  4. Pi Überlastet ** geschlossen mit neuinstall **
    5.6k
43 Beiträge 5 Kommentatoren 2.3k Aufrufe 3 Beobachtet
    @horst-böttcher Könntest du bitte vollständige Ein- und Ausgaben posten?
    Was steht so in
    dmesg -T
    drin?
    Horst BöttcherH Offline
    Horst Böttcher
    #41
    @thomas-braun sagte in Pi Überlastet:
    pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v12.22.6
    v12.22.6
    6.14.15
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
    Hit:4 https://phoscon.de/apt/deconz buster InRelease
    Reading package lists... Done
    Building dependency tree
    All packages are up to date.
    nodejs:
      Installed: 12.22.6-deb-1nodesource1
      Candidate: 12.22.6-deb-1nodesource1
      Version table:
     *** 12.22.6-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
            100 /var/lib/dpkg/status
         10.24.0~dfsg-1~deb10u1 500
    pi@raspberrypi:~ $ iobroker stop
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ npm install iobroker.js-controller
    > iobroker.js-controller@3.3.18 preinstall /opt/iobroker/node_modules/iobroker.js-controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.15
    > iobroker.js-controller@3.3.18 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    object _design/custom updated
    object _design/system updated
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.2 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN typedoc@0.20.28 requires a peer of typescript@3.9.x || 4.0.x || 4.1.x but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/zigbee-herdsman/node_modules/fsevents):
    + iobroker.js-controller@3.3.18
    updated 1 package in 91.027s
    140 packages are looking for funding
      run `npm fund` for details
    pi@raspberrypi:/opt/iobroker $ iobroker start
    dmesg -T
    pi@raspberrypi:/opt/iobroker $ dmesg -T
    [Sat Sep 18 17:25:25 2021] Booting Linux on physical CPU 0x0
    [Sat Sep 18 17:25:25 2021] Linux version 5.10.60-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1449 SMP Wed Aug 25 15:00:44 BST 2021
    [Sat Sep 18 17:25:25 2021] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
    [Sat Sep 18 17:25:25 2021] CPU: div instructions available: patching division code
    [Sat Sep 18 17:25:25 2021] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [Sat Sep 18 17:25:25 2021] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
    [Sat Sep 18 17:25:25 2021] random: fast init done
    [Sat Sep 18 17:25:25 2021] Memory policy: Data cache writealloc
    [Sat Sep 18 17:25:25 2021] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
    [Sat Sep 18 17:25:25 2021] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [Sat Sep 18 17:25:25 2021] Zone ranges:
    [Sat Sep 18 17:25:25 2021]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
    [Sat Sep 18 17:25:25 2021]   Normal   empty
    [Sat Sep 18 17:25:25 2021]   HighMem  [mem 0x0000000030000000-0x00000000fbffffff]
    [Sat Sep 18 17:25:25 2021] Movable zone start for each node
    [Sat Sep 18 17:25:25 2021] Early memory node ranges
    [Sat Sep 18 17:25:25 2021]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
    [Sat Sep 18 17:25:25 2021]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
    [Sat Sep 18 17:25:25 2021] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
    [Sat Sep 18 17:25:25 2021] On node 0 totalpages: 1012736
    [Sat Sep 18 17:25:25 2021]   DMA zone: 1728 pages used for memmap
    [Sat Sep 18 17:25:25 2021]   DMA zone: 0 pages reserved
    [Sat Sep 18 17:25:25 2021]   DMA zone: 196608 pages, LIFO batch:63
    [Sat Sep 18 17:25:25 2021]   HighMem zone: 816128 pages, LIFO batch:63
    [Sat Sep 18 17:25:25 2021] percpu: Embedded 20 pages/cpu s50764 r8192 d22964 u81920
    [Sat Sep 18 17:25:25 2021] pcpu-alloc: s50764 r8192 d22964 u81920 alloc=20*4096
    [Sat Sep 18 17:25:25 2021] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [Sat Sep 18 17:25:25 2021] Built 1 zonelists, mobility grouping on.  Total pages: 1011008
    [Sat Sep 18 17:25:25 2021] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:3F:39:D5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=34811267-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Sep 18 17:25:25 2021] Kernel parameter elevator= does not have any effect anymore.
                               Please use sysfs to set IO scheduler for individual devices.
