  4. Zigbee Adapter Installation - Unexpected end of JSON
    6.3k
15 Beiträge 2 Kommentatoren 572 Aufrufe 2 Beobachtet
  • W Offline
    W Offline
    WolfgangFB
    Ich wollte gerade auf einem komplett neu aufgesetzten System den Zigbee Adapter installieren und bekomme:
    $ iobroker add zigbee auto --host raspberrypi202
    NPM version: 6.14.15
    npm install iobroker.zigbee@1.5.6 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! Unexpected end of JSON input while parsing near '...man-0.13.19.tgz","fil'
    npm ERR! /home/iobroker/.npm/_logs/2021-10-23T14_18_15_037Z-debug.log
    host.raspberrypi202 Cannot install iobroker.zigbee@1.5.6: 1
    ERROR: Process exited with code 25
    in der Logdatei steht
    pi@raspberrypi202:/home/iobroker/.npm/_logs $ more 2021-10-23T14_18_15_037Z-debug.log
    0 info it worked if it ends with ok
    1 verbose cli [
    1 verbose cli   '/usr/bin/node',
    1 verbose cli   '/usr/bin/npm',
    1 verbose cli   'install',
    1 verbose cli   'iobroker.zigbee@1.5.6',
    1 verbose cli   '--loglevel',
    1 verbose cli   'error',
    1 verbose cli   '--prefix',
    1 verbose cli   '/opt/iobroker'
    1 verbose cli ]
    2 info using npm@6.14.15
    3 info using node@v12.22.6
    4 verbose npm-session 96b4af11a055cd35
    5 silly install loadCurrentTree
    6 silly install readLocalPackageData
    7 http fetch GET 304 https://registry.npmjs.org/iobroker.zigbee 673ms (from cache)
    8 silly pacote version manifest for iobroker.zigbee@1.5.6 fetched in 745ms
    9 timing stage:loadCurrentTree Completed in 13910ms
    10 silly install loadIdealTree
    11 silly install cloneCurrentTreeToIdealTree
    12 timing stage:loadIdealTree:cloneCurrentTree Completed in 134ms
    13 silly install loadShrinkwrap
    14 timing stage:loadIdealTree:loadShrinkwrap Completed in 7750ms
    15 silly install loadAllDepsIntoIdealTree
    16 silly resolveWithNewModule iobroker.zigbee@1.5.6 checking installable status
    17 http fetch GET 304 https://registry.npmjs.org/zigbee-herdsman 382ms (from cache)
    18 silly fetchPackageMetaData error for zigbee-herdsman@0.13.110 Unexpected end of JSON input while parsing near '...ma
    19 http fetch GET 304 https://registry.npmjs.org/zigbee-herdsman-converters 497ms (from cache)
    20 silly pacote version manifest for zigbee-herdsman-converters@14.0.162 fetched in 681ms
    21 silly resolveWithNewModule zigbee-herdsman-converters@14.0.162 checking installable status
    22 timing stage:rollbackFailedOptional Completed in 3ms
    23 timing stage:runTopLevelLifecycles Completed in 25668ms
    24 silly saveTree iobroker.inst@3.0.0
    24 silly saveTree ├─┬ iobroker.admin@5.1.25
    25 verbose stack SyntaxError: Unexpected end of JSON input while parsing near '...man-0.13.19.tgz","fil'
    25 verbose stack     at JSON.parse (<anonymous>)
    25 verbose stack     at parseJson (/usr/lib/node_modules/npm/node_modules/json-parse-better-errors/index.js:7:17)
    25 verbose stack     at /usr/lib/node_modules/npm/node_modules/node-fetch-npm/src/body.js:96:50
    25 verbose stack     at processTicksAndRejections (internal/process/task_queues.js:97:5)
    26 verbose cwd /opt/iobroker
    27 verbose Linux 5.10.63-v7+
    28 verbose argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.zigbee@1.5.6" "--loglevel" "error" "--prefix" "/opt/
    iobroker"
    29 verbose node v12.22.6
    30 verbose npm  v6.14.15
    31 error Unexpected end of JSON input while parsing near '...man-0.13.19.tgz","fil'
    32 verbose exit [ 1, true ]
    • W WolfgangFB
      1 verbose cli [
      1 verbose cli ]
      iobroker"
      @wolfgangfb
      cd /opt/iobroker
      npm cache clear --force
      Danach nochmal probieren.
      nodejs aktuell halten.
