  4. [gelöst] Fehler bei Installationen
    6.4k
installation schlägt fehl
5 Beiträge 3 Kommentatoren 422 Aufrufe 3 Beobachtet
  • PlasmachefP Offline
    PlasmachefP Offline
    Plasmachef
    schrieb am zuletzt editiert von Plasmachef
    Hallo Zusammen,
    seit kurzen bekommen ich bei der Installation eines Adapters folgende Mitteilungen
    $ iobroker add whatsapp-cmb auto --host raspberrypi
    NPM version: 6.14.11
    npm install iobroker.whatsapp-cmb@0.1.6 --loglevel error --prefix "/opt/iobroker" (System call)
    npm ERR! code EACCES
    npm ERR! syscall unlinknpm ERR! path /opt/iobroker/node_modules/.canvas.DELETE/build/Makefilenpm ERR! errno -13
    npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'
    npm ERR! [OperationalError: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'] {npm ERR! cause: [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'] {npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile'npm ERR! },npm ERR! errno: -13,npm ERR! code: 'EACCES',npm ERR! syscall: 'unlink',npm ERR! path: '/opt/iobroker/node_modules/.canvas.DELETE/build/Makefile',npm ERR! parent: 'iobroker'npm ERR! }npm ERR! npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current usernpm ERR! npm ERR! If you believe this might be a permissions issue, please double-check thenpm ERR! permissions of the file and its containing directories, or try runningnpm ERR! the command again as root/Administrator.
    npm ERR! /home/iobroker/.npm/_logs/2021-10-03T17_27_16_512Z-debug.log
    host.raspberrypi Cannot install iobroker.whatsapp-cmb@0.1.6: 243
    ERROR: Process exited with code 25
    auch dieser Befehl an der Console läuft auf das selbe Ergebnis
    sudo iobroker add whatsapp-cmb auto --host raspberrypi
    Kann mir bitte wer helfen?
    • PlasmachefP Plasmachef
      Hallo Zusammen,
      @plasmachef sagte in Fehler bei Installationen:
      sudo iobroker
      Das ist dein Fehler.
      An der Stelle wird NIE mit sudo (root-Rechten) hantiert...
      iobroker stop
      iobroker fix
      iobroker start
      mal probieren. Wenn nicht noch mehr krumm ist könnte das vielleicht schon reichen.
      Ansonsten das tun was im Log steht. Den Ordner löschen.
        sudo iobroker
        iobroker stop
        iobroker fix
        iobroker start
        GlasfaserG Offline
        GlasfaserG Offline
        Glasfaser
        Das Verzeichniss gibt es gar nicht bei ioBroker mit einem Punkt vorraus
        .canvans
        • GlasfaserG Glasfaser
          .canvans
          @glasfaser @Plasmachef
          Mal irgendwann unter Windows da rumgegurkt?
          Schaut für mich aus wie ein versteckter Ordner.
          PlasmachefP 1 Antwort Letzte Antwort
            PlasmachefP Offline
            PlasmachefP Offline
            Plasmachef
            Danke für die Tipps!
            Sie haben mich auf die richte Spur geführt.
            Es lag an einer defekten Installation von Canvas.
            Uninstall und Install haben das Problem gelöst :-)