    [Sat Sep 18 17:25:25 2021] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
    [Sat Sep 18 17:25:25 2021] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [Sat Sep 18 17:25:25 2021] mem auto-init: stack:off, heap alloc:off, heap free:off
    [Sat Sep 18 17:25:25 2021] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
    [Sat Sep 18 17:25:25 2021] Memory: 3601132K/4050944K available (10240K kernel code, 1364K rwdata, 3188K rodata, 2048K init, 891K bss, 122132K reserved, 327680K cma-reserved, 3264512K highmem)
    [Sat Sep 18 17:25:25 2021] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [Sat Sep 18 17:25:25 2021] ftrace: allocating 34309 entries in 68 pages
    [Sat Sep 18 17:25:25 2021] ftrace: allocated 68 pages with 2 groups
    [Sat Sep 18 17:25:25 2021] rcu: Hierarchical RCU implementation.
    [Sat Sep 18 17:25:25 2021]      Rude variant of Tasks RCU enabled.
    [Sat Sep 18 17:25:25 2021]      Tracing variant of Tasks RCU enabled.
    [Sat Sep 18 17:25:25 2021] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [Sat Sep 18 17:25:25 2021] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [Sat Sep 18 17:25:25 2021] GIC: Using split EOI/Deactivate mode
    [Sat Sep 18 17:25:25 2021] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
    [Sat Sep 18 17:25:25 2021] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
    [Sat Sep 18 17:25:25 2021] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
    [Sat Sep 18 17:25:25 2021] bcm2835: system timer (irq = 25)
    [Sat Sep 18 17:25:25 2021] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
    [Sat Sep 18 17:25:25 2021] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
    [Sat Sep 18 17:25:25 2021] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
    [Sat Sep 18 17:25:25 2021] Switching to timer-based delay loop, resolution 18ns
    [Sat Sep 18 17:25:25 2021] Console: colour dummy device 80x30
    [Sat Sep 18 17:25:25 2021] printk: console [tty1] enabled
    [Sat Sep 18 17:25:25 2021] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
    [Sat Sep 18 17:25:25 2021] pid_max: default: 32768 minimum: 301
    [Sat Sep 18 17:25:25 2021] LSM: Security Framework initializing
    [Sat Sep 18 17:25:25 2021] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Sat Sep 18 17:25:25 2021] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [Sat Sep 18 17:25:25 2021] cgroup: Disabling memory control group subsystem
    [Sat Sep 18 17:25:25 2021] CPU: Testing write buffer coherency: ok
    [Sat Sep 18 17:25:25 2021] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [Sat Sep 18 17:25:25 2021] Setting up static identity map for 0x200000 - 0x20003c
    [Sat Sep 18 17:25:25 2021] rcu: Hierarchical SRCU implementation.
    [Sat Sep 18 17:25:25 2021] smp: Bringing up secondary CPUs ...
    [Sat Sep 18 17:25:25 2021] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [Sat Sep 18 17:25:25 2021] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [Sat Sep 18 17:25:25 2021] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [Sat Sep 18 17:25:25 2021] smp: Brought up 1 node, 4 CPUs
    [Sat Sep 18 17:25:25 2021] SMP: Total of 4 processors activated (432.00 BogoMIPS).
    [Sat Sep 18 17:25:25 2021] CPU: All CPU(s) started in HYP mode.
    [Sat Sep 18 17:25:25 2021] CPU: Virtualization extensions available.
