  4. Adapter löschen - gelöst
    6.3k
löschen
5 Beiträge 2 Kommentatoren 446 Aufrufe 2 Beobachtet
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    schrieb am zuletzt editiert von sissiwup
    ich habe eine Installation unter Linux Debian 11. Keine VM etc.
    Es sammeln sich immer mehr Adapter, die man nicht löschen kann.
    Als Beispiel der unifi Adapter.
    System it aktuell, Löschversuch siehe am Ende:
    root@zotac /opt/iobroker # iobroker stop && iobroker update && iobroker upgrade self && iobroker start
    Used repository: beta
    hash unchanged, use cached sources
    update done
    Adapter    "admin"         : 5.1.25   , installed 5.1.25
    Adapter    "backitup"      : 2.2.1    , installed 2.2.1
    Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
    Adapter    "devices"       : 1.0.9    , installed 1.0.9
    Adapter    "dwd"           : 2.7.7    , installed 2.7.7
    Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
    Adapter    "geofency"      : 1.0.3    , installed 1.0.3
    Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
    Adapter    "hm-rega"       : 3.0.32   , installed 3.0.32
    Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
    Adapter    "ical"          : 1.11.4   , installed 1.11.4
    Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
    Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
    Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
    Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
    Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
    Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
    Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
    Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
    Adapter    "info"          : 1.9.10   , installed 1.9.10
    Adapter    "javascript"    : 5.2.13   , installed 5.2.13
    Controller "js-controller" : 3.3.18   , installed 3.3.18
    Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
    Adapter    "ping"          : 1.5.0    , installed 1.5.0
    Adapter    "pushover"      : 2.0.5    , installed 2.0.5
    Adapter    "scenes"        : 2.3.8    , installed 2.3.8
    Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
    Adapter    "socketio"      : 3.1.5    , installed 3.1.5
    Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
    Adapter    "sql"           : 1.15.7   , installed 1.15.7
    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
    Adapter    "telegram"      : 1.10.0   , installed 1.10.0
    Adapter    "trashschedule" : 1.3.0    , installed 1.3.0
    Adapter    "unifi"         : 0.5.10   , installed 0.5.10
    Adapter    "vis"           : 1.4.5    , installed 1.4.5
    Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
    Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
    Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
    Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
    Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
    Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
    Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
    Adapter    "vis-material"  : 0.1.3    , installed 0.1.3
    Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
    Adapter    "vis-material-webfont": 0.0.3   , installed 0.0.3
    Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
    Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
    Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
    Adapter    "vis-weather"   : 2.5.4    , installed 2.5.4
    Adapter    "web"           : 3.4.13   , installed 3.4.13
    Adapter    "yahka"         : 0.13.1   , installed 0.13.1
    Host    "zotac"          is up to date.
    root@zotac /opt/iobroker # iobroker del unifi
    Delete adapter "unifi"
    host.zotac object unifi deleted
    host.zotac object unifi.admin deleted
    npm uninstall iobroker.unifi --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ELOOP
    npm ERR! syscall open
    npm ERR! path /opt/iobroker/node_modules/iobroker.objects-redis/package.json
    npm ERR! errno -40
    npm ERR! ELOOP: too many symbolic links encountered, open '/opt/iobroker/node_modules/iobroker.objects-redis/package.json'
    npm ERR!     /home/iobroker/.npm/_logs/2021-11-06T08_01_55_296Z-debug.log
    Error deleting adapter unifi from disk: Error: host.zotac: Cannot uninstall iobroker.unifi: 216
    You might have to delete it yourself!
    root@zotac /opt/iobroker # node -v
    v14.17.0
    root@zotac /opt/iobroker # npm -v
    6.14.13
    MfG
    Sissi
    • sissiwupS sissiwup
      update done
      npm ERR! code ELOOP
      npm ERR! errno -40
      v14.17.0
      6.14.13
      @sissiwup
      root@zotac
      Lass den Mist bleiben!
      Da sind irgendwoher falsche Links (meist im Kreis auf die Datei selber) gesetzt. Schau dir die Rechte und die Dateiart an.
      sissiwupS 1 Antwort Letzte Antwort
        @sissiwup
        root@zotac
        sissiwupS Offline
        sissiwupS Offline
        sissiwup
        @thomas-braun sagte in Adapter löschen:
        @sissiwup
        root@zotac
        ich mache das nur über die Konsole, wenn es anders nicht geht.
        Kannst du mir noch einen Tipp geben, wo ich genau schauen soll wegen der zirkulären Links?
        MfG
        Sissi
        Thomas BraunT sissiwupS 2 Antworten Letzte Antwort
          @sissiwup
          root@zotac
          @sissiwup sagte in Adapter löschen:
          Das geht IMMER anders. Der root wird nicht genutzt, wird nicht genutzt, wird nicht genutzt! Gerade unter Debian, Ubuntu und Konsorten nicht.
          Zum Problem: Keine Ahnung. Und auch keine Lust mich mit einer per root shell zerrupften Installation zu beschäftigen.
            @sissiwup
            root@zotac
            sissiwupS Offline
            sissiwupS Offline
            sissiwup
            Hi, wenn du keine Ahnung hast, dann brauchst du nicht antworten.
            Ich habe nur über iobroker selbst installiert.
            Habe den Fehler jetzt aber gefunden:
            Zirkuläre Links kann man finden über
            find . -L >/dev/null
            Wenn hier Fehler kommen, den Link löschen.
            Bei mir war der "redis" da, obwohl ich das nicht verwende.
            Löschen in package.json hat geholfen.
            package.json:    "iobroker.objects-redis": "file:node_modules/iobroker.objects-redis",
            Danach ging es wieder aus dem Admin-Adapter.
            MfG
            Sissi
