  4. IOBroker lässt sich nicht starten (Logs im Post)
    2.0k
3 Beiträge 2 Kommentatoren 280 Aufrufe 2 Beobachtet
    AG21368
    Hallo, nachdem es gestern Nacht zu einem Stromausfall kam läuft alles soweit nur IOBroker lässt sich nicht starten. Hier die Logs dazu.
    node node_modules/iobroker.js-controller/controller.js --logs
    2021-10-11 10:00:10.300  - info: host.rpi-wohnwagen iobroker.js-controller version 3.3.15 js-controller starting
    2021-10-11 10:00:10.308  - info: host.rpi-wohnwagen Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
    2021-10-11 10:00:10.309  - info: host.rpi-wohnwagen hostname: rpi-wohnwagen, node: v12.20.1
    2021-10-11 10:00:10.310  - info: host.rpi-wohnwagen ip addresses: 192.168.1.210 fe80::4203:ce9e:9263:e966
    2021-10-11 10:00:10.415  - error: host.rpi-wohnwagen Cannot read system.config: null (OK when migrating or restoring)
    2021-10-11 10:00:10.523  - info: host.rpi-wohnwagen connected to Objects and States
    2021-10-11 10:00:10.558  - info: host.rpi-wohnwagen added notifications configuration of host
    2021-10-11 10:00:10.599  - error: host.rpi-wohnwagen Cannot find view "system" for search "instance"
    2021-10-11 10:00:10.601  - error: host.rpi-wohnwagen Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2021-10-11 10:00:10.671  - info: host.rpi-wohnwagen Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2021-10-11 10:00:10.679  - error: host.rpi-wohnwagen Cannot find view "system" for search "host"
    2021-10-11 10:00:10.689  - error: host.rpi-wohnwagen Cannot find view "system" for search "state"
    2021-10-11 10:00:10.690  - error: host.rpi-wohnwagen Cannot find view "system" for search "instance"
    2021-10-11 10:00:10.694  - error: host.rpi-wohnwagen Could not collect system.host.rpi-wohnwagen states to check for obsolete states: Error: Cannot find view "system"
    2021-10-11 10:00:10.695  - error: host.rpi-wohnwagen _design/system missing - call node iobroker.js setup
    2021-10-11 10:00:10.696  - info: host.rpi-wohnwagen no instances found
    doc.rows is not iterable
    TypeError: doc.rows is not iterable
        at Object.getInstancesOrderedByStartPrio (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:2787:27)
    2021-10-11 10:00:10.700  - error: host.rpi-wohnwagen uncaught exception: doc.rows is not iterable
    2021-10-11 10:00:10.701  - error: host.rpi-wohnwagen TypeError: doc.rows is not iterable
    2021-10-11 10:00:10.711  - info: host.rpi-wohnwagen iobroker _restart
    2021-10-11 10:00:10.736  - error: host.rpi-wohnwagen Cannot write host object:Error: DB closed
    object system.meta.uuid cannot be updated: Error: DB closed
    2021-10-11 10:00:10.776  - info: host.rpi-wohnwagen terminated
    object system.user.admin created
    2021-10-11 10:00:10.895  - info: host.rpi-wohnwagen Created UUID: a6f763a4-1aec-410a-c862-b4e9fac86263
    2021-10-11 10:00:11.404  - info: host.rpi-wohnwagen iobroker Starting node restart.js
    Das erste was mir auffällt ist die Meldung das er die system.config nicht lesen kann. Evtl. habt ihr einen Lösungsansatz für mich. im Ordner Backups liegen auch Backups. Kann ich die einfach so einspielen?
    Vielen Dank
    Andreas
    A Thomas BraunT 2 Antworten Letzte Antwort
    • A AG21368
      Vielen Dank
      Andreas
      AG21368
      Wenn ich netstat -n -a -p TCP steht bei den Ports 9000 und 9001 Time_Wait kann dass das Problem sein?
      • A AG21368
        Vielen Dank
        Andreas
        @ag21368
        Hört sich etwas danach an:
        https://forum.iobroker.net/topic/43325/mini-howto-cannot-find-view-system-for-search-host?_=1633939899097
        83.1k