    [Sat Sep 18 17:25:25 2021] devtmpfs: initialized
    [Sat Sep 18 17:25:25 2021] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
    [Sat Sep 18 17:25:25 2021] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [Sat Sep 18 17:25:25 2021] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [Sat Sep 18 17:25:25 2021] pinctrl core: initialized pinctrl subsystem
    [Sat Sep 18 17:25:25 2021] NET: Registered protocol family 16
    [Sat Sep 18 17:25:25 2021] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [Sat Sep 18 17:25:25 2021] audit: initializing netlink subsys (disabled)
    [Sat Sep 18 17:25:25 2021] audit: type=2000 audit(0.030:1): state=initialized audit_enabled=0 res=1
    [Sat Sep 18 17:25:25 2021] thermal_sys: Registered thermal governor 'step_wise'
    [Sat Sep 18 17:25:25 2021] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [Sat Sep 18 17:25:25 2021] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [Sat Sep 18 17:25:25 2021] Serial: AMBA PL011 UART driver
    [Sat Sep 18 17:25:25 2021] bcm2835-mbox fe00b880.mailbox: mailbox enabled
    [Sat Sep 18 17:25:25 2021] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-08-31T14:52:47, variant start
    [Sat Sep 18 17:25:25 2021] raspberrypi-firmware soc:firmware: Firmware hash is 67615e950e1e28b92dfae6303cf7a8b879a8908f
    [Sat Sep 18 17:25:25 2021] Kprobes globally optimized
    [Sat Sep 18 17:25:25 2021] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
    [Sat Sep 18 17:25:25 2021] vgaarb: loaded
    [Sat Sep 18 17:25:25 2021] SCSI subsystem initialized
    [Sat Sep 18 17:25:25 2021] usbcore: registered new interface driver usbfs
    [Sat Sep 18 17:25:25 2021] usbcore: registered new interface driver hub
    [Sat Sep 18 17:25:25 2021] usbcore: registered new device driver usb
    [Sat Sep 18 17:25:25 2021] usb_phy_generic phy: supply vcc not found, using dummy regulator
    [Sat Sep 18 17:25:25 2021] clocksource: Switched to clocksource arch_sys_counter
    [Sat Sep 18 17:25:26 2021] VFS: Disk quotas dquot_6.6.0
    [Sat Sep 18 17:25:26 2021] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [Sat Sep 18 17:25:26 2021] FS-Cache: Loaded
    [Sat Sep 18 17:25:26 2021] CacheFiles: Loaded
    [Sat Sep 18 17:25:26 2021] NET: Registered protocol family 2
    [Sat Sep 18 17:25:26 2021] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [Sat Sep 18 17:25:26 2021] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
    [Sat Sep 18 17:25:26 2021] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [Sat Sep 18 17:25:26 2021] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [Sat Sep 18 17:25:26 2021] TCP: Hash tables configured (established 8192 bind 8192)
    [Sat Sep 18 17:25:26 2021] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Sat Sep 18 17:25:26 2021] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
    [Sat Sep 18 17:25:26 2021] NET: Registered protocol family 1
    [Sat Sep 18 17:25:26 2021] RPC: Registered named UNIX socket transport module.
    [Sat Sep 18 17:25:26 2021] RPC: Registered udp transport module.
    [Sat Sep 18 17:25:26 2021] RPC: Registered tcp transport module.
    [Sat Sep 18 17:25:26 2021] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [Sat Sep 18 17:25:26 2021] PCI: CLS 0 bytes, default 64
    [Sat Sep 18 17:25:26 2021] Initialise system trusted keyrings
    [Sat Sep 18 17:25:26 2021] workingset: timestamp_bits=14 max_order=20 bucket_order=6
    [Sat Sep 18 17:25:26 2021] zbud: loaded
    [Sat Sep 18 17:25:26 2021] FS-Cache: Netfs 'nfs' registered for caching
    [Sat Sep 18 17:25:26 2021] NFS: Registering the id_resolver key type
    [Sat Sep 18 17:25:26 2021] Key type id_resolver registered
    [Sat Sep 18 17:25:26 2021] Key type id_legacy registered
    [Sat Sep 18 17:25:26 2021] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [Sat Sep 18 17:25:26 2021] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [Sat Sep 18 17:25:26 2021] Key type asymmetric registered
    [Sat Sep 18 17:25:26 2021] Asymmetric key parser 'x509' registered
    [Sat Sep 18 17:25:26 2021] bounce: pool size: 64 pages
    [Sat Sep 18 17:25:26 2021] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [Sat Sep 18 17:25:26 2021] io scheduler mq-deadline registered
    [Sat Sep 18 17:25:26 2021] io scheduler kyber registered
    [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
    [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
    [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
    [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
    [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
    [Sat Sep 18 17:25:26 2021] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
    [Sat Sep 18 17:25:26 2021] pci_bus 0000:00: root bus resource [bus 00-ff]
    [Sat Sep 18 17:25:26 2021] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
    [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
    [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: PME# supported from D0 D3hot
    [Sat Sep 18 17:25:26 2021] PCI: bus0: Fast back to back transfers disabled
    [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
    [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
    [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: PME# supported from D0 D3cold
    [Sat Sep 18 17:25:26 2021] PCI: bus1: Fast back to back transfers disabled
    [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
    [Sat Sep 18 17:25:26 2021] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
    [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0: PCI bridge to [bus 01]
    [Sat Sep 18 17:25:26 2021] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
    [Sat Sep 18 17:25:26 2021] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
    [Sat Sep 18 17:25:26 2021] pcieport 0000:00:00.0: PME: Signaling with IRQ 62
    [Sat Sep 18 17:25:26 2021] iproc-rng200 fe104000.rng: hwrng registered
    [Sat Sep 18 17:25:26 2021] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
    [Sat Sep 18 17:25:26 2021] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
    [Sat Sep 18 17:25:26 2021] brd: module loaded
    [Sat Sep 18 17:25:26 2021] loop: module loaded
    [Sat Sep 18 17:25:26 2021] Loading iSCSI transport class v2.0-870.