      W 1 Antwort Letzte Antwort
        @wolfgangfb
        cd /opt/iobroker
        W Offline
        W Offline
        WolfgangFB
        Jetzt kommt:
        npm ERR! code EINTEGRITY
        npm ERR! sha512-QzC+VeoqagXQjP1akJVh1OBvOnpnnVbLf467hDcFMFDQSDQTfTfcI7TRlO+DJ3tqj0c8695tk8meX4wbIv51Fw== integrity checksum failed when using sha512: wanted sha512-QzC+VeoqagXQjP1akJVh1OBvOnpnnVbLf467hDcFMFDQSDQTfTfcI7TRlO+DJ3tqj0c8695tk8meX4wbIv51Fw== but got sha512-1pJBJij7uq/un3TKQG7AFAxwu1IsNX0J7hCVlf1M9lLPJTiCc9Dz60U2uaPGJGUP1OoOW6oyJrw/caWBPK4+JA==. (8305006 bytes)
        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-10-23T18_18_46_763Z-debug.log
        • W WolfgangFB
          Jetzt kommt:
          @wolfgangfb
          Dann nochmal.
          Da ist beim Download wohl ein bit umgekippt.
            @wolfgangfb
            Dann nochmal.
            W Offline
            W Offline
            WolfgangFB
            Ich habe nochmal
            pi@raspberrypi202:/opt/iobroker $ npm cache clear --force
            npm WARN using --force I sure hope you know what you are doing.
            und dann versucht zu installieren, gleiches Ergebnis:
            npm ERR! sha512-QzC+VeoqagXQjP1akJVh1OBvOnpnnVbLf467hDcFMFDQSDQTfTfcI7TRlO+DJ3tqj0c8695tk8meX4wbIv51Fw== integrity checksum failed when using sha512: wanted sha512-QzC+VeoqagXQjP1akJVh1OBvOnpnnVbLf467hDcFMFDQSDQTfTfcI7TRlO+DJ3tqj0c8695tk8meX4wbIv51Fw== but got sha512-jWCut7+lvh3NFCdTaC9jhM5aRyWnyy7hU18yMB8cLd2giThd8TdciGv20Q+UeHvcQmcCyICjiA6+hVvzYOg55w==. (2009453 bytes)
            npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2021-10-23T18_33_17_451Z-debug.log
            • W WolfgangFB
              Ich habe nochmal
              @wolfgangfb
              Dann ist vielleicht die Version auf dem Server korrupt.
              Stell mal zum Testen auf das Beta-Repository um und installier die Version von dort. Dann wieder auf stable zurück.
              • W Offline
                W Offline
                WolfgangFB
                Wenn ich von Default auf Latest umstelle, und bei "Adapter" aktualisiere, dann kommt:
                Langsame Verbindung erkannt!
                Cannot GetRepositoryCompact:
                Thomas BraunT W 2 Antworten Letzte Antwort
                • W WolfgangFB
                  @wolfgangfb
                  Irgendwie scheint da bei dir im Netz was zu klemmen.
                  • W WolfgangFB
                    W Offline
                    W Offline
                    WolfgangFB
                    @wolfgangfb
                    Da ist tatsächlich etwas faul, ich weiß nur noch nicht was. Über Wlan ist die Verbindung top, über LAN zäh. Die WLAN Zugänge hängen aber alle am gleichen Gigabit Router, genau wie der Raspberry, per LAN Kabel.
                    • W WolfgangFB
                      @wolfgangfb
                      @wolfgangfb
                      Die Kiste mal neugestartet?
                        @wolfgangfb
                        W Offline
                        W Offline
                        WolfgangFB
                        Klar, ca.20 mal die letzten paar Stunden :-(
                        • W WolfgangFB
                          @wolfgangfb Ich meinte den Router.
                            W Offline
                            W Offline
                            WolfgangFB
                            Den Router habe ich auch neu gestartet.
                            Ich habe folgende Konstellation: Internet kommt über Kabel (Vodafone Router, so gut wie nichts konfigurierbar), das Vodafone Modem hat die IP 192.168.0.1. Der erste LAN Ausgang geht in eine Fritz!Box die DHCP, VoIP, NAS etc. macht, die hat 192.168.1.200 und von dort geht es in einen Gigabit Switch an dem z.B. dieser PC und die Raspberrys per Lan Kabel hängen (und die gerade eine grausame Internetgeschwindigkeit haben) und ein Fritz!Repeater über den per WLAN der volle Durchsatz (40MBit/sek) möglich sind. Verstehen tue ich das ganze im Moment nicht.
                            • W WolfgangFB
                              @wolfgangfb
                              Da hast du in dem Konstrukt wohl einen Knoten drin.
                              DHCP-Server sollte es z.B nur einen geben.
                                @wolfgangfb
                                W Offline
                                W Offline
                                WolfgangFB
                                Das sehe ich auch so, dass da ein Knoten ist (ich vermute mal, dass es irgendwas mit dem Nameserver zu tun hat, denn das ganze ist entstanden, weil ein Pi-Hole auf einem der Raspberrys nicht mehr wollte und ich den Nameserver wieder auf den 8.8.8.8 gestellt habe), aber warum geht es per Wlan und per Kabel nicht? Ich gehe jetzt erst mal in Bett und schaue mir das ganze morgen nochmal in Ruhe an.
