  4. [gelöst]hmrega Update schlägt fehl
    6.4k
5 Beiträge 3 Kommentatoren 485 Aufrufe 2 Beobachtet
  • C Offline
    coffee-junk
    schrieb am zuletzt editiert von coffee-junk
    Hallo, mein System versucht die RegaHSS zu aktualisieren, leider wird das Update nicht korrekt durchlaufen, was bedeutet folgende Ausgabe?
    $ iobroker upgrade hm-rega@3.0.33
    Update hm-rega from @3.0.31 to @3.0.33
    NPM version: 6.14.15
    npm install iobroker.hm-rega@3.0.33 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code ETARGET
    npm ERR! notarget No matching version found for iobroker.hm-rega@3.0.33.
    npm ERR! notarget In most cases you or one of your dependencies are requestingnpm ERR! notarget a package version that doesn't exist.
    npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-11-04T17_41_12_213Z-debug.log
    upload [13] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/words.js words.js application/javascript
    Update "system.adapter.hm-rega.0"
    upload [12] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index_m.html index_m.html text/html
    upload [11] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/index.html index.html text/html
    upload [10] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [9] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [8] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [7] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [5] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [4] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [3] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [2] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [1] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [0] hm-rega.admin /opt/iobroker/node_modules/iobroker.hm-rega/admin/homematic.png homematic.png image/png
    Adapter "hm-rega" updated
    Process exited with code 0
    Hier das LOGFILE:
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.hm-rega@3.0.33',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.15
    3 info using node@v12.22.7
    4 verbose npm-session 7847f08e20e915aa
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 200 https://registry.npmjs.org/iobroker.hm-rega 703ms
    8 silly fetchPackageMetaData error for iobroker.hm-rega@3.0.33 No matching version found for iobroker.hm-rega@3.0.33.
    9 timing stage:rollbackFailedOptional Completed in 1ms
    10 timing stage:runTopLevelLifecycles Completed in 4289ms
    11 verbose type version
    12 verbose stack iobroker.hm-rega: No matching version found for iobroker.hm-rega@3.0.33.
    12 verbose stack     at pickManifest (/usr/lib/node_modules/npm/node_modules/npm-pick-manifest/index.js:122:13)
    12 verbose stack     at /usr/lib/node_modules/npm/node_modules/pacote/lib/fetchers/registry/manifest.js:24:14
    12 verbose stack     at tryCatcher (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
    12 verbose stack     at Promise._settlePromiseFromHandler (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:517:31)
    12 verbose stack     at Promise._settlePromise (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:574:18)
    12 verbose stack     at Promise._settlePromise0 (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:619:10)
    12 verbose stack     at Promise._settlePromises (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:699:18)
    12 verbose stack     at _drainQueueStep (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:138:12)
    12 verbose stack     at _drainQueue (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:131:9)
    12 verbose stack     at Async._drainQueues (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:147:5)
    12 verbose stack     at Immediate.Async.drainQueues [as _onImmediate] (/usr/lib/node_modules/npm/node_modules/bluebird/js/release/async.js:17:14)
    12 verbose stack     at processImmediate (internal/timers.js:461:21)
    13 verbose cwd /opt/iobroker
    14 verbose Linux 5.10.63-v7l+
    15 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.hm-rega@3.0.33" "--loglevel" "error" "--prefix" "/opt/iobroker"
    16 verbose node v12.22.7
    17 verbose npm  v6.14.15
    18 error code ETARGET
    19 error notarget No matching version found for iobroker.hm-rega@3.0.33.
    20 error notarget In most cases you or one of your dependencies are requesting
    20 error notarget a package version that doesn't exist.
    21 verbose exit [ 1, true ]
    Jürgen
    • C coffee-junk
      Hier das LOGFILE:
      1 verbose cli [
      1 verbose cli ]
      @coffee-junk sagte in hmrega Update schlägt fehl:
      Das bedeutet, dass es noch keine 3.0.33 gibt
      C 1 Antwort Letzte Antwort
        coffee-junk
        OK, ioBroker zeigt mir aber an, dass ein Update anliegt.....
        Heisst das jetzt, dass sich der Knoten demnächst selbst löst..... und das eine zeitliche Überschneidung ist....
        Danke!
        Jürgen
        • C coffee-junk
          Danke!
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          Knoten
          https://forum.iobroker.net/topic/49063/homematic-regahss-3-0-33-lässt-sich-nicht-updaten
          • GlasfaserG Glasfaser
            Knoten
            coffee-junk
            @glasfaser 👍 Danke! Hab zwar zuvor im Forum gesucht.... aber wohl falsche Suchbegriffe.......
            PS: Ich kämpfe gerade mit diversen undurchsichtigen Fehlern und bin etwas platt nachdem ich heute Nacht bis halb zwei irgendwelchen Fehlern nachgerannt bin..... das jetzt zufällig noch dieser dazu kommt.....Murphy lässt grüssen....
            Dachte das hängt alles zusammen.... aber Denken ist so eine Sache 😧
            Jürgen
