/O error 10 writing to inode 914852 starting block 2216559)
    [5174417.764037] EXT4-fs warning (device sda2): ext4_end_bio:349: I/O error 10 writing to inode 789024 starting block 3279519)
    [5174417.764089] EXT4-fs warning (device sda2): ext4_end_bio:349: I/O error 10 writing to inode 789024 starting block 3279775)
    [5186765.829009] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm which: reading directory lblock 0
    [5186765.829089] EXT4-fs: 2 callbacks suppressed
    [5186765.829092] EXT4-fs (sda2): I/O error while writing superblock
    [5186765.829186] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm which: reading directory lblock 0
    [5186765.829249] EXT4-fs (sda2): I/O error while writing superblock
    [5186797.391864] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm which: reading directory lblock 0
    [5186797.391931] EXT4-fs (sda2): I/O error while writing superblock
    [5186797.391990] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm which: reading directory lblock 0
    [5186797.392039] EXT4-fs (sda2): I/O error while writing superblock
    [5186797.403891] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm which: reading directory lblock 0
    [5186797.403957] EXT4-fs (sda2): I/O error while writing superblock
    [5186797.404016] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm which: reading directory lblock 0
    [5186797.404065] EXT4-fs (sda2): I/O error while writing superblock
    [5186797.493350] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm which: reading directory lblock 0
    [5186797.493416] EXT4-fs (sda2): I/O error while writing superblock
    [5186797.493472] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm which: reading directory lblock 0
    [5186797.493521] EXT4-fs (sda2): I/O error while writing superblock
    [5186798.305357] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #788931: lblock 0: comm chown: error -5 reading directory block
    [5186798.309782] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2611207: lblock 0: comm chown: error -5 reading directory block
    [5186814.029036] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.029565] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.029669] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.029755] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.029861] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.029930] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.030019] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.030086] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.030174] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186814.030241] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.036685] EXT4-fs warning: 97953 callbacks suppressed
    [5186819.036691] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.036762] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.036829] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.036897] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.036964] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.037041] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.037108] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.037175] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.037241] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186819.037309] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.984932] EXT4-fs warning: 1475 callbacks suppressed
    [5186832.984938] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985011] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985082] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985150] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985217] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985285] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985351] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985418] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985492] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186832.985557] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.986795] EXT4-fs warning: 98859 callbacks suppressed
    [5186837.986802] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.986880] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.986948] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.987017] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.987084] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.987152] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.987219] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.987286] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.987352] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186837.987420] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.203529] EXT4-fs warning: 1121 callbacks suppressed
    [5186846.203536] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.203612] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.203683] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.203752] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.203821] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.203887] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.203955] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.204022] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.204098] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186846.204164] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.206961] EXT4-fs warning: 99751 callbacks suppressed
    [5186851.206967] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207037] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207104] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207173] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207239] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207307] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207373] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207441] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207509] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186851.207575] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265236] EXT4-fs warning: 229 callbacks suppressed
    [5186858.265243] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265320] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265391] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265458] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265527] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265594] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265662] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265728] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265804] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186858.265870] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628302] EXT4-fs warning: 99990 callbacks suppressed
    [5186870.628308] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628384] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628456] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628524] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628592] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628659] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628727] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628795] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628864] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186870.628940] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.355775] EXT4-fs warning: 99990 callbacks suppressed
    [5186883.355781] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.355857] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.355928] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.355995] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.356063] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.356130] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.356197] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.356263] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.356340] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186883.356408] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.781265] EXT4-fs warning: 99990 callbacks suppressed
    [5186900.781275] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.781401] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.781518] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.781632] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.781745] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.781856] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.781968] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.782080] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.782202] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186900.782313] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787409] EXT4-fs warning: 99689 callbacks suppressed
    [5186905.787416] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787494] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787563] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787631] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787698] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787764] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787830] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787897] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.787964] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186905.788031] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.804965] EXT4-fs warning: 291 callbacks suppressed
    [5186918.804973] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805088] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805193] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805294] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805394] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805495] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805596] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805695] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805804] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186918.805904] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.807554] EXT4-fs warning: 99700 callbacks suppressed
    [5186923.807562] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.807640] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.807709] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.807777] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.807843] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.807909] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.807977] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.808043] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.808109] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186923.808175] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629079] EXT4-fs warning: 280 callbacks suppressed
    [5186929.629085] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629162] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629231] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629299] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629368] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629435] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629502] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629569] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629645] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186929.629713] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.209592] EXT4-fs warning: 99990 callbacks suppressed
    [5186941.209599] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.209677] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.209746] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.209814] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.209882] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.209950] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.210016] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.210083] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.210158] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186941.210226] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639301] EXT4-fs warning: 99990 callbacks suppressed
    [5186958.639307] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639383] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639453] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639521] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639589] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639656] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639722] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639790] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639866] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186958.639932] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.647923] EXT4-fs warning: 99833 callbacks suppressed
    [5186963.647930] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.647999] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648066] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648135] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648202] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648268] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648335] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648402] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648468] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5186963.648534] EXT4-fs warning (device sda2): htree_dirblock_to_tree:1003: inode #2485637: lblock 9: comm chown: error -5 reading directory block
    [5187000.135137] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm bash: reading directory lblock 0
    [5187000.135243] EXT4-fs (sda2): I/O error while writing superblock
    [5187000.135327] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm bash: reading directory lblock 0
    [5187000.135393] EXT4-fs (sda2): I/O error while writing superblock
    [5187003.614800] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm bash: reading directory lblock 0
    [5187003.614886] EXT4-fs (sda2): I/O error while writing superblock
    [5187003.614952] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm bash: reading directory lblock 0
    [5187003.615002] EXT4-fs (sda2): I/O error while writing superblock
    [5187041.869214] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm bash: reading directory lblock 0
    [5187041.869305] EXT4-fs (sda2): I/O error while writing superblock
    [5187041.869372] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm bash: reading directory lblock 0
    [5187041.869434] EXT4-fs (sda2): I/O error while writing superblock
    [5187045.110066] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #19424: comm bash: reading directory lblock 0
    [5187045.110158] EXT4-fs (sda2): I/O error while writing superblock
    [5187045.110224] EXT4-fs error (device sda2): __ext4_find_entry:1536: inode #1098: comm bash: reading directory lblock 0
    [5187045.110275] EXT4-fs (sda2): I/O error while writing superblock
    • M mguenther
      Hardwaresystem: Pi4
      Festplattenart: SSD
      Image genutzt: Ja
      @mguenther Sieht schlecht an aus.
        mguenther
        hmmm...
        warum geschieht das immer nachts? :)
        was tun? neue SSD? Sieht nach HW Problem aus - richtig? mit dem verseuchtem NPM kann das nix zu tun haben?
        Wenn neue SSD - hat einer eine Empfehlung?