    [Sat Sep 18 17:25:26 2021] libphy: Fixed MDIO Bus: probed
    [Sat Sep 18 17:25:26 2021] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
    [Sat Sep 18 17:25:26 2021] libphy: bcmgenet MII bus: probed
    [Sat Sep 18 17:25:26 2021] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
    [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver r8152
    [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver lan78xx
    [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver smsc95xx
    [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
    [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: xHCI Host Controller
    [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
    [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
    [Sat Sep 18 17:25:26 2021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [Sat Sep 18 17:25:26 2021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Sat Sep 18 17:25:26 2021] usb usb1: Product: xHCI Host Controller
    [Sat Sep 18 17:25:26 2021] usb usb1: Manufacturer: Linux 5.10.60-v7l+ xhci-hcd
    [Sat Sep 18 17:25:26 2021] usb usb1: SerialNumber: 0000:01:00.0
    [Sat Sep 18 17:25:26 2021] hub 1-0:1.0: USB hub found
    [Sat Sep 18 17:25:26 2021] hub 1-0:1.0: 1 port detected
    [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
    [Sat Sep 18 17:25:26 2021] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
    [Sat Sep 18 17:25:26 2021] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
    [Sat Sep 18 17:25:26 2021] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [Sat Sep 18 17:25:26 2021] usb usb2: Product: xHCI Host Controller
    [Sat Sep 18 17:25:26 2021] usb usb2: Manufacturer: Linux 5.10.60-v7l+ xhci-hcd
    [Sat Sep 18 17:25:26 2021] usb usb2: SerialNumber: 0000:01:00.0
    [Sat Sep 18 17:25:26 2021] hub 2-0:1.0: USB hub found
    [Sat Sep 18 17:25:26 2021] hub 2-0:1.0: 4 ports detected
    [Sat Sep 18 17:25:26 2021] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [Sat Sep 18 17:25:26 2021] dwc_otg: FIQ enabled
    [Sat Sep 18 17:25:26 2021] dwc_otg: NAK holdoff enabled
    [Sat Sep 18 17:25:26 2021] dwc_otg: FIQ split-transaction FSM enabled
    [Sat Sep 18 17:25:26 2021] Module dwc_common_port init
    [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver uas
    [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver usb-storage
    [Sat Sep 18 17:25:26 2021] mousedev: PS/2 mouse device common for all mice
    [Sat Sep 18 17:25:26 2021] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
    [Sat Sep 18 17:25:26 2021] sdhci: Secure Digital Host Controller Interface driver
    [Sat Sep 18 17:25:26 2021] sdhci: Copyright(c) Pierre Ossman
    [Sat Sep 18 17:25:26 2021] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
    [Sat Sep 18 17:25:26 2021] sdhci-pltfm: SDHCI platform and OF driver helper
    [Sat Sep 18 17:25:26 2021] ledtrig-cpu: registered to indicate activity on CPUs
    [Sat Sep 18 17:25:26 2021] hid: raw HID events driver (C) Jiri Kosina
    [Sat Sep 18 17:25:26 2021] usbcore: registered new interface driver usbhid
    [Sat Sep 18 17:25:26 2021] usbhid: USB HID core driver
    [Sat Sep 18 17:25:26 2021] Initializing XFRM netlink socket
    [Sat Sep 18 17:25:26 2021] NET: Registered protocol family 17
    [Sat Sep 18 17:25:26 2021] Key type dns_resolver registered
    [Sat Sep 18 17:25:26 2021] Registering SWP/SWPB emulation handler
    [Sat Sep 18 17:25:26 2021] registered taskstats version 1
    [Sat Sep 18 17:25:26 2021] Loading compiled-in X.509 certificates
    [Sat Sep 18 17:25:26 2021] Key type ._fscrypt registered
    [Sat Sep 18 17:25:26 2021] Key type .fscrypt registered
    [Sat Sep 18 17:25:26 2021] Key type fscrypt-provisioning registered
    [Sat Sep 18 17:25:26 2021] uart-pl011 fe201000.serial: there is not valid maps for state default
    [Sat Sep 18 17:25:26 2021] uart-pl011 fe201000.serial: cts_event_workaround enabled
    [Sat Sep 18 17:25:26 2021] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
    [Sat Sep 18 17:25:26 2021] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
    [Sat Sep 18 17:25:26 2021] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
    [Sat Sep 18 17:25:26 2021] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
    [Sat Sep 18 17:25:26 2021] of_cfs_init
    [Sat Sep 18 17:25:26 2021] of_cfs_init: OK
    [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [Sat Sep 18 17:25:26 2021] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [Sat Sep 18 17:25:26 2021] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
    [Sat Sep 18 17:25:26 2021] Waiting for root device PARTUUID=34811267-02...
