  3. Off Topic
  4. FullpageOS mit ioBroker
4 Beiträge 2 Kommentatoren 929 Aufrufe 2 Beobachtet
  • H Offline
    Hcker
    Hallo zusammen, ich habe ein 15 Zoll Waveshare Touch Display an einem Raspberry Pi 4 (4 GB) hängen. Ich würde auf FullpageOS gerne ioBroker installieren und später die VIS auf dem Touch anzeigen lassen. Hat das jemand erfolgreich in Betrieb? Ich bekomme folgende Fehlermeldungen:
    pi@fullpageos:~ $ curl -sLf https://deb.nodesource.com/setup_12.x | sudo -E bash -
    Installing the NodeSource Node.js 12.x repo...
    Populating apt-get cache...
    • apt-get update
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
      Reading package lists... Done
      E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
      N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
      Error executing command, exiting
      pi@fullpageos:~ $ sudo apt-get install -y nodejs
      Building dependency tree
      The following additional packages will be installed:
      libbrotli1 libc-ares2 libnode64 libuv1 nodejs-doc
      Suggested packages:
      npm
      The following NEW packages will be installed:
      libbrotli1 libc-ares2 libnode64 libuv1 nodejs nodejs-doc
      0 upgraded, 6 newly installed, 0 to remove and 63 not upgraded.
      Need to get 6,356 kB of archives.
      After this operation, 28.4 MB of additional disk space will be used.
      Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf libc-ares2 armhf 1.14.0-1
      404 Not Found [IP: 93.93.128.193 80]
      Get:1 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libbrotli1 armhf 1.0.7-2+deb10u1 [257 kB]
      Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf libuv1 armhf 1.24.1-1
      Get:4 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libnode64 armhf 10.24.0~dfsg-1~deb10u1 [4,860 kB]
      Get:5 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf nodejs armhf 10.24.0~dfsg-1~deb10u1 [87.2 kB]
      Get:6 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf nodejs-doc all 10.24.0~dfsg-1~deb10u1 [974 kB]
      Fetched 6,179 kB in 1s (4,707 kB/s)
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/c/c-ares/libc-ares2_1.14.0-1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/libu/libuv1/libuv1_1.24.1-1_armhf.deb 404 Not Found [IP: 93.93.128.193 80]
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      pi@fullpageos:~ $ curl -sLf https://iobroker.net/install.sh | bash -
      library: loaded
      Library version=2021-08-05
    Welcome to the ioBroker installer!
    Installer version: 2021-06-18
    You might need to enter your password a couple of times.
    Installing prerequisites (1/4)
    Node.js not found. Installing...
    • apt-get update
      Installed nodejs
      Cannot install Node.js! Please install it manually.
      library: loaded
    • apt-get update
      Installed nodejs
    VIelen Dank vorab!
    • H Hcker
      • apt-get update
        Suggested packages:
        npm
        library: loaded
      • apt-get update
        Installed nodejs
        library: loaded
      • apt-get update
        Installed nodejs
      VIelen Dank vorab!
      @hcker
      Du installierst die falsche nodejs-Version.
      sudo apt update
      sudo apt upgrade
      Änderungen bestätigen.
      H 1 Antwort Letzte Antwort
        @hcker
        sudo apt update
        sudo apt upgrade
        Hcker
        @thomas-braun Danke das hat funktioniert!
        • H Hcker
          @hcker
          which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          liefert?
