  4. Error JavaScript
    6.4k
Error JavaScript
6 Beiträge 2 Kommentatoren 370 Aufrufe 2 Beobachtet
  • ? Offline
    Keine Ahnung was ich damit anfangen kann. Kam nach dem Update auf 12.22.6
    iobroker fix hab ich schon gestartet und hilft nicht.
    javascript.0
    2021-09-05 22:33:54.173	error	In file included from ../src/binding.cc:6:/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(sshcrypto, init) ^~~~~~~~~~~
    javascript.0
    2021-09-05 22:33:52.733	error	In file included from ../src/binding.cc:1:/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(cpufeatures, init) ^~~~~~~~~~~
    Plattform
    linux
    Betriebssystem
    linux
    Architektur
    x64
    Node.js
    v12.22.6
    NPM
    6.14.15
    Aktive Instanzen
    41
    location
    /opt/iobroker/
    |Hardwaresystem:| NUC
    |Arbeitsspeicher:| 8GB |
      javascript.0
      javascript.0
      Plattform
      linux
      Betriebssystem
      linux
      Architektur
      x64
      Node.js
      v12.22.6
      NPM
      6.14.15
      Aktive Instanzen
      41
      location
      /opt/iobroker/
      @brainbug
      nodeJS ist wie installiert?
      npm Cache gelöscht?
      ? 1 Antwort Letzte Antwort
        @brainbug
        npm Cache gelöscht?
        Wie in der Installationsanleitung und dann immer per Update auf die nächste Version.
        npm Cache gelöscht?
        Ich Google, keine Ahnung wie das geht.
        Wenn ich es gemacht habe schreibe ich.
          npm Cache gelöscht?
          @brainbug
          which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          cd /opt/iobroker
          npm cache clear --force
            @brainbug
            cd /opt/iobroker
            which nodejs node npm && nodejs -v && node -        v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v12.22.6
            v12.22.6
            6.14.15
            OK:1 http://deb.debian.org/debian buster InRelease
            Holen:2 http://security.debian.org/debian-security buster/updates InRelease [65,        4 kB]
            Holen:3 http://deb.debian.org/debian buster-updates InRelease [51,9 kB]
            OK:4 https://deb.nodesource.com/node_12.x buster InRelease
            Es wurden 117 kB in 0 s geholt (255 kB/s).
            Alle Pakete sind aktuell.
            OK:2 http://security.debian.org/debian-security buster/updates InRelease
            OK:3 http://deb.debian.org/debian buster-updates InRelease
            nodejs:
              Installiert:           12.22.6-deb-1nodesource1
              Installationskandidat: 12.22.6-deb-1nodesource1
              Versionstabelle:
             *** 12.22.6-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_12.x buster/main amd64 Packages
                    100 /var/lib/dpkg/status
                 10.24.0~dfsg-1~deb10u1 500
                    500 http://deb.debian.org/debian buster/main amd64 Packages
                    500 http://security.debian.org/debian-security buster/updates/main amd64        Packages
            /opt/iobroker$ npm cache clear --force
            npm WARN using --force I sure hope you know what you are doing.
            Cache löschen erledigt.
            iobroker neugestartet und Fehler scheint weg zu sein, ich beobachte es.
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v12.22.6
              v12.22.6
              6.14.15
              nodejs:
                Versionstabelle:
              Nachdem ich gerade auf 3.3.16 upgedatet habe kam die Meldung wieder.
              javascript.0
              2021-09-09 17:38:59.164	error	In file included from ../src/binding.cc:6: /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(sshcrypto, init) ^~~~~~~~~~~
              javascript.0
              2021-09-09 17:38:57.941	error	In file included from ../src/binding.cc:1: /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:736:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^ /home/iobroker/.cache/node-gyp/12.22.6/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~ ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(cpufeatures, init) ^~~~~~~~~~~