    [Sat Sep 18 17:25:26 2021] mmc1: new high speed SDIO card at address 0001
    [Sat Sep 18 17:25:26 2021] mmc0: new ultra high speed SDR25 SDHC card at address b368
    [Sat Sep 18 17:25:26 2021] mmcblk0: mmc0:b368 CBADS 30.0 GiB
    [Sat Sep 18 17:25:26 2021]  mmcblk0: p1 p2
    [Sat Sep 18 17:25:26 2021] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Sep 18 17:25:26 2021] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Sep 18 17:25:26 2021] devtmpfs: mounted
    [Sat Sep 18 17:25:26 2021] Freeing unused kernel memory: 2048K
    [Sat Sep 18 17:25:26 2021] Run /sbin/init as init process
    [Sat Sep 18 17:25:26 2021]   with arguments:
    [Sat Sep 18 17:25:26 2021]     /sbin/init
    [Sat Sep 18 17:25:26 2021]   with environment:
    [Sat Sep 18 17:25:26 2021]     HOME=/
    [Sat Sep 18 17:25:26 2021]     TERM=linux
    [Sat Sep 18 17:25:26 2021] usb 1-1: new high-speed USB device number 2 using xhci_hcd
    [Sat Sep 18 17:25:26 2021] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
    [Sat Sep 18 17:25:26 2021] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
    [Sat Sep 18 17:25:26 2021] usb 1-1: Product: USB2.0 Hub
    [Sat Sep 18 17:25:26 2021] hub 1-1:1.0: USB hub found
    [Sat Sep 18 17:25:26 2021] hub 1-1:1.0: 4 ports detected
    [Sat Sep 18 17:25:27 2021] usb 1-1.3: new full-speed USB device number 3 using xhci_hcd
    [Sat Sep 18 17:25:27 2021] systemd[1]: System time before build time, advancing clock.
    [Sat Sep 18 17:25:27 2021] usb 1-1.3: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00
    [Sat Sep 18 17:25:27 2021] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [Sat Sep 18 17:25:27 2021] usb 1-1.3: Product: ConBee II
    [Sat Sep 18 17:25:27 2021] usb 1-1.3: Manufacturer: dresden elektronik ingenieurtechnik GmbH
    [Sat Sep 18 17:25:27 2021] usb 1-1.3: SerialNumber: DE2407723
    [Sat Sep 18 17:25:27 2021] NET: Registered protocol family 10
    [Sat Sep 18 17:25:27 2021] Segment Routing with IPv6
    [Sat Sep 18 17:25:27 2021] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
    [Sat Sep 18 17:25:27 2021] systemd[1]: Detected architecture arm.
    [Sat Sep 18 17:25:27 2021] systemd[1]: Set hostname to <raspberrypi>.
    [Sat Sep 18 17:25:28 2021] random: systemd: uninitialized urandom read (16 bytes read)
    [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on Syslog Socket.
    [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on udev Kernel Socket.
    [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on udev Control Socket.
    [Sat Sep 18 17:25:28 2021] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [Sat Sep 18 17:25:28 2021] systemd[1]: Listening on Journal Socket (/dev/log).
    [Sat Sep 18 17:25:28 2021] systemd[1]: Created slice system-getty.slice.
    [Sat Sep 18 17:25:28 2021] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [Sat Sep 18 17:25:29 2021] systemd-journald[122]: Received request to flush runtime journal from PID 1
    [Sat Sep 18 17:25:29 2021] mc: Linux media interface: v0.10
    [Sat Sep 18 17:25:29 2021] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
    [Sat Sep 18 17:25:29 2021] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
    [Sat Sep 18 17:25:29 2021] [vc_sm_connected_init]: start
    [Sat Sep 18 17:25:29 2021] [vc_sm_connected_init]: installed successfully
    [Sat Sep 18 17:25:29 2021] videodev: Linux video capture interface: v2.00
    [Sat Sep 18 17:25:29 2021] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
    [Sat Sep 18 17:25:29 2021] bcm2835_audio bcm2835_audio: card created with 8 channels
    [Sat Sep 18 17:25:29 2021] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
    [Sat Sep 18 17:25:29 2021] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
    [Sat Sep 18 17:25:29 2021] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
    [Sat Sep 18 17:25:29 2021] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
    [Sat Sep 18 17:25:29 2021] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
    [Sat Sep 18 17:25:29 2021] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
    [Sat Sep 18 17:25:29 2021] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
    [Sat Sep 18 17:25:29 2021] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
    [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
    [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
    [Sat Sep 18 17:25:29 2021] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
    [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
    [Sat Sep 18 17:25:29 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
    [Sat Sep 18 17:25:30 2021] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
    [Sat Sep 18 17:25:30 2021] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
    [Sat Sep 18 17:25:30 2021] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
    [Sat Sep 18 17:25:30 2021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [Sat Sep 18 17:25:30 2021] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [Sat Sep 18 17:25:30 2021] brcmfmac: F1 signature read @0x18000000=0x15264345
    [Sat Sep 18 17:25:30 2021] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
    [Sat Sep 18 17:25:30 2021] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    [Sat Sep 18 17:25:30 2021] usbcore: registered new interface driver cdc_acm
    [Sat Sep 18 17:25:30 2021] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [Sat Sep 18 17:25:30 2021] usbcore: registered new interface driver brcmfmac
    [Sat Sep 18 17:25:30 2021] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    [Sat Sep 18 17:25:30 2021] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    [Sat Sep 18 17:25:30 2021] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    [Sat Sep 18 17:25:30 2021] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    [Sat Sep 18 17:25:33 2021] uart-pl011 fe201000.serial: no DMA platform data
    [Sat Sep 18 17:25:33 2021] 8021q: 802.1Q VLAN Support v1.8
    [Sat Sep 18 17:25:33 2021] random: crng init done
    [Sat Sep 18 17:25:33 2021] random: 7 urandom warning(s) missed due to ratelimiting
    [Sat Sep 18 17:25:33 2021] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
    [Sat Sep 18 17:25:34 2021] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    [Sat Sep 18 17:25:34 2021] bcmgenet fd580000.ethernet eth0: Link is Down
    [Sat Sep 18 17:25:38 2021] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [Sat Sep 18 17:25:38 2021] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    [Sat Sep 18 17:25:40 2021] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
    [Sat Sep 18 17:25:40 2021] Bluetooth: Core ver 2.22
    [Sat Sep 18 17:25:40 2021] NET: Registered protocol family 31
    [Sat Sep 18 17:25:40 2021] Bluetooth: HCI device and connection manager initialized
    [Sat Sep 18 17:25:40 2021] Bluetooth: HCI socket layer initialized
    [Sat Sep 18 17:25:40 2021] Bluetooth: L2CAP socket layer initialized
    [Sat Sep 18 17:25:40 2021] Bluetooth: SCO socket layer initialized
    [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART driver ver 2.3
    [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART protocol H4 registered
    [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [Sat Sep 18 17:25:40 2021] Bluetooth: HCI UART protocol Broadcom registered
    [Sat Sep 18 17:25:40 2021] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [Sat Sep 18 17:25:40 2021] Bluetooth: BNEP filters: protocol multicast
    [Sat Sep 18 17:25:40 2021] Bluetooth: BNEP socket layer initialized
    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
    • Horst BöttcherH Horst Böttcher
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v12.22.6
      v12.22.6
      6.14.15
      nodejs:
        Version table:
      dmesg -T
      #42
      @horst-böttcher
      Nichts ungewöhnliches drin, soweit ich sehe.
      Horst BöttcherH 1 Antwort Letzte Antwort
        @horst-böttcher
        Horst Böttcher
        #43
        bleibt aber leider dabei
